[newlib 10/22] bitset(9): Introduce BIT_FOREACH_ISSET and BIT_FOREACH_ISCLR
Wed Jun 22 08:24:33 UTC 2022
These allow one to non-destructively iterate over the set or clear bits
in a bitset.  The motivation is that we have several code fragments
which iterate over a CPU set like this:
while ((cpu = CPU_FFS(&cpus)) != 0) {
	cpu--;
	CPU_CLR(cpu, &cpus);
	<do something>;
This is slow since CPU_FFS begins the search at the beginning of the
bitset each time.  On amd64 and arm64, CPU sets have size 256, so there
are four limbs in the bitset and we do a lot of unnecessary scanning.
A second problem is that this is destructive, so code which needs to
preserve the original set has to make a copy.  In particular, we have
quite a few functions which take a cpuset_t parameter by value, meaning
that each call has to copy the 32 byte cpuset_t.
The new macros address both problems.
Reviewed by:	cem, kib
MFC after:	2 weeks
Sponsored by:	The FreeBSD Foundation
Differential Revision:	https://reviews.freebsd.org/D32028
 newlib/libc/sys/rtems/include/sys/bitset.h | 10 ++++++++++
 1 file changed, 10 insertions(+)
diff --git a/newlib/libc/sys/rtems/include/sys/bitset.h b/newlib/libc/sys/rtems/include/sys/bitset.h
index 913fa290d..35c21f6ae 100644
--- a/newlib/libc/sys/rtems/include/sys/bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/bitset.h
@@ -274,6 +274,16 @@
 	__count;							\
+/* Non-destructively loop over all set or clear bits in the set. */
+#define	_BIT_FOREACH(_s, i, p, op)					\
+	for (__size_t __i = 0; __i < __bitset_words(_s); __i++)		\
+		for (long __j = op((p)->__bits[__i]), __b = ffsl(__j);	\
+		    (i = (__b - 1) + __i * _BITSET_BITS), __j != 0;	\
+		    __j &= ~(1l << i), __b = ffsl(__j))
+#define	BIT_FOREACH_ISSET(_s, i, p)	_BIT_FOREACH(_s, i, p, )
+#define	BIT_FOREACH_ISCLR(_s, i, p)	_BIT_FOREACH(_s, i, p, ~)
 #define	BITSET_T_INITIALIZER(x)						\
 	{ .__bits = { x } }
2.35.3
