[PATCH] tools/gnu: Enable LTO in RSB tools
Joel Sherrill
joel at rtems.org
Wed Jun 15 22:41:19 UTC 2022
On Wed, Jun 15, 2022 at 5:29 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/6/2022 10:58 pm, Joel Sherrill wrote:
> > What's the problem with enabling LTO support in the tools by default?
> None that I know of and this patch enables the support by default. The RSB
> incorrectly supported the configure `--enable-lto` option. That option
> controls
> the host build and when enabled the built host executables are built with
> LTO.
> For RTEMS building LTO support is via the languages option, ie it is
> treated as
> a language. This patch provides that support and enables it.
I'm happy with that. If it is going to cause a problem building the tools,
it would
be better to know it and then disable it for an architecture until that's
resolved.
> > Using it is a different matter.
> Yes. I comments were an attempt to highlight this. I would like to see LTO
> support available but it is not something all users will use.
> FYI Xilinx use to build the Microblaze firmware for the PMC/PMS cores in
> the Versal.
Interesting. I wonder if we have any examples that would show
a real benefit from it. I think it would take a real application to
see an advantage.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220615/0f2a0184/attachment.htm>
