[PATCH] libstdc++: 60241.cc: tolerate slightly shorter aggregate sleep
    Sebastian Huber
    Wed Jun 22 08:55:27 UTC 2022
On 22/06/2022 08:22, Sebastian Huber wrote:
> On 22/06/2022 08:01, Alexandre Oliva via Gcc-patches wrote:
>> On rtems under qemu, the frequently-interrupted nanosleep ends up
>> sleeping shorter than expected, by a margin of less than 0,3%.
>> I figured failing the library test over a system (emulator?) bug is
>> undesirable, so I put in some tolerance for the drift.
>> Regstrapped on x86_64-linux-gnu, also tested with a cross to
>> aarch64-rtems6.  Ok to install?
>> PS: I see nothing wrong with the implementation of clock_nanosleep (used
>> by nanosleep) on rtems6 that could cause it to wake up too early.  I
>> suspect some artifact of the emulation environment.
>> for  libstdc++-v3/ChangeLog
>>     * testsuite/30_threads/this_thread/60421.cc: Tolerate a
>>     slightly early wakeup.
>>   .../testsuite/30_threads/this_thread/60421.cc      |    3 ++-
>>   1 file changed, 2 insertions(+), 1 deletion(-)
>> diff --git a/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
>> b/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
>> index 12dbeba1cc492..f3a5af453c4ad 100644
>> --- a/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
>> +++ b/libstdc++-v3/testsuite/30_threads/this_thread/60421.cc
>> @@ -51,9 +51,10 @@ test02()
>>     std::thread t([&result, &sleeping] {
>>       auto start = std::chrono::system_clock::now();
>>       auto time = std::chrono::seconds(3);
>> +    auto tolerance = std::chrono::milliseconds(10);
>>       sleeping = true;
>>       std::this_thread::sleep_for(time);
>> -    result = std::chrono::system_clock::now() >= (start + time);
>> +    result = std::chrono::system_clock::now() + tolerance >= (start +
>> time);
>>       sleeping = false;
>>     while (!sleeping)
> This looks like a bug in RTEMS or the BSP for the test platform. I would
> first investigate this and then change the test which looks all right to
> me.
This is a problem in RTEMS. RTEMS uses the FreeBSD timecounters to
maintain CLOCK_REALTIME and provides two methods to get the time in a
coarse and fine resolution. The std::chrono::system_clock::now() uses
the fine resolution (higher overhead). The clock_nanosleep() uses the
coarse resolution which may give a time before now().
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
