[newlib 11/22] cpuset(9): Add CPU_FOREACH_IS(SET|CLR) and modify consumers to use it
Wed Jun 22 08:24:34 UTC 2022
This implementation is faster and doesn't modify the cpuset, so it lets
us avoid some unnecessary copying as well.  No functional change
intended.
Reviewed by:	cem, kib, jhb
MFC after:	2 weeks
Sponsored by:	The FreeBSD Foundation
Differential Revision:	https://reviews.freebsd.org/D32029
 newlib/libc/sys/rtems/include/sys/cpuset.h | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/newlib/libc/sys/rtems/include/sys/cpuset.h b/newlib/libc/sys/rtems/include/sys/cpuset.h
index a321bddc2..7779f0639 100644
--- a/newlib/libc/sys/rtems/include/sys/cpuset.h
+++ b/newlib/libc/sys/rtems/include/sys/cpuset.h
@@ -62,6 +62,8 @@
 #define	CPU_COPY_STORE_REL(f, t)	BIT_COPY_STORE_REL(CPU_SETSIZE, f, t)
 #define	CPU_FFS(p)			BIT_FFS(CPU_SETSIZE, p)
 #define	CPU_FLS(p)			BIT_FLS(CPU_SETSIZE, p)
+#define	CPU_FOREACH_ISSET(i, p)		BIT_FOREACH_ISSET(CPU_SETSIZE, i, p)
+#define	CPU_FOREACH_ISCLR(i, p)		BIT_FOREACH_ISCLR(CPU_SETSIZE, i, p)
 #define	CPUSET_FSET			BITSET_FSET(_NCPUWORDS)
 #define	CPUSET_T_INITIALIZER		BITSET_T_INITIALIZER
2.35.3
