[newlib 08/22] bitset: implement BIT_TEST_CLR_ATOMIC & BIT_TEST_SET_ATOMIC
Wed Jun 22 08:24:31 UTC 2022
That is, provide wrappers around the atomic_testandclear and
atomic_testandset primitives.
Submitted by:	jeff
Reviewed by:	cem, kib, markj
Sponsored by:	Dell EMC Isilon
Differential Revision:	https://reviews.freebsd.org/D22702
 newlib/libc/sys/rtems/include/sys/bitset.h | 14 ++++++++++++++
 1 file changed, 14 insertions(+)
diff --git a/newlib/libc/sys/rtems/include/sys/bitset.h b/newlib/libc/sys/rtems/include/sys/bitset.h
index 3f263acd0..913fa290d 100644
--- a/newlib/libc/sys/rtems/include/sys/bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/bitset.h
@@ -176,6 +176,12 @@
 		(d)->__bits[__i] = (s1)->__bits[__i] ^ (s2)->__bits[__i];\
 } while (0)
+ * Note, the atomic(9) API is not consistent between clear/set and
+ * testandclear/testandset in whether the value argument is a mask
+ * or a bit index.
 #define	BIT_CLR_ATOMIC(_s, n, p)					\
 	atomic_clear_long(&(p)->__bits[__bitset_word(_s, n)],		\
 	    __bitset_mask((_s), n))
@@ -188,6 +194,14 @@
 	atomic_set_acq_long(&(p)->__bits[__bitset_word(_s, n)],		\
+#define	BIT_TEST_CLR_ATOMIC(_s, n, p)					\
+	(atomic_testandclear_long(					\
+	    &(p)->__bits[__bitset_word((_s), (n))], (n)) != 0)
+#define	BIT_TEST_SET_ATOMIC(_s, n, p)					\
+	(atomic_testandset_long(					\
 /* Convenience functions catering special cases. */
 #define	BIT_AND_ATOMIC(_s, d, s) do {					\
 	__size_t __i;							\
2.35.3
