[newlib 17/22] sys/_bitset.h: Fix fall-out from commit 5e04571cf3c
Sebastian Huber
Wed Jun 22 08:24:40 UTC 2022
The changes to the bitset macros allowed sched.h to be included into
userland programs without name space pollution due to BIT_* and
BITSET_* macros.
The definition of a global variable "bitset" had been overlooked.
This name space pollution caused a compile failure in print/miktex.
This commit renames the bitset variable to __bitset with the same
mapping back to the bitset if _KERNEL or _WANT_FREEBSD_BITSET is
defined.
This fix has been suggested by kib. It has been tested to let the
build of the print/miktex port succeed and to not break buildworld.
This commit shall be MFCed together with commit 5e04571cf3c.
Reported by: arrowd
MFC after: 1 month
newlib/libc/sys/rtems/include/sys/_bitset.h | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/newlib/libc/sys/rtems/include/sys/_bitset.h b/newlib/libc/sys/rtems/include/sys/_bitset.h
index 1c167daf3..8ce632333 100644
--- a/newlib/libc/sys/rtems/include/sys/_bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/_bitset.h
@@ -61,11 +61,13 @@ struct _t { \
* Define a default type that can be used while manually specifying size
* to every call.
-__BITSET_DEFINE(bitset, 1);
+__BITSET_DEFINE(__bitset, 1);
#if defined(_KERNEL) || defined(_WANT_FREEBSD_BITSET)
#define BITSET_DEFINE(_t, _s) __BITSET_DEFINE(_t, _s)
#define BITSET_DEFINE_VAR(_t) __BITSET_DEFINE_VAR(_t)
+#define bitset __bitset
#endif
#endif /* !_SYS__BITSET_H_ */
2.35.3
