[PATCH 3/3] aarch64/gicv3: Remove accesses to secure registers
Wed Jun 15 00:55:22 UTC 2022
On 14/6/2022 11:44 pm, Gedare Bloom wrote:
> On Mon, Jun 13, 2022 at 7:39 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>>  bsps/include/dev/irq/arm-gicv3.h | 18 +++++++++++++++---
>>  1 file changed, 15 insertions(+), 3 deletions(-)
>> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
>> index 0d3ef9a1c1..a79368ebdf 100644
>> --- a/bsps/include/dev/irq/arm-gicv3.h
>> +++ b/bsps/include/dev/irq/arm-gicv3.h
>> @@ -300,12 +300,25 @@ static void gicv3_init_dist(volatile gic_dist *dist)
>> + * A better way to access these registers than special opcodes
>> +#define isb() __asm __volatile("isb" : : : "memory")
>> +#define  WRITE_SPECIALREG(reg, _val)                                    \
>> +  __asm __volatile("msr  " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
>> +#define  gic_icc_write(reg, val)            \
>> +do {                                        \
>> +  WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
>> +  isb();                                    \
>> +} while (0)
>>  static void gicv3_init_cpu_interface(uint32_t cpu_index)
>>    uint32_t sre_value = 0x7;
>>    WRITE_SR(ICC_SRE, sre_value);
>>    WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
>> -  WRITE_SR(ICC_BPR0, GIC_CPUIF_ICCBPR_BINARY_POINT(0x0));
> This appears unrelated?
The binary pointer effects the secure interrupts and so cannot be touched on
EL1. It traps into EL3. It makes sense to me it is protected. There is no code
in Petalinux or FreeBSD writing to this register.
>>    volatile gic_redist *redist = gicv3_get_redist(cpu_index);
>>    uint32_t waker = redist->icrwaker;
>> @@ -322,8 +335,7 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
>>    /* Enable interrupt groups 0 and 1 */
>> -  WRITE_SR(ICC_IGRPEN0, 0x1);
>> -  WRITE_SR(ICC_IGRPEN1, 0x1);
>> +  gic_icc_write(IGRPEN1, 1);
> Removed the write to IGRPEN0?
The write I replaced is touching a secure register and so traps into EL3 when
your TF-A has enabled a secure mode.
The enable is replaced with a write to the EL1 accessible register. This is how
FreeBSD does it so I copied that method rather than the binary opcode approach
which I found complicated.
You need a suitably configured TF-A to run on aarch64. I would be questioning
any TF-A that lets this code run without these changes. The Xilinx 2020.2
vck-190 build of TF-A lets our code run without this patch however 2021.2 had
tightened things. Xilinx and I looked into the history of their TF-A source and
how they build it and came to the conclusion the change in the secure mode has
come from ARM and their TF-A code.
