[PATCH] libstdc++: 60241.cc: tolerate slightly shorter aggregate sleep
Sebastian Huber
Wed Jun 22 06:22:12 UTC 2022
On 22/06/2022 08:01, Alexandre Oliva via Gcc-patches wrote:
> On rtems under qemu, the frequently-interrupted nanosleep ends up
> sleeping shorter than expected, by a margin of less than 0,3%.
> I figured failing the library test over a system (emulator?) bug is
> undesirable, so I put in some tolerance for the drift.
> Regstrapped on x86_64-linux-gnu, also tested with a cross to
> aarch64-rtems6. Ok to install?
> PS: I see nothing wrong with the implementation of clock_nanosleep (used
> by nanosleep) on rtems6 that could cause it to wake up too early. I
> suspect some artifact of the emulation environment.
> for libstdc++-v3/ChangeLog
> * testsuite/30_threads/this_thread/60421.cc: Tolerate a
> slightly early wakeup.
> .../testsuite/30_threads/this_thread/60421.cc | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc b/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
> index 12dbeba1cc492..f3a5af453c4ad 100644
> --- a/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
> +++ b/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
> @@ -51,9 +51,10 @@ test02()
> std::thread t([&result, &sleeping] {
> auto start = std::chrono::system_clock::now();
> auto time = std::chrono::seconds(3);
> + auto tolerance = std::chrono::milliseconds(10);
> sleeping = true;
> std::this_thread::sleep_for(time);
> - result = std::chrono::system_clock::now() >= (start + time);
> + result = std::chrono::system_clock::now() + tolerance >= (start + time);
> sleeping = false;
> while (!sleeping)
This looks like a bug in RTEMS or the BSP for the test platform. I would
first investigate this and then change the test which looks all right to me.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
