[newlib 16/22] sys/bitset.h: reduce visibility of BIT_* macros
Sebastian Huber
Wed Jun 22 08:24:39 UTC 2022
Add two underscore characters "__" to names of BIT_* and BITSET_*
macros to move them to the implementation name space and to prevent
a name space pollution due to BIT_* macros in 3rd party programs with
conflicting parameter signatures.
These prefixed macro names are used in kernel header files to define
macros in e.g. sched.h, sys/cpuset.h and sys/domainset.h.
If C programs are built with either -D_KERNEL (automatically passed
when building a kernel or kernel modules) or -D_WANT_FREENBSD_BITSET
(or this macros is defined in the source code before including the
bitset macros), then all macros are made visible with their previous
names, too. E.g., both __BIT_SET() and BIT_SET() are visible with
either of _KERNEL or _WANT_FREEBSD_BITSET defined.
The main reason for this change is that some 3rd party sources
including sched.h have been found to contain conflicting BIT_*
macros.
As a work-around, parts of shed.h have been made conditional and
depend on _WITH_CPU_SET_T being set when sched.h is included.
Ports that expect the full functionality provided by sched.h need
to be built with -D_WITH_CPU_SET_T. But this leads to conflicts if
BIT_* macros are defined in that program, too.
This patch set makes all of sched.h visible again without this
parameter being passed and without any name space pollution due
to BIT_* macros becoming visible when sched.h is included.
This patch set will be backported to the STABLE branches, but ports
will need to use -D_WITH_CPU_SET_T as long as there are supported
releases that do not contain these patches.
Reviewed by: kib, markj
MFC after: 1 month
Relnotes: yes
Differential Revision: https://reviews.freebsd.org/D33235
newlib/libc/sys/rtems/include/sys/_bitset.h | 13 +-
newlib/libc/sys/rtems/include/sys/_cpuset.h | 2 +-
newlib/libc/sys/rtems/include/sys/bitset.h | 130 +++++++++++++-------
newlib/libc/sys/rtems/include/sys/cpuset.h | 60 ++++-----
4 files changed, 127 insertions(+), 78 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/sys/_bitset.h b/newlib/libc/sys/rtems/include/sys/_bitset.h
index e54f04cbe..1c167daf3 100644
--- a/newlib/libc/sys/rtems/include/sys/_bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/_bitset.h
@@ -44,8 +44,8 @@
#define __bitset_words(_s) (__howmany(_s, _BITSET_BITS))
-#define BITSET_DEFINE(t, _s) \
-struct t { \
+#define __BITSET_DEFINE(_t, _s) \
+struct _t { \
long __bits[__bitset_words((_s))]; \
@@ -55,12 +55,17 @@ struct t { \
* Sadly we cannot declare a bitset struct with '__bits[]', because it's
* the only member of the struct and the compiler complains.
-#define BITSET_DEFINE_VAR(t) BITSET_DEFINE(t, 1)
+#define __BITSET_DEFINE_VAR(_t) __BITSET_DEFINE(_t, 1)
* Define a default type that can be used while manually specifying size
* to every call.
-BITSET_DEFINE(bitset, 1);
+__BITSET_DEFINE(bitset, 1);
+#if defined(_KERNEL) || defined(_WANT_FREEBSD_BITSET)
+#define BITSET_DEFINE(_t, _s) __BITSET_DEFINE(_t, _s)
+#define BITSET_DEFINE_VAR(_t) __BITSET_DEFINE_VAR(_t)
+#endif
#endif /* !_SYS__BITSET_H_ */
diff --git a/newlib/libc/sys/rtems/include/sys/_cpuset.h b/newlib/libc/sys/rtems/include/sys/_cpuset.h
index dee341665..c6383f363 100644
--- a/newlib/libc/sys/rtems/include/sys/_cpuset.h
+++ b/newlib/libc/sys/rtems/include/sys/_cpuset.h
@@ -46,7 +46,7 @@
#endif
#endif
-BITSET_DEFINE(_cpuset, CPU_SETSIZE);
+__BITSET_DEFINE(_cpuset, CPU_SETSIZE);
typedef struct _cpuset cpuset_t;
#endif /* !_SYS__CPUSET_H_ */
diff --git a/newlib/libc/sys/rtems/include/sys/bitset.h b/newlib/libc/sys/rtems/include/sys/bitset.h
index 88cda9dd9..00bdc23f9 100644
--- a/newlib/libc/sys/rtems/include/sys/bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/bitset.h
@@ -51,36 +51,36 @@
(__constexpr_cond(__bitset_words((_s)) == 1) ? \
0 : ((n) / _BITSET_BITS))
-#define BIT_CLR(_s, n, p) \
+#define __BIT_CLR(_s, n, p) \
((p)->__bits[__bitset_word(_s, n)] &= ~__bitset_mask((_s), (n)))
-#define BIT_COPY(_s, f, t) (void)(*(t) = *(f))
+#define __BIT_COPY(_s, f, t) (void)(*(t) = *(f))
-#define BIT_ISSET(_s, n, p) \
+#define __BIT_ISSET(_s, n, p) \
((((p)->__bits[__bitset_word(_s, n)] & __bitset_mask((_s), (n))) != 0))
-#define BIT_SET(_s, n, p) \
+#define __BIT_SET(_s, n, p) \
((p)->__bits[__bitset_word(_s, n)] |= __bitset_mask((_s), (n)))
-#define BIT_ZERO(_s, p) do { \
+#define __BIT_ZERO(_s, p) do { \
__size_t __i; \
for (__i = 0; __i < __bitset_words((_s)); __i++) \
(p)->__bits[__i] = 0L; \
} while (0)
-#define BIT_FILL(_s, p) do { \
+#define __BIT_FILL(_s, p) do { \
__size_t __i; \
(p)->__bits[__i] = -1L; \
} while (0)
-#define BIT_SETOF(_s, n, p) do { \
- BIT_ZERO(_s, p); \
+#define __BIT_SETOF(_s, n, p) do { \
+ __BIT_ZERO(_s, p); \
(p)->__bits[__bitset_word(_s, n)] = __bitset_mask((_s), (n)); \
} while (0)
/* Is p empty. */
-#define BIT_EMPTY(_s, p) __extension__ ({ \
+#define __BIT_EMPTY(_s, p) __extension__ ({ \
__size_t __i; \
if ((p)->__bits[__i]) \
@@ -89,7 +89,7 @@
/* Is p full set. */
-#define BIT_ISFULLSET(_s, p) __extension__ ({ \
+#define __BIT_ISFULLSET(_s, p) __extension__ ({ \
__size_t __i; \
if ((p)->__bits[__i] != (long)-1) \
@@ -98,7 +98,7 @@
/* Is c a subset of p. */
-#define BIT_SUBSET(_s, p, c) __extension__ ({ \
+#define __BIT_SUBSET(_s, p, c) __extension__ ({ \
__size_t __i; \
if (((c)->__bits[__i] & \
@@ -109,7 +109,7 @@
/* Are there any common bits between b & c? */
-#define BIT_OVERLAP(_s, p, c) __extension__ ({ \
+#define __BIT_OVERLAP(_s, p, c) __extension__ ({ \
__size_t __i; \
@@ -119,7 +119,7 @@
/* Compare two sets, returns 0 if equal 1 otherwise. */
-#define BIT_CMP(_s, p, c) __extension__ ({ \
+#define __BIT_CMP(_s, p, c) __extension__ ({ \
__size_t __i; \
if (((c)->__bits[__i] != \
@@ -128,49 +128,49 @@
__i != __bitset_words((_s)); \
-#define BIT_OR(_s, d, s) do { \
+#define __BIT_OR(_s, d, s) do { \
__size_t __i; \
(d)->__bits[__i] |= (s)->__bits[__i]; \
} while (0)
-#define BIT_OR2(_s, d, s1, s2) do { \
+#define __BIT_OR2(_s, d, s1, s2) do { \
__size_t __i; \
(d)->__bits[__i] = (s1)->__bits[__i] | (s2)->__bits[__i];\
} while (0)
-#define BIT_AND(_s, d, s) do { \
+#define __BIT_AND(_s, d, s) do { \
__size_t __i; \
(d)->__bits[__i] &= (s)->__bits[__i]; \
} while (0)
-#define BIT_AND2(_s, d, s1, s2) do { \
+#define __BIT_AND2(_s, d, s1, s2) do { \
__size_t __i; \
(d)->__bits[__i] = (s1)->__bits[__i] & (s2)->__bits[__i];\
} while (0)
-#define BIT_ANDNOT(_s, d, s) do { \
+#define __BIT_ANDNOT(_s, d, s) do { \
__size_t __i; \
(d)->__bits[__i] &= ~(s)->__bits[__i]; \
} while (0)
-#define BIT_ANDNOT2(_s, d, s1, s2) do { \
+#define __BIT_ANDNOT2(_s, d, s1, s2) do { \
__size_t __i; \
(d)->__bits[__i] = (s1)->__bits[__i] & ~(s2)->__bits[__i];\
} while (0)
-#define BIT_XOR(_s, d, s) do { \
+#define __BIT_XOR(_s, d, s) do { \
__size_t __i; \
(d)->__bits[__i] ^= (s)->__bits[__i]; \
} while (0)
-#define BIT_XOR2(_s, d, s1, s2) do { \
+#define __BIT_XOR2(_s, d, s1, s2) do { \
__size_t __i; \
(d)->__bits[__i] = (s1)->__bits[__i] ^ (s2)->__bits[__i];\
@@ -182,42 +182,42 @@
* or a bit index.
-#define BIT_CLR_ATOMIC(_s, n, p) \
+#define __BIT_CLR_ATOMIC(_s, n, p) \
atomic_clear_long(&(p)->__bits[__bitset_word(_s, n)], \
__bitset_mask((_s), n))
-#define BIT_SET_ATOMIC(_s, n, p) \
+#define __BIT_SET_ATOMIC(_s, n, p) \
atomic_set_long(&(p)->__bits[__bitset_word(_s, n)], \
-#define BIT_SET_ATOMIC_ACQ(_s, n, p) \
+#define __BIT_SET_ATOMIC_ACQ(_s, n, p) \
atomic_set_acq_long(&(p)->__bits[__bitset_word(_s, n)], \
-#define BIT_TEST_CLR_ATOMIC(_s, n, p) \
+#define __BIT_TEST_CLR_ATOMIC(_s, n, p) \
(atomic_testandclear_long( \
&(p)->__bits[__bitset_word((_s), (n))], (n)) != 0)
-#define BIT_TEST_SET_ATOMIC(_s, n, p) \
+#define __BIT_TEST_SET_ATOMIC(_s, n, p) \
(atomic_testandset_long( \
/* Convenience functions catering special cases. */
-#define BIT_AND_ATOMIC(_s, d, s) do { \
+#define __BIT_AND_ATOMIC(_s, d, s) do { \
__size_t __i; \
atomic_clear_long(&(d)->__bits[__i], \
~(s)->__bits[__i]); \
} while (0)
-#define BIT_OR_ATOMIC(_s, d, s) do { \
+#define __BIT_OR_ATOMIC(_s, d, s) do { \
__size_t __i; \
atomic_set_long(&(d)->__bits[__i], \
} while (0)
-#define BIT_COPY_STORE_REL(_s, f, t) do { \
+#define __BIT_COPY_STORE_REL(_s, f, t) do { \
__size_t __i; \
atomic_store_rel_long(&(t)->__bits[__i], \
@@ -225,10 +225,10 @@
} while (0)
- * Note that `start` and the returned value from BIT_FFS_AT are
+ * Note that `start` and the returned value from __BIT_FFS_AT are
* 1-based bit indices.
-#define BIT_FFS_AT(_s, p, start) __extension__ ({ \
+#define __BIT_FFS_AT(_s, p, start) __extension__ ({ \
__size_t __i; \
long __bit, __mask; \
@@ -247,9 +247,9 @@
__bit; \
-#define BIT_FFS(_s, p) BIT_FFS_AT((_s), (p), 0)
+#define __BIT_FFS(_s, p) __BIT_FFS_AT((_s), (p), 0)
-#define BIT_FLS(_s, p) __extension__ ({ \
+#define __BIT_FLS(_s, p) __extension__ ({ \
__size_t __i; \
long __bit; \
@@ -264,7 +264,7 @@
__bit; \
-#define BIT_COUNT(_s, p) __extension__ ({ \
+#define __BIT_COUNT(_s, p) __extension__ ({ \
__size_t __i; \
long __count; \
@@ -274,7 +274,7 @@
__count; \
-#define _BIT_FOREACH_ADVANCE(_s, i, p, op) __extension__ ({ \
+#define __BIT_FOREACH_ADVANCE(_s, i, p, op) __extension__ ({ \
int __found; \
for (;;) { \
if (__bits != 0) { \
@@ -296,24 +296,68 @@
* Non-destructively loop over all set or clear bits in the set.
-#define _BIT_FOREACH(_s, i, p, op) \
+#define __BIT_FOREACH(_s, i, p, op) \
for (long __i = -1, __bits = 0; \
- _BIT_FOREACH_ADVANCE(_s, i, p, op); )
+ __BIT_FOREACH_ADVANCE(_s, i, p, op); )
-#define BIT_FOREACH_ISSET(_s, i, p) _BIT_FOREACH(_s, i, p, )
-#define BIT_FOREACH_ISCLR(_s, i, p) _BIT_FOREACH(_s, i, p, ~)
+#define __BIT_FOREACH_ISSET(_s, i, p) __BIT_FOREACH(_s, i, p, )
+#define __BIT_FOREACH_ISCLR(_s, i, p) __BIT_FOREACH(_s, i, p, ~)
-#define BITSET_T_INITIALIZER(x) \
+#define __BITSET_T_INITIALIZER(x) \
{ .__bits = { x } }
-#define BITSET_FSET(n) \
+#define __BITSET_FSET(n) \
[ 0 ... ((n) - 1) ] = (-1L)
-#define BITSET_SIZE(_s) (__bitset_words((_s)) * sizeof(long))
+#define __BITSET_SIZE(_s) (__bitset_words((_s)) * sizeof(long))
* Dynamically allocate a bitset.
-#define BITSET_ALLOC(_s, mt, mf) malloc(BITSET_SIZE((_s)), mt, (mf))
+#define __BITSET_ALLOC(_s, mt, mf) malloc(__BITSET_SIZE((_s)), mt, (mf))
+#define BIT_AND(_s, d, s) __BIT_AND(_s, d, s)
+#define BIT_AND2(_s, d, s1, s2) __BIT_AND2(_s, d, s1, s2)
+#define BIT_ANDNOT(_s, d, s) __BIT_ANDNOT(_s, d, s)
+#define BIT_ANDNOT2(_s, d, s1, s2) __BIT_ANDNOT2(_s, d, s1, s2)
+#define BIT_AND_ATOMIC(_s, d, s) __BIT_AND_ATOMIC(_s, d, s)
+#define BIT_CLR(_s, n, p) __BIT_CLR(_s, n, p)
+#define BIT_CLR_ATOMIC(_s, n, p) __BIT_CLR_ATOMIC(_s, n, p)
+#define BIT_CMP(_s, p, c) __BIT_CMP(_s, p, c)
+#define BIT_COPY(_s, f, t) __BIT_COPY(_s, f, t)
+#define BIT_COPY_STORE_REL(_s, f, t) __BIT_COPY_STORE_REL(_s, f, t)
+#define BIT_COUNT(_s, p) __BIT_COUNT(_s, p)
+#define BIT_EMPTY(_s, p) __BIT_EMPTY(_s, p)
+#define BIT_FFS(_s, p) __BIT_FFS(_s, p)
+#define BIT_FFS_AT(_s, p, start) __BIT_FFS_AT(_s, p, start)
+#define BIT_FILL(_s, p) __BIT_FILL(_s, p)
+#define BIT_FLS(_s, p) __BIT_FLS(_s, p)
+#define BIT_FOREACH(_s, i, p, op) __BIT_FOREACH(_s, i, p, op)
+#define BIT_FOREACH_ADVANCE(_s, i, p, op) __BIT_FOREACH_ADVANCE(_s, i, p, op)
+#define BIT_FOREACH_ISCLR(_s, i, p) __BIT_FOREACH_ISCLR(_s, i, p)
+#define BIT_FOREACH_ISSET(_s, i, p) __BIT_FOREACH_ISSET(_s, i, p)
+#define BIT_ISFULLSET(_s, p) __BIT_ISFULLSET(_s, p)
+#define BIT_ISSET(_s, n, p) __BIT_ISSET(_s, n, p)
+#define BIT_OR(_s, d, s) __BIT_OR(_s, d, s)
+#define BIT_OR2(_s, d, s1, s2) __BIT_OR2(_s, d, s1, s2)
+#define BIT_OR_ATOMIC(_s, d, s) __BIT_OR_ATOMIC(_s, d, s)
+#define BIT_OVERLAP(_s, p, c) __BIT_OVERLAP(_s, p, c)
+#define BIT_SET(_s, n, p) __BIT_SET(_s, n, p)
+#define BIT_SETOF(_s, n, p) __BIT_SETOF(_s, n, p)
+#define BIT_SET_ATOMIC(_s, n, p) __BIT_SET_ATOMIC(_s, n, p)
+#define BIT_SET_ATOMIC_ACQ(_s, n, p) __BIT_SET_ATOMIC_ACQ(_s, n, p)
+#define BIT_SUBSET(_s, p, c) __BIT_SUBSET(_s, p, c)
+#define BIT_TEST_CLR_ATOMIC(_s, n, p) __BIT_TEST_CLR_ATOMIC(_s, n, p)
+#define BIT_TEST_SET_ATOMIC(_s, n, p) __BIT_TEST_SET_ATOMIC(_s, n, p)
+#define BIT_XOR(_s, d, s) __BIT_XOR(_s, d, s)
+#define BIT_XOR2(_s, d, s1, s2) __BIT_XOR2(_s, d, s1, s2)
+#define BIT_ZERO(_s, p) __BIT_ZERO(_s, p)
+#define BITSET_ALLOC(_s, mt, mf) __BITSET_ALLOC(_s, mt, mf)
+#define BITSET_FSET(n) __BITSET_FSET(n)
+#define BITSET_SIZE(_s) __BITSET_SIZE(_s)
+#define BITSET_T_INITIALIZER(x) __BITSET_T_INITIALIZER(x)
+#endif
#endif /* !_SYS_BITSET_H_ */
diff --git a/newlib/libc/sys/rtems/include/sys/cpuset.h b/newlib/libc/sys/rtems/include/sys/cpuset.h
index e46090b8a..e24bce30c 100644
--- a/newlib/libc/sys/rtems/include/sys/cpuset.h
+++ b/newlib/libc/sys/rtems/include/sys/cpuset.h
@@ -50,22 +50,22 @@
#define CPUSETBUFSIZ ((2 + sizeof(long) * 2) * _NCPUWORDS)
-#define CPU_SETOF(n, p) BIT_SETOF(CPU_SETSIZE, n, p)
-#define CPU_ISFULLSET(p) BIT_ISFULLSET(CPU_SETSIZE, p)
-#define CPU_SUBSET(p, c) BIT_SUBSET(CPU_SETSIZE, p, c)
-#define CPU_OVERLAP(p, c) BIT_OVERLAP(CPU_SETSIZE, p, c)
-#define CPU_CLR_ATOMIC(n, p) BIT_CLR_ATOMIC(CPU_SETSIZE, n, p)
-#define CPU_SET_ATOMIC(n, p) BIT_SET_ATOMIC(CPU_SETSIZE, n, p)
-#define CPU_SET_ATOMIC_ACQ(n, p) BIT_SET_ATOMIC_ACQ(CPU_SETSIZE, n, p)
-#define CPU_AND_ATOMIC(n, p) BIT_AND_ATOMIC(CPU_SETSIZE, n, p)
-#define CPU_OR_ATOMIC(d, s) BIT_OR_ATOMIC(CPU_SETSIZE, d, s)
-#define CPU_COPY_STORE_REL(f, t) BIT_COPY_STORE_REL(CPU_SETSIZE, f, t)
-#define CPU_FFS(p) BIT_FFS(CPU_SETSIZE, p)
-#define CPU_FLS(p) BIT_FLS(CPU_SETSIZE, p)
-#define CPU_FOREACH_ISSET(i, p) BIT_FOREACH_ISSET(CPU_SETSIZE, i, p)
-#define CPU_FOREACH_ISCLR(i, p) BIT_FOREACH_ISCLR(CPU_SETSIZE, i, p)
-#define CPUSET_FSET BITSET_FSET(_NCPUWORDS)
-#define CPUSET_T_INITIALIZER BITSET_T_INITIALIZER
+#define CPU_SETOF(n, p) __BIT_SETOF(CPU_SETSIZE, n, p)
+#define CPU_ISFULLSET(p) __BIT_ISFULLSET(CPU_SETSIZE, p)
+#define CPU_SUBSET(p, c) __BIT_SUBSET(CPU_SETSIZE, p, c)
+#define CPU_OVERLAP(p, c) __BIT_OVERLAP(CPU_SETSIZE, p, c)
+#define CPU_CLR_ATOMIC(n, p) __BIT_CLR_ATOMIC(CPU_SETSIZE, n, p)
+#define CPU_SET_ATOMIC(n, p) __BIT_SET_ATOMIC(CPU_SETSIZE, n, p)
+#define CPU_SET_ATOMIC_ACQ(n, p) __BIT_SET_ATOMIC_ACQ(CPU_SETSIZE, n, p)
+#define CPU_AND_ATOMIC(n, p) __BIT_AND_ATOMIC(CPU_SETSIZE, n, p)
+#define CPU_OR_ATOMIC(d, s) __BIT_OR_ATOMIC(CPU_SETSIZE, d, s)
+#define CPU_COPY_STORE_REL(f, t) __BIT_COPY_STORE_REL(CPU_SETSIZE, f, t)
+#define CPU_FFS(p) __BIT_FFS(CPU_SETSIZE, p)
+#define CPU_FLS(p) __BIT_FLS(CPU_SETSIZE, p)
+#define CPU_FOREACH_ISSET(i, p) __BIT_FOREACH_ISSET(CPU_SETSIZE, i, p)
+#define CPU_FOREACH_ISCLR(i, p) __BIT_FOREACH_ISCLR(CPU_SETSIZE, i, p)
+#define CPUSET_FSET __BITSET_FSET(_NCPUWORDS)
+#define CPUSET_T_INITIALIZER __BITSET_T_INITIALIZER
typedef cpuset_t cpu_set_t;
@@ -91,7 +91,7 @@ static __inline void CPU_FREE(cpu_set_t *set)
static __inline void CPU_ZERO_S(size_t setsize, cpu_set_t *set)
- BIT_ZERO(_cpu_set_bits(setsize), set);
+ __BIT_ZERO(_cpu_set_bits(setsize), set);
static __inline void CPU_ZERO(cpu_set_t *set)
@@ -101,7 +101,7 @@ static __inline void CPU_ZERO(cpu_set_t *set)
static __inline void CPU_FILL_S(size_t setsize, cpu_set_t *set)
- BIT_FILL(_cpu_set_bits(setsize), set);
+ __BIT_FILL(_cpu_set_bits(setsize), set);
static __inline void CPU_FILL(cpu_set_t *set)
@@ -111,7 +111,7 @@ static __inline void CPU_FILL(cpu_set_t *set)
static __inline void CPU_SET_S(int cpu, size_t setsize, cpu_set_t *set)
- BIT_SET(_cpu_set_bits(setsize), cpu, set);
+ __BIT_SET(_cpu_set_bits(setsize), cpu, set);
static __inline void CPU_SET(int cpu, cpu_set_t *set)
@@ -121,7 +121,7 @@ static __inline void CPU_SET(int cpu, cpu_set_t *set)
static __inline void CPU_CLR_S(int cpu, size_t setsize, cpu_set_t *set)
- BIT_CLR(_cpu_set_bits(setsize), cpu, set);
+ __BIT_CLR(_cpu_set_bits(setsize), cpu, set);
static __inline void CPU_CLR(int cpu, cpu_set_t *set)
@@ -131,7 +131,7 @@ static __inline void CPU_CLR(int cpu, cpu_set_t *set)
static __inline int CPU_ISSET_S(int cpu, size_t setsize, const cpu_set_t *set)
- return BIT_ISSET(_cpu_set_bits(setsize), cpu, set);
+ return __BIT_ISSET(_cpu_set_bits(setsize), cpu, set);
static __inline int CPU_ISSET(int cpu, const cpu_set_t *set)
@@ -141,13 +141,13 @@ static __inline int CPU_ISSET(int cpu, const cpu_set_t *set)
static __inline void CPU_COPY(const cpu_set_t *src, cpu_set_t *dest)
- BIT_COPY(_cpu_set_bits(setsize), src, dest);
+ __BIT_COPY(_cpu_set_bits(setsize), src, dest);
static __inline void CPU_AND_S(size_t setsize, cpu_set_t *destset,
const cpu_set_t *srcset1, const cpu_set_t *srcset2)
- BIT_AND2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
+ __BIT_AND2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
static __inline void CPU_AND(cpu_set_t *destset, const cpu_set_t *srcset1,
@@ -159,7 +159,7 @@ static __inline void CPU_AND(cpu_set_t *destset, const cpu_set_t *srcset1,
static __inline void CPU_OR_S(size_t setsize, cpu_set_t *destset,
- BIT_OR2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
+ __BIT_OR2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
static __inline void CPU_OR(cpu_set_t *destset, const cpu_set_t *srcset1,
@@ -171,7 +171,7 @@ static __inline void CPU_OR(cpu_set_t *destset, const cpu_set_t *srcset1,
static __inline void CPU_XOR_S(size_t setsize, cpu_set_t *destset,
- BIT_XOR2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
+ __BIT_XOR2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
static __inline void CPU_XOR(cpu_set_t *destset, const cpu_set_t *srcset1,
@@ -183,7 +183,7 @@ static __inline void CPU_XOR(cpu_set_t *destset, const cpu_set_t *srcset1,
static __inline void CPU_ANDNOT_S(size_t setsize, cpu_set_t *destset,
- BIT_ANDNOT2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
+ __BIT_ANDNOT2(_cpu_set_bits(setsize), destset, srcset1, srcset2);
static __inline void CPU_ANDNOT(cpu_set_t *destset, const cpu_set_t *srcset1,
@@ -194,7 +194,7 @@ static __inline void CPU_ANDNOT(cpu_set_t *destset, const cpu_set_t *srcset1,
static __inline int CPU_COUNT_S(size_t setsize, const cpu_set_t *set)
- return (int)BIT_COUNT(_cpu_set_bits(setsize), set);
+ return (int)__BIT_COUNT(_cpu_set_bits(setsize), set);
static __inline int CPU_COUNT(const cpu_set_t *set)
@@ -205,7 +205,7 @@ static __inline int CPU_COUNT(const cpu_set_t *set)
static __inline int CPU_EQUAL_S(size_t setsize, const cpu_set_t *set1,
const cpu_set_t *set2)
- return BIT_CMP(_cpu_set_bits(setsize), set1, set2) == 0;
+ return __BIT_CMP(_cpu_set_bits(setsize), set1, set2) == 0;
static __inline int CPU_EQUAL(const cpu_set_t *set1, const cpu_set_t *set2)
@@ -215,12 +215,12 @@ static __inline int CPU_EQUAL(const cpu_set_t *set1, const cpu_set_t *set2)
static __inline int CPU_CMP(const cpu_set_t *set1, const cpu_set_t *set2)
- return BIT_CMP(CPU_SETSIZE, set1, set2);
+ return __BIT_CMP(CPU_SETSIZE, set1, set2);
static __inline int CPU_EMPTY(const cpu_set_t *set)
- return BIT_EMPTY(_cpu_set_bits(sizeof(*set)), set);
+ return __BIT_EMPTY(_cpu_set_bits(sizeof(*set)), set);
__END_DECLS
2.35.3
