[libbsd 2/4] if_lpe.c: Port to LibBSD
Sebastian Huber
Thu Jun 23 09:20:18 UTC 2022
libbsd.py | 1 +
rtemsbsd/sys/arm/lpc/if_lpe.c | 466 +++++++++++++++++-----------------
2 files changed, 228 insertions(+), 239 deletions(-)
diff --git a/libbsd.py b/libbsd.py
index de22eaa9..983f41a1 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -235,6 +235,7 @@ class rtems(builder.Module):
'rtems/rtems-legacy-rtrequest.c',
'rtems/rtems-legacy-newproc.c',
'rtems/rtems-legacy-mii.c',
+ 'sys/arm/lpc/if_lpe.c',
'sys/arm/lpc/lpc_pwr.c',
'sys/dev/atsam/if_atsam.c',
'sys/dev/atsam/if_atsam_media.c',
diff --git a/rtemsbsd/sys/arm/lpc/if_lpe.c b/rtemsbsd/sys/arm/lpc/if_lpe.c
index ccfe1696..247bd486 100755
--- a/rtemsbsd/sys/arm/lpc/if_lpe.c
+++ b/rtemsbsd/sys/arm/lpc/if_lpe.c
@@ -22,28 +22,32 @@
#include <machine/rtems-bsd-kernel-space.h>
-#include <errno.h>
-#include <inttypes.h>
-#include <stdlib.h>
-#include <stdio.h>
-#include <string.h>
-#include <assert.h>
+#include <bsp.h>
-#include <rtems.h>
-#include <rtems/rtems_bsdnet.h>
-#include <rtems/rtems_mii_ioctl.h>
+#if defined(LIBBSP_ARM_LPC24XX_BSP_H) || defined(LIBBSP_ARM_LPC32XX_BSP_H)
#include <sys/param.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/mbuf.h>
+#include <sys/module.h>
#include <sys/socket.h>
#include <sys/sockio.h>
-#include <sys/mbuf.h>
+#include <sys/bus.h>
+#include <machine/bus.h>
#include <net/if.h>
+#include <net/ethernet.h>
#include <net/if_arp.h>
-#include <netinet/in.h>
-#include <netinet/if_ether.h>
-#include <netinet/in_systm.h>
-#include <netinet/ip.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <dev/mii/mii.h>
+#include <rtems/bsd/bsd.h>
#include <bsp.h>
#include <bsp/irq.h>
@@ -128,6 +132,10 @@ typedef struct {
uint32_t powerdown;
} lpc_eth_controller;
+#define LPE_LOCK(e) mtx_lock(&(e)->mtx)
+#define LPE_UNLOCK(e) mtx_unlock(&(e)->mtx)
static volatile lpc_eth_controller *const lpc_eth =
(volatile lpc_eth_controller *) LPC_ETH_CONFIG_REG_BASE;
@@ -300,10 +308,12 @@ typedef enum {
} lpc_eth_state;
typedef struct {
- struct arpcom arpcom;
+ device_t dev;
+ struct ifnet *ifp;
+ struct mtx mtx;
lpc_eth_state state;
- struct rtems_mdio_info mdio;
uint32_t anlpar;
+ struct callout watchdog_callout;
rtems_id receive_task;
rtems_id transmit_task;
unsigned rx_unit_count;
@@ -338,14 +348,18 @@ typedef struct {
int phy;
rtems_vector_number interrupt_number;
rtems_id control_task;
+ int if_flags;
+ struct ifmedia ifmedia;
} lpc_eth_driver_entry;
-static lpc_eth_driver_entry lpc_eth_driver_data;
+static void lpc_eth_interface_watchdog(void *arg);
+static void lpc_eth_setup_rxfilter(lpc_eth_driver_entry *e);
static void lpc_eth_control_request_complete(const lpc_eth_driver_entry *e)
rtems_status_code sc = rtems_event_transient_send(e->control_task);
- assert(sc == RTEMS_SUCCESSFUL);
+ BSD_ASSERT(sc == RTEMS_SUCCESSFUL);
static void lpc_eth_control_request(
@@ -355,17 +369,14 @@ static void lpc_eth_control_request(
rtems_status_code sc = RTEMS_SUCCESSFUL;
- uint32_t nest_count = 0;
e->control_task = rtems_task_self();
- sc = rtems_bsdnet_event_send(task, event);
+ sc = rtems_event_send(task, event);
- nest_count = rtems_bsdnet_semaphore_release_recursive();
sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
- rtems_bsdnet_semaphore_obtain_recursive(nest_count);
e->control_task = 0;
@@ -418,7 +429,7 @@ static void lpc_eth_interrupt_handler(void *arg)
/* Send events to receive task */
if (re != 0) {
++e->receive_interrupts;
- (void) rtems_bsdnet_event_send(e->receive_task, re);
+ (void) rtems_event_send(e->receive_task, re);
/* Check transmit interrupts */
@@ -433,7 +444,7 @@ static void lpc_eth_interrupt_handler(void *arg)
/* Send events to transmit task */
if (te != 0) {
++e->transmit_interrupts;
- (void) rtems_bsdnet_event_send(e->transmit_task, te);
+ (void) rtems_event_send(e->transmit_task, te);
LPC_ETH_PRINTK("interrupt: rx = 0x%08x, tx = 0x%08x\n", re, te);
@@ -486,7 +497,7 @@ static void lpc_eth_disable_transmit_interrupts(void)
static struct mbuf *lpc_eth_new_mbuf(struct ifnet *ifp, bool wait)
struct mbuf *m = NULL;
- int mw = wait ? M_WAIT : M_DONTWAIT;
+ int mw = wait ? M_WAITOK : M_NOWAIT;
MGETHDR(m, mw, MT_DATA);
if (m != NULL) {
@@ -546,12 +557,12 @@ static bool lpc_eth_add_new_mbuf(
-static void lpc_eth_receive_task(void *arg)
+static void lpc_eth_receive_task(rtems_task_argument arg)
rtems_event_set events = 0;
lpc_eth_driver_entry *const e = (lpc_eth_driver_entry *) arg;
- struct ifnet *const ifp = &e->arpcom.ac_if;
+ struct ifnet *const ifp = e->ifp;
volatile lpc_eth_transfer_descriptor *const desc = e->rx_desc_table;
volatile lpc_eth_receive_status *const status = e->rx_status_table;
struct mbuf **const mbufs = e->rx_mbuf_table;
@@ -564,7 +575,7 @@ static void lpc_eth_receive_task(void *arg)
/* Main event loop */
while (true) {
/* Wait for events */
- sc = rtems_bsdnet_event_receive(
+ sc = rtems_event_receive(
LPC_ETH_EVENT_INITIALIZE
| LPC_ETH_EVENT_STOP
| LPC_ETH_EVENT_INTERRUPT,
@@ -572,7 +583,7 @@ static void lpc_eth_receive_task(void *arg)
RTEMS_NO_TIMEOUT,
&events
LPC_ETH_PRINTF("rx: wake up: 0x%08" PRIx32 "\n", events);
@@ -667,22 +678,17 @@ static void lpc_eth_receive_task(void *arg)
struct mbuf *m = mbufs [consume_index];
if (lpc_eth_add_new_mbuf(ifp, desc, mbufs, consume_index, false)) {
- /* Ethernet header */
- struct ether_header *eh = mtod(m, struct ether_header *);
- /* Discard Ethernet header and CRC */
- int sz = (int) (stat & ETH_RX_STAT_RXSIZE_MASK) + 1
- - ETHER_HDR_LEN - ETHER_CRC_LEN;
+ /* Discard Ethernet CRC */
+ int sz = (int) (stat & ETH_RX_STAT_RXSIZE_MASK) + 1 - ETHER_CRC_LEN;
/* Update mbuf */
m->m_len = sz;
m->m_pkthdr.len = sz;
- m->m_data = mtod(m, char *) + ETHER_HDR_LEN;
LPC_ETH_PRINTF("rx: %02" PRIu32 ": %u\n", consume_index, sz);
/* Hand over */
- ether_input(ifp, eh, m);
+ (*ifp->if_input)(ifp, m);
/* Increment received frames counter */
++e->received_frames;
@@ -776,12 +782,12 @@ static struct mbuf *lpc_eth_next_fragment(
return m;
-static void lpc_eth_transmit_task(void *arg)
+static void lpc_eth_transmit_task(rtems_task_argument arg)
lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) arg;
- struct ifnet *ifp = &e->arpcom.ac_if;
+ struct ifnet *ifp = e->ifp;
volatile lpc_eth_transfer_descriptor *const desc = e->tx_desc_table;
volatile uint32_t *const status = e->tx_status_table;
#ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
@@ -812,7 +818,7 @@ static void lpc_eth_transmit_task(void *arg)
while (true) {
| LPC_ETH_EVENT_STOP
| LPC_ETH_EVENT_TXSTART
@@ -821,7 +827,7 @@ static void lpc_eth_transmit_task(void *arg)
RTEMS_NO_TIMEOUT,
&events
LPC_ETH_PRINTF("tx: wake up: 0x%08" PRIx32 "\n", events);
@@ -1030,7 +1036,7 @@ static void lpc_eth_transmit_task(void *arg)
/* Cache flush of data */
rtems_cache_flush_multiple_data_lines(
(const void *) desc [produce_index].start,
- new_frame_length
+ new_frame_length
/* Cache flush of descriptor */
@@ -1071,7 +1077,7 @@ static void lpc_eth_transmit_task(void *arg)
/* No more fragments? */
if (m == NULL) {
/* Interface is now inactive */
- ifp->if_flags &= ~IFF_OACTIVE;
+ ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
} else {
LPC_ETH_PRINTF("tx: enable interrupts\n");
@@ -1358,9 +1364,10 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
int eno = 0;
if (up && e->state == LPC_ETH_STATE_DOWN) {
+ ifp->if_drv_flags |= IFF_DRV_RUNNING;
lpc_eth_config_module_enable();
@@ -1376,6 +1383,8 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
eno = lpc_eth_phy_up(e);
if (eno == 0) {
+ const uint8_t *eaddr;
* We must have a valid external clock from the PHY at this point,
* otherwise the system bus hangs and only a watchdog reset helps.
@@ -1400,12 +1409,12 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
lpc_eth->powerdown = 0;
/* MAC address */
- lpc_eth->sa0 = ((uint32_t) e->arpcom.ac_enaddr [5] << 8)
- | (uint32_t) e->arpcom.ac_enaddr [4];
- lpc_eth->sa1 = ((uint32_t) e->arpcom.ac_enaddr [3] << 8)
- | (uint32_t) e->arpcom.ac_enaddr [2];
- lpc_eth->sa2 = ((uint32_t) e->arpcom.ac_enaddr [1] << 8)
- | (uint32_t) e->arpcom.ac_enaddr [0];
+ eaddr = IF_LLADDR(e->ifp);
+ lpc_eth->sa0 = ((uint32_t) eaddr [5] << 8) | (uint32_t) eaddr [4];
+ lpc_eth->sa1 = ((uint32_t) eaddr [3] << 8) | (uint32_t) eaddr [2];
+ lpc_eth->sa2 = ((uint32_t) eaddr [1] << 8) | (uint32_t) eaddr [0];
+ lpc_eth_setup_rxfilter(e);
/* Enable receiver */
lpc_eth->mac1 = 0x03;
@@ -1422,10 +1431,10 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
lpc_eth_interrupt_handler,
/* Start watchdog timer */
- ifp->if_timer = 1;
+ callout_reset(&e->watchdog_callout, hz, lpc_eth_interface_watchdog, e);
/* Change state */
e->state = LPC_ETH_STATE_UP;
@@ -1435,13 +1444,15 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
ifp->if_flags &= ~IFF_UP;
} else if (!up && e->state == LPC_ETH_STATE_UP) {
+ ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
/* Remove interrupt handler */
sc = rtems_interrupt_handler_remove(
e->interrupt_number,
/* Stop tasks */
lpc_eth_control_request(e, e->receive_task, LPC_ETH_EVENT_STOP);
@@ -1452,7 +1463,7 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
lpc_eth_config_module_disable();
/* Stop watchdog timer */
- ifp->if_timer = 0;
+ callout_stop(&e->watchdog_callout);
/* Change state */
e->state = LPC_ETH_STATE_DOWN;
@@ -1466,94 +1477,44 @@ static void lpc_eth_interface_init(void *arg)
/* Nothing to do */
-static void lpc_eth_interface_stats(lpc_eth_driver_entry *e)
- int eno = EIO;
- int media = 0;
- if (e->state == LPC_ETH_STATE_UP) {
- media = IFM_MAKEWORD(0, 0, 0, 0);
- eno = rtems_mii_ioctl(&e->mdio, e, SIOCGIFMEDIA, &media);
- rtems_bsdnet_semaphore_release();
- if (eno == 0) {
- rtems_ifmedia2str(media, NULL, 0);
- printf("\n");
- printf("received frames: %u\n", e->received_frames);
- printf("receive interrupts: %u\n", e->receive_interrupts);
- printf("transmitted frames: %u\n", e->transmitted_frames);
- printf("transmit interrupts: %u\n", e->transmit_interrupts);
- printf("receive drop errors: %u\n", e->receive_drop_errors);
- printf("receive overrun errors: %u\n", e->receive_overrun_errors);
- printf("receive fragment errors: %u\n", e->receive_fragment_errors);
- printf("receive CRC errors: %u\n", e->receive_crc_errors);
- printf("receive symbol errors: %u\n", e->receive_symbol_errors);
- printf("receive length errors: %u\n", e->receive_length_errors);
- printf("receive alignment errors: %u\n", e->receive_alignment_errors);
- printf("receive no descriptor errors: %u\n", e->receive_no_descriptor_errors);
- printf("receive fatal errors: %u\n", e->receive_fatal_errors);
- printf("transmit underrun errors: %u\n", e->transmit_underrun_errors);
- printf("transmit late collision errors: %u\n", e->transmit_late_collision_errors);
- printf("transmit excessive collision errors: %u\n", e->transmit_excessive_collision_errors);
- printf("transmit excessive defer errors: %u\n", e->transmit_excessive_defer_errors);
- printf("transmit no descriptor errors: %u\n", e->transmit_no_descriptor_errors);
- printf("transmit overflow errors: %u\n", e->transmit_overflow_errors);
- printf("transmit fatal errors: %u\n", e->transmit_fatal_errors);
- rtems_bsdnet_semaphore_obtain();
+ lpc_eth_enable_promiscous_mode((ifp->if_flags & IFF_PROMISC) != 0);
-static int lpc_eth_multicast_control(
- bool add,
- struct ifreq *ifr,
- struct arpcom *ac
- int eno = 0;
- if (add) {
- eno = ether_addmulti(ifr, ac);
+ if ((ifp->if_flags & IFF_ALLMULTI)) {
+ lpc_eth->hashfilterl = 0xffffffff;
+ lpc_eth->hashfilterh = 0xffffffff;
} else {
- eno = ether_delmulti(ifr, ac);
- if (eno == ENETRESET) {
- struct ether_multistep step;
- struct ether_multi *enm;
+ struct ifmultiaddr *ifma;
- eno = 0;
+ lpc_eth->hashfilterl = 0x0;
+ lpc_eth->hashfilterh = 0x0;
- lpc_eth->hashfilterl = 0;
- lpc_eth->hashfilterh = 0;
+ if_maddr_rlock(ifp);
+ CK_STAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
+ uint32_t crc;
+ uint32_t index;
- ETHER_FIRST_MULTI(step, ac, enm);
- while (enm != NULL) {
- uint64_t addrlo = 0;
- uint64_t addrhi = 0;
+ if (ifma->ifma_addr->sa_family != AF_LINK)
+ continue;
- memcpy(&addrlo, enm->enm_addrlo, ETHER_ADDR_LEN);
- memcpy(&addrhi, enm->enm_addrhi, ETHER_ADDR_LEN);
- while (addrlo <= addrhi) {
- /* XXX: ether_crc32_le() does not work, why? */
- uint32_t crc = ether_crc32_be((uint8_t *) &addrlo, ETHER_ADDR_LEN);
- uint32_t index = (crc >> 23) & 0x3f;
+ /* XXX: ether_crc32_le() does not work, why? */
+ crc = ether_crc32_be(
+ LLADDR((struct sockaddr_dl *) ifma->ifma_addr),
+ ETHER_ADDR_LEN
+ index = (crc >> 23) & 0x3f;
- if (index < 32) {
- lpc_eth->hashfilterl |= 1U << index;
- } else {
- lpc_eth->hashfilterh |= 1U << (index - 32);
- ++addrlo;
+ if (index < 32) {
+ lpc_eth->hashfilterl |= 1U << index;
+ } else {
+ lpc_eth->hashfilterh |= 1U << (index - 32);
- ETHER_NEXT_MULTI(step, enm);
+ if_maddr_runlock(ifp);
- return eno;
static int lpc_eth_interface_ioctl(
@@ -1571,27 +1532,40 @@ static int lpc_eth_interface_ioctl(
switch (cmd) {
case SIOCGIFMEDIA:
case SIOCSIFMEDIA:
- rtems_mii_ioctl(&e->mdio, e, cmd, &ifr->ifr_media);
+ eno = ifmedia_ioctl(ifp, ifr, &e->ifmedia, cmd);
break;
case SIOCGIFADDR:
case SIOCSIFADDR:
ether_ioctl(ifp, cmd, data);
break;
case SIOCSIFFLAGS:
- eno = lpc_eth_up_or_down(e, (ifp->if_flags & IFF_UP) != 0);
- if (eno == 0 && (ifp->if_flags & IFF_UP) != 0) {
- lpc_eth_enable_promiscous_mode((ifp->if_flags & IFF_PROMISC) != 0);
+ LPE_LOCK(e);
+ if (ifp->if_flags & IFF_UP) {
+ if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+ if ((ifp->if_flags ^ e->if_flags) & (IFF_PROMISC | IFF_ALLMULTI)) {
+ } else {
+ eno = lpc_eth_up_or_down(e, true);
+ } else {
+ eno = lpc_eth_up_or_down(e, false);
+ e->if_flags = ifp->if_flags;
+ LPE_UNLOCK(e);
break;
case SIOCADDMULTI:
case SIOCDELMULTI:
- eno = lpc_eth_multicast_control(cmd == SIOCADDMULTI, ifr, &e->arpcom);
- break;
- case SIO_RTEMS_SHOW_STATS:
- lpc_eth_interface_stats(e);
+ LPE_LOCK(e);
+ LPE_UNLOCK(e);
break;
default:
- eno = EINVAL;
+ eno = ether_ioctl(ifp, cmd, data);
break;
@@ -1603,17 +1577,17 @@ static void lpc_eth_interface_start(struct ifnet *ifp)
lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) ifp->if_softc;
- ifp->if_flags |= IFF_OACTIVE;
+ ifp->if_drv_flags |= IFF_DRV_OACTIVE;
- sc = rtems_bsdnet_event_send(e->transmit_task, LPC_ETH_EVENT_TXSTART);
+ sc = rtems_event_send(e->transmit_task, LPC_ETH_EVENT_TXSTART);
-static void lpc_eth_interface_watchdog(struct ifnet *ifp)
- lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) ifp->if_softc;
+ lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) arg;
uint32_t anlpar = lpc_eth_mdio_read_anlpar(e->phy);
@@ -1648,79 +1622,77 @@ static void lpc_eth_interface_watchdog(struct ifnet *ifp)
- ifp->if_timer = WATCHDOG_TIMEOUT;
+ callout_reset(&e->watchdog_callout, WATCHDOG_TIMEOUT * hz, lpc_eth_interface_watchdog, e);
-static unsigned lpc_eth_fixup_unit_count(int count, int default_value, int max)
+static int lpc_eth_media_change(struct ifnet *ifp)
- if (count <= 0) {
- count = default_value;
- } else if (count > max) {
- count = max;
+ (void) ifp;
+ return EINVAL;
+static void lpc_eth_media_status(struct ifnet *ifp, struct ifmediareq *imr)
+ (void) ifp;
+ imr->ifm_status = IFM_AVALID | IFM_ACTIVE;
+ imr->ifm_active = IFM_ETHER;
+ if ((lpc_eth->supp & ETH_SUPP_SPEED) != 0) {
+ imr->ifm_active |= IFM_100_TX;
+ } else {
+ imr->ifm_active |= IFM_10_T;
- return LPC_ETH_CONFIG_UNIT_MULTIPLE
- + (((unsigned) count - 1U) & ~(LPC_ETH_CONFIG_UNIT_MULTIPLE - 1U));
+ if ((lpc_eth->mac2 & ETH_MAC2_FULL_DUPLEX) != 0) {
+ imr->ifm_active |= IFM_FDX;
+ } else {
+ imr->ifm_active |= IFM_HDX;
-static int lpc_eth_attach(struct rtems_bsdnet_ifconfig *config)
+int lpc_eth_probe(device_t dev)
- lpc_eth_driver_entry *e = &lpc_eth_driver_data;
+ int unit = device_get_unit(dev);
+ if (unit != 0) {
+ return ENXIO;
+ return 0;
+static int lpc_eth_attach(device_t dev)
+ lpc_eth_driver_entry *e = device_get_softc(dev);
+ struct ifnet *ifp = NULL;
char *unit_name = NULL;
- int unit_index = rtems_bsdnet_parse_driver_name(config, &unit_name);
+ int unit_index = device_get_unit(dev);
size_t table_area_size = 0;
char *table_area = NULL;
char *table_location = NULL;
+ rtems_status_code status;
+ uint8_t eaddr[ETHER_ADDR_LEN];
- /* Check parameter */
- if (unit_index < 0) {
- return 0;
- if (unit_index != 0) {
- goto cleanup;
- if (config->hardware_address == NULL) {
- goto cleanup;
- if (e->state != LPC_ETH_STATE_NOT_INITIALIZED) {
- goto cleanup;
+ BSD_ASSERT(e->state == LPC_ETH_STATE_NOT_INITIALIZED);
- /* MDIO */
- e->mdio.mdio_r = lpc_eth_mdio_read;
- e->mdio.mdio_w = lpc_eth_mdio_write;
- e->mdio.has_gmii = 0;
- e->anlpar = 0;
+ mtx_init(&e->mtx, device_get_nameunit(e->dev), MTX_NETWORK_LOCK, MTX_DEF);
- /* Interrupt number */
- config->irno = LPC_ETH_CONFIG_INTERRUPT;
+ ifmedia_init(&e->ifmedia, 0, lpc_eth_media_change, lpc_eth_media_status);
+ ifmedia_add(&e->ifmedia, IFM_ETHER | IFM_AUTO, 0, NULL);
+ ifmedia_set(&e->ifmedia, IFM_ETHER | IFM_AUTO);
- /* Device control */
- config->drv_ctrl = e;
+ callout_init_mtx(&e->watchdog_callout, &e->mtx, 0);
/* Receive unit count */
- e->rx_unit_count = lpc_eth_fixup_unit_count(
- config->rbuf_count,
- LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT,
- LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX
- config->rbuf_count = (int) e->rx_unit_count;
+ e->rx_unit_count = LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT;
/* Transmit unit count */
- e->tx_unit_count = lpc_eth_fixup_unit_count(
- config->xbuf_count,
- LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT,
- LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX
- config->xbuf_count = (int) e->tx_unit_count;
+ e->tx_unit_count = LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT;
/* Remember interrupt number */
- e->interrupt_number = config->irno;
- /* Copy MAC address */
- memcpy(e->arpcom.ac_enaddr, config->hardware_address, ETHER_ADDR_LEN);
+ e->interrupt_number = LPC_ETH_CONFIG_INTERRUPT;
/* Allocate and clear table area */
table_area_size =
@@ -1734,7 +1706,7 @@ static int lpc_eth_attach(struct rtems_bsdnet_ifconfig *config)
+ LPC_ETH_CONFIG_TX_BUF_SIZE);
table_area = lpc_eth_config_alloc_table_area(table_area_size);
if (table_area == NULL) {
- goto cleanup;
+ return ENOMEM;
memset(table_area, 0, table_area_size);
@@ -1762,56 +1734,66 @@ static int lpc_eth_attach(struct rtems_bsdnet_ifconfig *config)
e->tx_buf_table = table_location;
/* Set interface data */
+ e->dev = dev;
+ e->ifp = ifp = if_alloc(IFT_ETHER);
ifp->if_softc = e;
- ifp->if_unit = (short) unit_index;
- ifp->if_name = unit_name;
- ifp->if_mtu = (config->mtu > 0) ? (u_long) config->mtu : ETHERMTU;
+ if_initname(ifp, device_get_name(dev), device_get_unit(dev));
ifp->if_init = lpc_eth_interface_init;
ifp->if_ioctl = lpc_eth_interface_ioctl;
ifp->if_start = lpc_eth_interface_start;
- ifp->if_output = ether_output;
- ifp->if_watchdog = lpc_eth_interface_watchdog;
- ifp->if_flags = IFF_MULTICAST | IFF_BROADCAST | IFF_SIMPLEX;
- ifp->if_snd.ifq_maxlen = ifqmaxlen;
+ ifp->if_qflush = if_qflush;
+ ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
+ IFQ_SET_MAXLEN(&ifp->if_snd, LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX - 1);
+ ifp->if_snd.ifq_drv_maxlen = LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX - 1;
+ IFQ_SET_READY(&ifp->if_snd);
+ ifp->if_hdrlen = sizeof(struct ether_header);
+ rtems_bsd_get_mac_address(device_get_name(e->dev), unit_index, eaddr);
/* Create tasks */
- e->receive_task = rtems_bsdnet_newproc(
- "ntrx",
+ status = rtems_task_create(
+ rtems_build_name('n', 't', 'r', 'x'),
+ rtems_bsd_get_task_priority(device_get_name(e->dev)),
4096,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &e->receive_task
+ BSD_ASSERT(status == RTEMS_SUCCESSFUL);
+ status = rtems_task_start(
+ e->receive_task,
lpc_eth_receive_task,
- e
+ (rtems_task_argument)e
- e->transmit_task = rtems_bsdnet_newproc(
- "nttx",
+ rtems_build_name('n', 't', 't', 'x'),
4096,
+ &e->transmit_task
+ e->transmit_task,
lpc_eth_transmit_task,
- e
+ if_link_state_change(e->ifp, LINK_STATE_UP);
/* Change status */
- ifp->if_flags |= IFF_RUNNING;
/* Attach the interface */
- if_attach(ifp);
- ether_ifattach(ifp);
- return 1;
-cleanup:
- lpc_eth_config_free_table_area(table_area);
- /* FIXME: Type */
- free(unit_name, (int) 0xdeadbeef);
+ ether_ifattach(ifp, eaddr);
return 0;
-static int lpc_eth_detach(
- struct rtems_bsdnet_ifconfig *config RTEMS_UNUSED
+static int lpc_eth_detach(device_t dev)
/* FIXME: Detach the interface from the upper layers? */
@@ -1821,19 +1803,25 @@ static int lpc_eth_detach(
/* FIXME: More cleanup */
- return 0;
+ return ENXIO;
-int lpc_eth_attach_detach(
- struct rtems_bsdnet_ifconfig *config,
- int attaching
- /* FIXME: Return value */
+static device_method_t lpe_methods[] = {
+ DEVMETHOD(device_probe, lpc_eth_probe),
+ DEVMETHOD(device_attach, lpc_eth_attach),
+ DEVMETHOD(device_detach, lpc_eth_detach),
+ DEVMETHOD_END
- if (attaching) {
- return lpc_eth_attach(config);
- } else {
- return lpc_eth_detach(config);
+static driver_t lpe_nexus_driver = {
+ "lpe",
+ lpe_methods,
+ sizeof(lpc_eth_driver_entry)
+static devclass_t lpe_devclass;
+DRIVER_MODULE(lpe, nexus, lpe_nexus_driver, lpe_devclass, 0, 0);
+MODULE_DEPEND(lpe, nexus, 1, 1, 1);
+MODULE_DEPEND(lpe, ether, 1, 1, 1);
+#endif /* LIBBSP_ARM_LPC24XX_BSP_H || LIBBSP_ARM_LPC32XX_BSP_H */
2.35.3
