[newlib 07/22] bitset: expand bit index type to `long`
Sebastian Huber
Wed Jun 22 08:24:30 UTC 2022
An upcoming patch to use the bitset macros for tracking vm page
dump information could conceivably need more than INT_MAX bits.
Expand the bit type to long so that the extra range is available
on 64-bit platforms where it would most likely be needed.
CPUSET_COUNT and DOMAINSET_COUNT are also modified to remain of
type `int`.
Reviewed by: kib, markj
Approved by: scottl (implicit)
MFC after: 1 week
Sponsored by: Ampere Computing, Inc.
Differential Revision: https://reviews.freebsd.org/D26190
newlib/libc/sys/rtems/include/sys/bitset.h | 7 +++----
newlib/libc/sys/rtems/include/sys/cpuset.h | 2 +-
2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/sys/bitset.h b/newlib/libc/sys/rtems/include/sys/bitset.h
index 2e00dab7b..3f263acd0 100644
--- a/newlib/libc/sys/rtems/include/sys/bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/bitset.h
@@ -216,8 +216,7 @@
#define BIT_FFS_AT(_s, p, start) __extension__ ({ \
__size_t __i; \
- long __mask; \
- int __bit; \
+ long __bit, __mask; \
__mask = ~0UL << ((start) % _BITSET_BITS); \
__bit = 0; \
@@ -238,7 +237,7 @@
#define BIT_FLS(_s, p) __extension__ ({ \
__size_t __i; \
- int __bit; \
+ long __bit; \
__bit = 0; \
for (__i = __bitset_words((_s)); __i > 0; __i--) { \
@@ -253,7 +252,7 @@
#define BIT_COUNT(_s, p) __extension__ ({ \
__size_t __i; \
- int __count; \
+ long __count; \
__count = 0; \
for (__i = 0; __i < __bitset_words((_s)); __i++) \
diff --git a/newlib/libc/sys/rtems/include/sys/cpuset.h b/newlib/libc/sys/rtems/include/sys/cpuset.h
index a8af67bac..7958e3b1a 100644
--- a/newlib/libc/sys/rtems/include/sys/cpuset.h
+++ b/newlib/libc/sys/rtems/include/sys/cpuset.h
@@ -191,7 +191,7 @@ static __inline void CPU_ANDNOT(cpu_set_t *destset, const cpu_set_t *srcset1,
static __inline int CPU_COUNT_S(size_t setsize, const cpu_set_t *set)
- return BIT_COUNT(_cpu_set_bits(setsize), set);
+ return (int)BIT_COUNT(_cpu_set_bits(setsize), set);
static __inline int CPU_COUNT(const cpu_set_t *set)
2.35.3
