[libbsd 1/4] if_lpe.c: Import legacy LPC Ethernet driver
Sebastian Huber
Thu Jun 23 09:20:17 UTC 2022
The standard FreeBSD MII support causes severe problems on the LPC3200
chip family. If an Ethernet module register is accessed while there is
no clock from the PHY, the chip completely locks up and only an external
watchdog can recover from this state. The legacy driver had a custom
PHY management code which helped to avoid such issues. The if_lpe.c
driver is no longer maintained by FreeBSD.
libbsd.py | 1 -
rtemsbsd/sys/arm/lpc/if_lpe.c | 2953 +++++++++++++++++-------------
rtemsbsd/sys/arm/lpc/if_lpereg.h | 210 ---
3 files changed, 1682 insertions(+), 1482 deletions(-)
delete mode 100644 rtemsbsd/sys/arm/lpc/if_lpereg.h
diff --git a/libbsd.py b/libbsd.py
index 983f41a1..de22eaa9 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -235,7 +235,6 @@ class rtems(builder.Module):
'rtems/rtems-legacy-rtrequest.c',
'rtems/rtems-legacy-newproc.c',
'rtems/rtems-legacy-mii.c',
- 'sys/arm/lpc/if_lpe.c',
'sys/arm/lpc/lpc_pwr.c',
'sys/dev/atsam/if_atsam.c',
'sys/dev/atsam/if_atsam_media.c',
diff --git a/rtemsbsd/sys/arm/lpc/if_lpe.c b/rtemsbsd/sys/arm/lpc/if_lpe.c
index 40ac162e..ccfe1696 100755
--- a/rtemsbsd/sys/arm/lpc/if_lpe.c
+++ b/rtemsbsd/sys/arm/lpc/if_lpe.c
@@ -1,1428 +1,1839 @@
-#include <machine/rtems-bsd-kernel-space.h>
- * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * @file
- * Copyright (c) 2011 Jakub Wojciech Klama <jceel at FreeBSD.org>
- * All rights reserved.
+ * @ingroup lpc_eth
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
+ * @brief Ethernet driver.
+ * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
-#include <sys/cdefs.h>
-__FBSDID("$FreeBSD$");
+#include <machine/rtems-bsd-kernel-space.h>
+#include <errno.h>
+#include <inttypes.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <assert.h>
+#include <rtems.h>
+#include <rtems/rtems_bsdnet.h>
+#include <rtems/rtems_mii_ioctl.h>
#include <sys/param.h>
-#include <sys/endian.h>
-#include <sys/systm.h>
+#include <sys/socket.h>
#include <sys/sockio.h>
#include <sys/mbuf.h>
-#include <sys/malloc.h>
-#include <sys/kernel.h>
-#include <sys/module.h>
-#include <sys/lock.h>
-#include <sys/mutex.h>
-#include <sys/rman.h>
-#include <sys/bus.h>
-#include <sys/socket.h>
-#include <machine/bus.h>
-#ifndef __rtems__
-#include <machine/intr.h>
-#endif /* __rtems__ */
#include <net/if.h>
#include <net/if_arp.h>
-#include <net/ethernet.h>
-#include <net/if_dl.h>
-#include <net/if_media.h>
-#include <net/if_types.h>
-#include <net/if_var.h>
+#include <netinet/in.h>
+#include <netinet/if_ether.h>
+#include <netinet/in_systm.h>
+#include <netinet/ip.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <bsp/lpc-ethernet-config.h>
+#include <bsp/utility.h>
+#if MCLBYTES > (2 * 1024)
+ #error "MCLBYTES to large"
+#endif
-#include <net/bpf.h>
+#ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
+ #define LPC_ETH_CONFIG_TX_BUF_SIZE sizeof(struct mbuf *)
+#else
+ #define LPC_ETH_CONFIG_TX_BUF_SIZE 1518U
+#endif
-#ifndef __rtems__
-#include <dev/ofw/ofw_bus.h>
-#include <dev/ofw/ofw_bus_subr.h>
+#define DEFAULT_PHY 0
+#define WATCHDOG_TIMEOUT 5
+typedef struct {
+ uint32_t start;
+ uint32_t control;
+} lpc_eth_transfer_descriptor;
+typedef struct {
+ uint32_t info;
+ uint32_t hash_crc;
+} lpc_eth_receive_status;
+typedef struct {
+ uint32_t mac1;
+ uint32_t mac2;
+ uint32_t ipgt;
+ uint32_t ipgr;
+ uint32_t clrt;
+ uint32_t maxf;
+ uint32_t supp;
+ uint32_t test;
+ uint32_t mcfg;
+ uint32_t mcmd;
+ uint32_t madr;
+ uint32_t mwtd;
+ uint32_t mrdd;
+ uint32_t mind;
+ uint32_t reserved_0 [2];
+ uint32_t sa0;
+ uint32_t sa1;
+ uint32_t sa2;
+ uint32_t reserved_1 [45];
+ uint32_t command;
+ uint32_t status;
+ uint32_t rxdescriptor;
+ uint32_t rxstatus;
+ uint32_t rxdescriptornum;
+ uint32_t rxproduceindex;
+ uint32_t rxconsumeindex;
+ uint32_t txdescriptor;
+ uint32_t txstatus;
+ uint32_t txdescriptornum;
+ uint32_t txproduceindex;
+ uint32_t txconsumeindex;
+ uint32_t reserved_2 [10];
+ uint32_t tsv0;
+ uint32_t tsv1;
+ uint32_t rsv;
+ uint32_t reserved_3 [3];
+ uint32_t flowcontrolcnt;
+ uint32_t flowcontrolsts;
+ uint32_t reserved_4 [34];
+ uint32_t rxfilterctrl;
+ uint32_t rxfilterwolsts;
+ uint32_t rxfilterwolclr;
+ uint32_t reserved_5 [1];
+ uint32_t hashfilterl;
+ uint32_t hashfilterh;
+ uint32_t reserved_6 [882];
+ uint32_t intstatus;
+ uint32_t intenable;
+ uint32_t intclear;
+ uint32_t intset;
+ uint32_t reserved_7 [1];
+ uint32_t powerdown;
+} lpc_eth_controller;
+static volatile lpc_eth_controller *const lpc_eth =
+ (volatile lpc_eth_controller *) LPC_ETH_CONFIG_REG_BASE;
+/* ETH_RX_CTRL */
+#define ETH_RX_CTRL_SIZE_MASK 0x000007ffU
+#define ETH_RX_CTRL_INTERRUPT 0x80000000U
+/* ETH_RX_STAT */
+#define ETH_RX_STAT_RXSIZE_MASK 0x000007ffU
+#define ETH_RX_STAT_BYTES 0x00000100U
+#define ETH_RX_STAT_CONTROL_FRAME 0x00040000U
+#define ETH_RX_STAT_VLAN 0x00080000U
+#define ETH_RX_STAT_FAIL_FILTER 0x00100000U
+#define ETH_RX_STAT_MULTICAST 0x00200000U
+#define ETH_RX_STAT_BROADCAST 0x00400000U
+#define ETH_RX_STAT_CRC_ERROR 0x00800000U
+#define ETH_RX_STAT_SYMBOL_ERROR 0x01000000U
+#define ETH_RX_STAT_LENGTH_ERROR 0x02000000U
+#define ETH_RX_STAT_RANGE_ERROR 0x04000000U
+#define ETH_RX_STAT_ALIGNMENT_ERROR 0x08000000U
+#define ETH_RX_STAT_OVERRUN 0x10000000U
+#define ETH_RX_STAT_NO_DESCRIPTOR 0x20000000U
+#define ETH_RX_STAT_LAST_FLAG 0x40000000U
+#define ETH_RX_STAT_ERROR 0x80000000U
+/* ETH_TX_CTRL */
+#define ETH_TX_CTRL_SIZE_MASK 0x7ffU
+#define ETH_TX_CTRL_SIZE_SHIFT 0
+#define ETH_TX_CTRL_OVERRIDE 0x04000000U
+#define ETH_TX_CTRL_HUGE 0x08000000U
+#define ETH_TX_CTRL_PAD 0x10000000U
+#define ETH_TX_CTRL_CRC 0x20000000U
+#define ETH_TX_CTRL_LAST 0x40000000U
+#define ETH_TX_CTRL_INTERRUPT 0x80000000U
+/* ETH_TX_STAT */
+#define ETH_TX_STAT_COLLISION_COUNT_MASK 0x01e00000U
+#define ETH_TX_STAT_DEFER 0x02000000U
+#define ETH_TX_STAT_EXCESSIVE_DEFER 0x04000000U
+#define ETH_TX_STAT_EXCESSIVE_COLLISION 0x08000000U
+#define ETH_TX_STAT_LATE_COLLISION 0x10000000U
+#define ETH_TX_STAT_UNDERRUN 0x20000000U
+#define ETH_TX_STAT_NO_DESCRIPTOR 0x40000000U
+#define ETH_TX_STAT_ERROR 0x80000000U
+/* ETH_INT */
+#define ETH_INT_RX_OVERRUN 0x00000001U
+#define ETH_INT_RX_ERROR 0x00000002U
+#define ETH_INT_RX_FINISHED 0x00000004U
+#define ETH_INT_RX_DONE 0x00000008U
+#define ETH_INT_TX_UNDERRUN 0x00000010U
+#define ETH_INT_TX_ERROR 0x00000020U
+#define ETH_INT_TX_FINISHED 0x00000040U
+#define ETH_INT_TX_DONE 0x00000080U
+#define ETH_INT_SOFT 0x00001000U
+#define ETH_INT_WAKEUP 0x00002000U
+/* ETH_RX_FIL_CTRL */
+#define ETH_RX_FIL_CTRL_ACCEPT_UNICAST 0x00000001U
+#define ETH_RX_FIL_CTRL_ACCEPT_BROADCAST 0x00000002U
+#define ETH_RX_FIL_CTRL_ACCEPT_MULTICAST 0x00000004U
+#define ETH_RX_FIL_CTRL_ACCEPT_UNICAST_HASH 0x00000008U
+#define ETH_RX_FIL_CTRL_ACCEPT_MULTICAST_HASH 0x00000010U
+#define ETH_RX_FIL_CTRL_ACCEPT_PERFECT 0x00000020U
+#define ETH_RX_FIL_CTRL_MAGIC_PACKET_WOL 0x00001000U
+#define ETH_RX_FIL_CTRL_RX_FILTER_WOL 0x00002000U
+/* ETH_CMD */
+#define ETH_CMD_RX_ENABLE 0x00000001U
+#define ETH_CMD_TX_ENABLE 0x00000002U
+#define ETH_CMD_REG_RESET 0x00000008U
+#define ETH_CMD_TX_RESET 0x00000010U
+#define ETH_CMD_RX_RESET 0x00000020U
+#define ETH_CMD_PASS_RUNT_FRAME 0x00000040U
+#define ETH_CMD_PASS_RX_FILTER 0X00000080U
+#define ETH_CMD_TX_FLOW_CONTROL 0x00000100U
+#define ETH_CMD_RMII 0x00000200U
+#define ETH_CMD_FULL_DUPLEX 0x00000400U
+/* ETH_STAT */
-#include <dev/mii/mii.h>
-#include <dev/mii/miivar.h>
+#define ETH_STAT_RX_ACTIVE 0x00000001U
+#define ETH_STAT_TX_ACTIVE 0x00000002U
-#include <arm/lpc/lpcreg.h>
-#include <arm/lpc/lpcvar.h>
-#include <arm/lpc/if_lpereg.h>
+/* ETH_MAC2 */
-#include <rtems/bsd/local/miibus_if.h>
-#ifdef __rtems__
-#include <machine/rtems-bsd-cache.h>
-#include <rtems/bsd/bsd.h>
+#define ETH_MAC2_FULL_DUPLEX BSP_BIT32(8)
-#ifdef DEBUG
-#define debugf(fmt, args...) do { printf("%s(): ", __func__); \
- printf(fmt,##args); } while (0)
-#else
-#endif
+/* ETH_SUPP */
-struct lpe_dmamap_arg {
- bus_addr_t lpe_dma_busaddr;
+#define ETH_SUPP_SPEED BSP_BIT32(8)
-struct lpe_rxdesc {
- struct mbuf * lpe_rxdesc_mbuf;
-#ifndef __rtems__
- bus_dmamap_t lpe_rxdesc_dmamap;
+/* ETH_MCFG */
-struct lpe_txdesc {
- int lpe_txdesc_first;
- struct mbuf * lpe_txdesc_mbuf;
-#ifndef __rtems__
- bus_dmamap_t lpe_txdesc_dmamap;
+#define ETH_MCFG_CLOCK_SELECT(val) BSP_FLD32(val, 2, 4)
-struct lpe_chain_data {
- bus_dma_tag_t lpe_parent_tag;
- bus_dma_tag_t lpe_tx_ring_tag;
- bus_dmamap_t lpe_tx_ring_map;
- bus_dma_tag_t lpe_tx_status_tag;
- bus_dmamap_t lpe_tx_status_map;
- bus_dma_tag_t lpe_tx_buf_tag;
- bus_dma_tag_t lpe_rx_ring_tag;
- bus_dmamap_t lpe_rx_ring_map;
- bus_dma_tag_t lpe_rx_status_tag;
- bus_dmamap_t lpe_rx_status_map;
- bus_dma_tag_t lpe_rx_buf_tag;
- struct lpe_rxdesc lpe_rx_desc[LPE_RXDESC_NUM];
- struct lpe_txdesc lpe_tx_desc[LPE_TXDESC_NUM];
- int lpe_tx_prod;
- int lpe_tx_last;
- int lpe_tx_used;
+#define ETH_MCFG_RESETMIIMGMT BSP_BIT32(15)
-struct lpe_ring_data {
- struct lpe_hwdesc * lpe_rx_ring;
- struct lpe_hwstatus * lpe_rx_status;
- bus_addr_t lpe_rx_ring_phys;
- bus_addr_t lpe_rx_status_phys;
- struct lpe_hwdesc * lpe_tx_ring;
- struct lpe_hwstatus * lpe_tx_status;
- bus_addr_t lpe_tx_ring_phys;
- bus_addr_t lpe_tx_status_phys;
+/* ETH_MCMD */
-struct lpe_softc {
- struct ifnet * lpe_ifp;
- struct mtx lpe_mtx;
-#ifndef __rtems__
- phandle_t lpe_ofw;
- device_t lpe_dev;
- device_t lpe_miibus;
- uint8_t lpe_enaddr[6];
- struct resource * lpe_mem_res;
- struct resource * lpe_irq_res;
- void * lpe_intrhand;
- bus_space_tag_t lpe_bst;
- bus_space_handle_t lpe_bsh;
-#define LPE_FLAG_LINK (1 << 0)
- uint32_t lpe_flags;
- int lpe_watchdog_timer;
- struct callout lpe_tick;
- struct lpe_chain_data lpe_cdata;
- struct lpe_ring_data lpe_rdata;
+#define ETH_MCMD_READ BSP_BIT32(0)
+#define ETH_MCMD_SCAN BSP_BIT32(1)
-static int lpe_probe(device_t);
-static int lpe_attach(device_t);
-static int lpe_detach(device_t);
-static int lpe_miibus_readreg(device_t, int, int);
-static int lpe_miibus_writereg(device_t, int, int, int);
-static void lpe_miibus_statchg(device_t);
-static void lpe_reset(struct lpe_softc *);
-static void lpe_init(void *);
-static void lpe_init_locked(struct lpe_softc *);
-static void lpe_start(struct ifnet *);
-static void lpe_start_locked(struct ifnet *);
-static void lpe_stop(struct lpe_softc *);
-static void lpe_stop_locked(struct lpe_softc *);
-static int lpe_ioctl(struct ifnet *, u_long, caddr_t);
-static void lpe_set_rxmode(struct lpe_softc *);
-static void lpe_set_rxfilter(struct lpe_softc *);
-static void lpe_intr(void *);
-static void lpe_rxintr(struct lpe_softc *);
-static void lpe_txintr(struct lpe_softc *);
-static void lpe_tick(void *);
-static void lpe_watchdog(struct lpe_softc *);
-static int lpe_encap(struct lpe_softc *, struct mbuf **);
-static int lpe_dma_alloc(struct lpe_softc *);
-static int lpe_dma_alloc_rx(struct lpe_softc *);
-static int lpe_dma_alloc_tx(struct lpe_softc *);
-static int lpe_init_rx(struct lpe_softc *);
-static int lpe_init_rxbuf(struct lpe_softc *, int);
-static void lpe_discard_rxbuf(struct lpe_softc *, int);
-static void lpe_dmamap_cb(void *, bus_dma_segment_t *, int, int);
-static int lpe_ifmedia_upd(struct ifnet *);
-static void lpe_ifmedia_sts(struct ifnet *, struct ifmediareq *);
-#define lpe_lock(_sc) mtx_lock(&(_sc)->lpe_mtx)
-#define lpe_unlock(_sc) mtx_unlock(&(_sc)->lpe_mtx)
-#define lpe_lock_assert(_sc) mtx_assert(&(_sc)->lpe_mtx, MA_OWNED)
-#define lpe_read_4(_sc, _reg) \
- bus_space_read_4((_sc)->lpe_bst, (_sc)->lpe_bsh, (_reg))
-#define lpe_write_4(_sc, _reg, _val) \
- bus_space_write_4((_sc)->lpe_bst, (_sc)->lpe_bsh, (_reg), (_val))
-#define LPE_HWDESC_RXERRS (LPE_HWDESC_CRCERROR | LPE_HWDESC_SYMBOLERROR | \
- LPE_HWDESC_LENGTHERROR | LPE_HWDESC_ALIGNERROR | LPE_HWDESC_OVERRUN | \
- LPE_HWDESC_RXNODESCR)
-#define LPE_HWDESC_TXERRS (LPE_HWDESC_EXCDEFER | LPE_HWDESC_EXCCOLL | \
- LPE_HWDESC_LATECOLL | LPE_HWDESC_UNDERRUN | LPE_HWDESC_TXNODESCR)
-static int
-lpe_probe(device_t dev)
+/* ETH_MADR */
-#ifndef __rtems__
- if (!ofw_bus_status_okay(dev))
- return (ENXIO);
+#define ETH_MADR_REG(val) BSP_FLD32(val, 0, 4)
+#define ETH_MADR_PHY(val) BSP_FLD32(val, 8, 12)
- if (!ofw_bus_is_compatible(dev, "lpc,ethernet"))
- return (ENXIO);
+/* ETH_MIND */
- device_set_desc(dev, "LPC32x0 10/100 Ethernet");
- return (BUS_PROBE_DEFAULT);
+#define ETH_MIND_BUSY BSP_BIT32(0)
+#define ETH_MIND_SCANNING BSP_BIT32(1)
+#define ETH_MIND_NOT_VALID BSP_BIT32(2)
+#define ETH_MIND_MII_LINK_FAIL BSP_BIT32(3)
-static int
-lpe_attach(device_t dev)
- struct lpe_softc *sc = device_get_softc(dev);
- struct ifnet *ifp;
-#ifndef __rtems__
- int rid, i;
- uint32_t val;
-#else /* __rtems__ */
- int rid;
- sc->lpe_dev = dev;
-#ifndef __rtems__
- sc->lpe_ofw = ofw_bus_get_node(dev);
- i = OF_getprop(sc->lpe_ofw, "local-mac-address", (void *)&sc->lpe_enaddr, 6);
- if (i != 6) {
- sc->lpe_enaddr[0] = 0x00;
- sc->lpe_enaddr[1] = 0x11;
- sc->lpe_enaddr[2] = 0x22;
- sc->lpe_enaddr[3] = 0x33;
- sc->lpe_enaddr[4] = 0x44;
- sc->lpe_enaddr[5] = 0x55;
- rtems_bsd_get_mac_address(device_get_name(sc->lpe_dev), device_get_unit(sc->lpe_dev), sc->lpe_enaddr);
- mtx_init(&sc->lpe_mtx, device_get_nameunit(dev), MTX_NETWORK_LOCK,
- MTX_DEF);
- callout_init_mtx(&sc->lpe_tick, &sc->lpe_mtx, 0);
- rid = 0;
- sc->lpe_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
- RF_ACTIVE);
- if (!sc->lpe_mem_res) {
- device_printf(dev, "cannot allocate memory window\n");
- goto fail;
- sc->lpe_bst = rman_get_bustag(sc->lpe_mem_res);
- sc->lpe_bsh = rman_get_bushandle(sc->lpe_mem_res);
- rid = 0;
- sc->lpe_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
- RF_ACTIVE);
- if (!sc->lpe_irq_res) {
- device_printf(dev, "cannot allocate interrupt\n");
- goto fail;
- sc->lpe_ifp = if_alloc(IFT_ETHER);
- if (!sc->lpe_ifp) {
- device_printf(dev, "cannot allocated ifnet\n");
- goto fail;
- ifp = sc->lpe_ifp;
- if_initname(ifp, device_get_name(dev), device_get_unit(dev));
- ifp->if_softc = sc;
- ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX | IFF_MULTICAST;
- ifp->if_start = lpe_start;
- ifp->if_ioctl = lpe_ioctl;
- ifp->if_init = lpe_init;
- IFQ_SET_MAXLEN(&ifp->if_snd, IFQ_MAXLEN);
- ifp->if_snd.ifq_drv_maxlen = IFQ_MAXLEN;
- IFQ_SET_READY(&ifp->if_snd);
- ether_ifattach(ifp, sc->lpe_enaddr);
- if (bus_setup_intr(dev, sc->lpe_irq_res, INTR_TYPE_NET, NULL,
- lpe_intr, sc, &sc->lpe_intrhand)) {
- device_printf(dev, "cannot establish interrupt handler\n");
- ether_ifdetach(ifp);
- goto fail;
- /* Enable Ethernet clock */
-#ifndef __rtems__
- lpc_pwr_write(dev, LPC_CLKPWR_MACCLK_CTRL,
- LPC_CLKPWR_MACCLK_CTRL_REG |
- LPC_CLKPWR_MACCLK_CTRL_SLAVE |
- LPC_CLKPWR_MACCLK_CTRL_MASTER |
- LPC_CLKPWR_MACCLK_CTRL_HDWINF(3));
-#ifdef LPC32XX_ETHERNET_RMII
-#else
- LPC_CLKPWR_MACCLK_CTRL_HDWINF(1));
-#endif
- /* Reset chip */
- lpe_reset(sc);
- /* Initialize MII */
-#ifndef __rtems__
- val = lpe_read_4(sc, LPE_COMMAND);
- lpe_write_4(sc, LPE_COMMAND, val | LPE_COMMAND_RMII);
- if (mii_attach(dev, &sc->lpe_miibus, ifp, lpe_ifmedia_upd,
- lpe_ifmedia_sts, BMSR_DEFCAPMASK, 0x01,
- MII_OFFSET_ANY, 0)) {
- device_printf(dev, "cannot find PHY\n");
- goto fail;
- lpe_ifmedia_sts, BMSR_DEFCAPMASK, MII_PHY_ANY,
- goto fail;
- lpe_dma_alloc(sc);
- return (0);
-fail:
- if (sc->lpe_ifp)
- if_free(sc->lpe_ifp);
- if (sc->lpe_intrhand)
- bus_teardown_intr(dev, sc->lpe_irq_res, sc->lpe_intrhand);
- if (sc->lpe_irq_res)
- bus_release_resource(dev, SYS_RES_IRQ, 0, sc->lpe_irq_res);
- if (sc->lpe_mem_res)
- bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->lpe_mem_res);
- return (ENXIO);
+/* Events */
-static int
-lpe_detach(device_t dev)
+#define LPC_ETH_EVENT_INITIALIZE RTEMS_EVENT_1
- lpe_stop(sc);
+#define LPC_ETH_EVENT_TXSTART RTEMS_EVENT_2
+#define LPC_ETH_EVENT_INTERRUPT RTEMS_EVENT_3
- return (0);
+#define LPC_ETH_EVENT_STOP RTEMS_EVENT_4
-static int
-lpe_miibus_readreg(device_t dev, int phy, int reg)
- uint32_t val;
- int result;
+/* Status */
- lpe_write_4(sc, LPE_MCMD, LPE_MCMD_READ);
- lpe_write_4(sc, LPE_MADR,
- (reg & LPE_MADR_REGMASK) << LPE_MADR_REGSHIFT |
- (phy & LPE_MADR_PHYMASK) << LPE_MADR_PHYSHIFT);
+#define LPC_ETH_INTERRUPT_RECEIVE \
+ (ETH_INT_RX_ERROR | ETH_INT_RX_FINISHED | ETH_INT_RX_DONE)
- val = lpe_read_4(sc, LPE_MIND);
+#define LPC_ETH_INTERRUPT_TRANSMIT \
+ (ETH_INT_TX_DONE | ETH_INT_TX_FINISHED | ETH_INT_TX_ERROR)
- /* Wait until request is completed */
- while (val & LPE_MIND_BUSY) {
- DELAY(10);
+#define LPC_ETH_RX_STAT_ERRORS \
+ (ETH_RX_STAT_CRC_ERROR \
+ | ETH_RX_STAT_SYMBOL_ERROR \
+ | ETH_RX_STAT_LENGTH_ERROR \
+ | ETH_RX_STAT_ALIGNMENT_ERROR \
+ | ETH_RX_STAT_OVERRUN \
+ | ETH_RX_STAT_NO_DESCRIPTOR)
- if (val & LPE_MIND_INVALID)
- return (0);
+#define LPC_ETH_LAST_FRAGMENT_FLAGS \
+ (ETH_TX_CTRL_OVERRIDE \
+ | ETH_TX_CTRL_PAD \
+ | ETH_TX_CTRL_CRC \
+ | ETH_TX_CTRL_INTERRUPT \
+ | ETH_TX_CTRL_LAST)
- lpe_write_4(sc, LPE_MCMD, 0);
- result = (lpe_read_4(sc, LPE_MRDD) & LPE_MRDD_DATAMASK);
- debugf("phy=%d reg=%d result=0x%04x\n", phy, reg, result);
+/* Debug */
- return (result);
+#ifdef DEBUG
+ #define LPC_ETH_PRINTF(...) printf(__VA_ARGS__)
+ #define LPC_ETH_PRINTK(...) printk(__VA_ARGS__)
+#else
+#endif
-static int
-lpe_miibus_writereg(device_t dev, int phy, int reg, int data)
+typedef enum {
+ LPC_ETH_STATE_NOT_INITIALIZED = 0,
+ LPC_ETH_STATE_DOWN,
+ LPC_ETH_STATE_UP
+} lpc_eth_state;
+typedef struct {
+ struct arpcom arpcom;
+ lpc_eth_state state;
+ struct rtems_mdio_info mdio;
+ uint32_t anlpar;
+ rtems_id receive_task;
+ rtems_id transmit_task;
+ unsigned rx_unit_count;
+ unsigned tx_unit_count;
+ volatile lpc_eth_transfer_descriptor *rx_desc_table;
+ volatile lpc_eth_receive_status *rx_status_table;
+ struct mbuf **rx_mbuf_table;
+ volatile lpc_eth_transfer_descriptor *tx_desc_table;
+ volatile uint32_t *tx_status_table;
+ void *tx_buf_table;
+ unsigned received_frames;
+ unsigned receive_interrupts;
+ unsigned transmitted_frames;
+ unsigned transmit_interrupts;
+ unsigned receive_drop_errors;
+ unsigned receive_overrun_errors;
+ unsigned receive_fragment_errors;
+ unsigned receive_crc_errors;
+ unsigned receive_symbol_errors;
+ unsigned receive_length_errors;
+ unsigned receive_alignment_errors;
+ unsigned receive_no_descriptor_errors;
+ unsigned receive_fatal_errors;
+ unsigned transmit_underrun_errors;
+ unsigned transmit_late_collision_errors;
+ unsigned transmit_excessive_collision_errors;
+ unsigned transmit_excessive_defer_errors;
+ unsigned transmit_no_descriptor_errors;
+ unsigned transmit_overflow_errors;
+ unsigned transmit_fatal_errors;
+ uint32_t phy_id;
+ int phy;
+ rtems_vector_number interrupt_number;
+ rtems_id control_task;
+} lpc_eth_driver_entry;
+static lpc_eth_driver_entry lpc_eth_driver_data;
+static void lpc_eth_control_request_complete(const lpc_eth_driver_entry *e)
- uint32_t val;
- debugf("phy=%d reg=%d data=0x%04x\n", phy, reg, data);
+ rtems_status_code sc = rtems_event_transient_send(e->control_task);
+ assert(sc == RTEMS_SUCCESSFUL);
- lpe_write_4(sc, LPE_MCMD, LPE_MCMD_WRITE);
+static void lpc_eth_control_request(
+ lpc_eth_driver_entry *e,
+ rtems_id task,
+ rtems_event_set event
+ rtems_status_code sc = RTEMS_SUCCESSFUL;
+ uint32_t nest_count = 0;
- lpe_write_4(sc, LPE_MWTD, (data & LPE_MWTD_DATAMASK));
+ e->control_task = rtems_task_self();
+ sc = rtems_bsdnet_event_send(task, event);
- DELAY(10);
+ nest_count = rtems_bsdnet_semaphore_release_recursive();
+ sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ rtems_bsdnet_semaphore_obtain_recursive(nest_count);
- return (0);
+ e->control_task = 0;
-static void
-lpe_miibus_statchg(device_t dev)
+static inline uint32_t lpc_eth_increment(
+ uint32_t value,
+ uint32_t cycle
- struct mii_data *mii = device_get_softc(sc->lpe_miibus);
-#ifndef __rtems__
- lpe_lock(sc);
- if ((mii->mii_media_status & IFM_ACTIVE) &&
- (mii->mii_media_status & IFM_AVALID))
- sc->lpe_flags |= LPE_FLAG_LINK;
- else
- sc->lpe_flags &= ~LPE_FLAG_LINK;
-#ifndef __rtems__
- lpe_unlock(sc);
+ if (value < cycle) {
+ return ++value;
+ } else {
+ return 0;
-static void
-lpe_reset(struct lpe_softc *sc)
+static void lpc_eth_enable_promiscous_mode(bool enable)
- uint32_t mac1;
-#ifndef __rtems__
- /* Enter soft reset mode */
- mac1 = lpe_read_4(sc, LPE_MAC1);
- lpe_write_4(sc, LPE_MAC1, mac1 | LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
- LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX);
- /* Reset registers, Tx path and Rx path */
- lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_REGRESET |
- LPE_COMMAND_TXRESET | LPE_COMMAND_RXRESET);
- /* Set station address */
- lpe_write_4(sc, LPE_SA2, sc->lpe_enaddr[1] << 8 | sc->lpe_enaddr[0]);
- lpe_write_4(sc, LPE_SA1, sc->lpe_enaddr[3] << 8 | sc->lpe_enaddr[2]);
- lpe_write_4(sc, LPE_SA0, sc->lpe_enaddr[5] << 8 | sc->lpe_enaddr[4]);
- /* Leave soft reset mode */
- lpe_write_4(sc, LPE_MAC1, mac1 & ~(LPE_MAC1_SOFTRESET | LPE_MAC1_RESETTX |
- LPE_MAC1_RESETMCSTX | LPE_MAC1_RESETRX | LPE_MAC1_RESETMCSRX));
- lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_REGRESET | LPE_COMMAND_TXRESET | LPE_COMMAND_RXRESET);
- /* Reinitialize registers */
- lpe_write_4(sc, LPE_MCFG, LPE_MCFG_CLKSEL(0x7));
- lpe_write_4(sc, LPE_MAC2, LPE_MAC2_PADCRCENABLE | LPE_MAC2_CRCENABLE | LPE_MAC2_FULLDUPLEX);
- lpe_write_4(sc, LPE_IPGT, 0x15);
- lpe_write_4(sc, LPE_IPGR, 0x12);
- lpe_write_4(sc, LPE_CLRT, 0x370f);
- lpe_write_4(sc, LPE_MAXF, 0x0600);
- lpe_write_4(sc, LPE_SUPP, LPE_SUPP_SPEED);
- lpe_write_4(sc, LPE_TEST, 0x0);
- lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_FULLDUPLEX | LPE_COMMAND_RMII);
-#else
- lpe_write_4(sc, LPE_COMMAND, LPE_COMMAND_FULLDUPLEX);
-#endif
- lpe_write_4(sc, LPE_INTENABLE, 0x0);
- lpe_write_4(sc, LPE_INTCLEAR, 0x30ff);
- lpe_write_4(sc, LPE_POWERDOWN, 0x0);
+ if (enable) {
+ lpc_eth->rxfilterctrl = ETH_RX_FIL_CTRL_ACCEPT_UNICAST
+ | ETH_RX_FIL_CTRL_ACCEPT_MULTICAST
+ | ETH_RX_FIL_CTRL_ACCEPT_BROADCAST;
+ } else {
+ lpc_eth->rxfilterctrl = ETH_RX_FIL_CTRL_ACCEPT_PERFECT
+ | ETH_RX_FIL_CTRL_ACCEPT_MULTICAST_HASH
-static void
-lpe_init(void *arg)
+static void lpc_eth_interrupt_handler(void *arg)
- struct lpe_softc *sc = (struct lpe_softc *)arg;
- lpe_lock(sc);
- lpe_init_locked(sc);
- lpe_unlock(sc);
+ lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) arg;
+ rtems_event_set re = 0;
+ rtems_event_set te = 0;
+ uint32_t ie = 0;
+ /* Get interrupt status */
+ uint32_t im = lpc_eth->intenable;
+ uint32_t is = lpc_eth->intstatus & im;
+ /* Check receive interrupts */
+ if ((is & ETH_INT_RX_OVERRUN) != 0) {
+ re = LPC_ETH_EVENT_INITIALIZE;
+ ++e->receive_fatal_errors;
+ } else if ((is & LPC_ETH_INTERRUPT_RECEIVE) != 0) {
+ re = LPC_ETH_EVENT_INTERRUPT;
+ ie |= LPC_ETH_INTERRUPT_RECEIVE;
+ /* Send events to receive task */
+ if (re != 0) {
+ ++e->receive_interrupts;
+ (void) rtems_bsdnet_event_send(e->receive_task, re);
+ /* Check transmit interrupts */
+ if ((is & ETH_INT_TX_UNDERRUN) != 0) {
+ te = LPC_ETH_EVENT_INITIALIZE;
+ ++e->transmit_fatal_errors;
+ } else if ((is & LPC_ETH_INTERRUPT_TRANSMIT) != 0) {
+ te = LPC_ETH_EVENT_INTERRUPT;
+ ie |= LPC_ETH_INTERRUPT_TRANSMIT;
+ /* Send events to transmit task */
+ if (te != 0) {
+ ++e->transmit_interrupts;
+ (void) rtems_bsdnet_event_send(e->transmit_task, te);
+ LPC_ETH_PRINTK("interrupt: rx = 0x%08x, tx = 0x%08x\n", re, te);
+ /* Update interrupt mask */
+ lpc_eth->intenable = im & ~ie;
+ /* Clear interrupts */
+ lpc_eth->intclear = is;
-static void
-lpe_init_locked(struct lpe_softc *sc)
+static void lpc_eth_enable_receive_interrupts(void)
- struct ifnet *ifp = sc->lpe_ifp;
- uint32_t cmd, mac1;
- lpe_lock_assert(sc);
- if (ifp->if_drv_flags & IFF_DRV_RUNNING)
- return;
- /* Enable Tx and Rx */
- cmd = lpe_read_4(sc, LPE_COMMAND);
- lpe_write_4(sc, LPE_COMMAND, cmd | LPE_COMMAND_RXENABLE |
- LPE_COMMAND_TXENABLE | LPE_COMMAND_PASSRUNTFRAME);
- /* Enable receive */
-#ifdef __rtems__
- (void)mac1;
- lpe_write_4(sc, LPE_MAC1, /*mac1 |*/ LPE_MAC1_RXENABLE | LPE_MAC1_PASSALL);
- lpe_write_4(sc, LPE_MAC2, LPE_MAC2_CRCENABLE | LPE_MAC2_PADCRCENABLE |
- LPE_MAC2_FULLDUPLEX);
- lpe_write_4(sc, LPE_MCFG, LPE_MCFG_CLKSEL(7));
- /* Set up Rx filter */
- lpe_set_rxmode(sc);
- /* Enable interrupts */
- lpe_write_4(sc, LPE_INTENABLE, LPE_INT_RXOVERRUN | LPE_INT_RXERROR |
- LPE_INT_RXFINISH | LPE_INT_RXDONE | LPE_INT_TXUNDERRUN |
- LPE_INT_TXERROR | LPE_INT_TXFINISH | LPE_INT_TXDONE);
- sc->lpe_cdata.lpe_tx_prod = 0;
- sc->lpe_cdata.lpe_tx_last = 0;
- sc->lpe_cdata.lpe_tx_used = 0;
- lpe_init_rx(sc);
- /* Initialize Rx packet and status descriptor heads */
- lpe_write_4(sc, LPE_RXDESC, sc->lpe_rdata.lpe_rx_ring_phys);
- lpe_write_4(sc, LPE_RXSTATUS, sc->lpe_rdata.lpe_rx_status_phys);
- lpe_write_4(sc, LPE_RXDESC_NUMBER, LPE_RXDESC_NUM - 1);
- lpe_write_4(sc, LPE_RXDESC_CONS, 0);
- /* Initialize Tx packet and status descriptor heads */
- lpe_write_4(sc, LPE_TXDESC, sc->lpe_rdata.lpe_tx_ring_phys);
- lpe_write_4(sc, LPE_TXSTATUS, sc->lpe_rdata.lpe_tx_status_phys);
- lpe_write_4(sc, LPE_TXDESC_NUMBER, LPE_TXDESC_NUM - 1);
- lpe_write_4(sc, LPE_TXDESC_PROD, 0);
+ rtems_interrupt_level level;
- ifp->if_drv_flags |= IFF_DRV_RUNNING;
- ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
- callout_reset(&sc->lpe_tick, hz, lpe_tick, sc);
+ rtems_interrupt_disable(level);
+ lpc_eth->intenable |= LPC_ETH_INTERRUPT_RECEIVE;
+ rtems_interrupt_enable(level);
-static void
-lpe_start(struct ifnet *ifp)
+static void lpc_eth_disable_receive_interrupts(void)
- struct lpe_softc *sc = (struct lpe_softc *)ifp->if_softc;
- lpe_lock(sc);
- lpe_start_locked(ifp);
- lpe_unlock(sc);
+ lpc_eth->intenable &= ~LPC_ETH_INTERRUPT_RECEIVE;
-static void
-lpe_start_locked(struct ifnet *ifp)
+static void lpc_eth_enable_transmit_interrupts(void)
- struct mbuf *m_head;
- int encap = 0;
- while (!IFQ_DRV_IS_EMPTY(&ifp->if_snd)) {
- if (lpe_read_4(sc, LPE_TXDESC_PROD) ==
- lpe_read_4(sc, LPE_TXDESC_CONS) - 5)
- break;
+ lpc_eth->intenable |= LPC_ETH_INTERRUPT_TRANSMIT;
- /* Dequeue first packet */
- IFQ_DRV_DEQUEUE(&ifp->if_snd, m_head);
- if (!m_head)
- break;
+static void lpc_eth_disable_transmit_interrupts(void)
- lpe_encap(sc, &m_head);
+ lpc_eth->intenable &= ~LPC_ETH_INTERRUPT_TRANSMIT;
- encap++;
+#define LPC_ETH_RX_DATA_OFFSET 2
- /* Submit new descriptor list */
- if (encap) {
- lpe_write_4(sc, LPE_TXDESC_PROD, sc->lpe_cdata.lpe_tx_prod);
- sc->lpe_watchdog_timer = 5;
+static struct mbuf *lpc_eth_new_mbuf(struct ifnet *ifp, bool wait)
+ struct mbuf *m = NULL;
+ int mw = wait ? M_WAIT : M_DONTWAIT;
+ MGETHDR(m, mw, MT_DATA);
+ if (m != NULL) {
+ MCLGET(m, mw);
+ if ((m->m_flags & M_EXT) != 0) {
+ /* Set receive interface */
+ m->m_pkthdr.rcvif = ifp;
+ /* Adjust by two bytes for proper IP header alignment */
+ m->m_data = mtod(m, char *) + LPC_ETH_RX_DATA_OFFSET;
+ return m;
+ } else {
+ m_free(m);
+ return NULL;
-#ifdef __rtems__
-static int
-lpe_get_segs_for_tx(struct mbuf *m, bus_dma_segment_t segs[LPE_MAXFRAGS],
- int *nsegs)
+static bool lpc_eth_add_new_mbuf(
+ struct ifnet *ifp,
+ volatile lpc_eth_transfer_descriptor *desc,
+ struct mbuf **mbufs,
+ uint32_t i,
+ bool wait
- int i = 0;
- do {
- if (m->m_len > 0) {
- segs[i].ds_addr = mtod(m, bus_addr_t);
- segs[i].ds_len = m->m_len;
-#ifdef CPU_DATA_CACHE_ALIGNMENT
- rtems_cache_flush_multiple_data_lines(m->m_data, m->m_len);
-#endif
- ++i;
- m = m->m_next;
- if (m == NULL) {
- *nsegs = i;
- return (0);
- } while (i < LPE_MAXFRAGS);
- return (EFBIG);
+ /* New mbuf */
+ struct mbuf *m = lpc_eth_new_mbuf(ifp, wait);
+ /* Check mbuf */
+ if (m != NULL) {
+ /* Cache invalidate */
+ rtems_cache_invalidate_multiple_data_lines(
+ mtod(m, void *),
+ MCLBYTES - LPC_ETH_RX_DATA_OFFSET
+ /* Add mbuf to queue */
+ desc [i].start = mtod(m, uint32_t);
+ desc [i].control = (MCLBYTES - LPC_ETH_RX_DATA_OFFSET - 1)
+ | ETH_RX_CTRL_INTERRUPT;
+ /* Cache flush of descriptor */
+ rtems_cache_flush_multiple_data_lines(
+ (void *) &desc [i],
+ sizeof(desc [0])
+ /* Add mbuf to table */
+ mbufs [i] = m;
+ return true;
+ } else {
+ return false;
-static int
-lpe_encap(struct lpe_softc *sc, struct mbuf **m_head)
- struct lpe_txdesc *txd;
- struct lpe_hwdesc *hwd;
- bus_dma_segment_t segs[LPE_MAXFRAGS];
- int i, err, nsegs, prod;
- M_ASSERTPKTHDR((*m_head));
- prod = sc->lpe_cdata.lpe_tx_prod;
- txd = &sc->lpe_cdata.lpe_tx_desc[prod];
- debugf("starting with prod=%d\n", prod);
-#ifndef __rtems__
- err = bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_tx_buf_tag,
- txd->lpe_txdesc_dmamap, *m_head, segs, &nsegs, BUS_DMA_NOWAIT);
- err = lpe_get_segs_for_tx(*m_head, segs, &nsegs);
- if (err)
- return (err);
- if (nsegs == 0) {
- m_freem(*m_head);
- *m_head = NULL;
- return (EIO);
-#ifndef __rtems__
- bus_dmamap_sync(sc->lpe_cdata.lpe_tx_buf_tag, txd->lpe_txdesc_dmamap,
- BUS_DMASYNC_PREREAD);
- bus_dmamap_sync(sc->lpe_cdata.lpe_tx_ring_tag, sc->lpe_cdata.lpe_tx_ring_map,
- BUS_DMASYNC_POSTREAD | BUS_DMASYNC_POSTWRITE);
- txd->lpe_txdesc_first = 1;
- txd->lpe_txdesc_mbuf = *m_head;
- for (i = 0; i < nsegs; i++) {
- hwd = &sc->lpe_rdata.lpe_tx_ring[prod];
- hwd->lhr_data = segs[i].ds_addr;
- hwd->lhr_control = segs[i].ds_len - 1;
- if (i == nsegs - 1) {
- hwd->lhr_control |= LPE_HWDESC_LASTFLAG;
- hwd->lhr_control |= LPE_HWDESC_INTERRUPT;
- hwd->lhr_control |= LPE_HWDESC_CRC;
- hwd->lhr_control |= LPE_HWDESC_PAD;
-#ifdef __rtems__
- rtems_cache_flush_multiple_data_lines(hwd, sizeof(*hwd));
-#endif
- LPE_INC(prod, LPE_TXDESC_NUM);
- BUS_DMASYNC_PREREAD | BUS_DMASYNC_PREWRITE);
- sc->lpe_cdata.lpe_tx_used += nsegs;
- sc->lpe_cdata.lpe_tx_prod = prod;
- return (0);
+static void lpc_eth_receive_task(void *arg)
+ rtems_event_set events = 0;
+ lpc_eth_driver_entry *const e = (lpc_eth_driver_entry *) arg;
+ struct ifnet *const ifp = &e->arpcom.ac_if;
+ volatile lpc_eth_transfer_descriptor *const desc = e->rx_desc_table;
+ volatile lpc_eth_receive_status *const status = e->rx_status_table;
+ struct mbuf **const mbufs = e->rx_mbuf_table;
+ uint32_t const index_max = e->rx_unit_count - 1;
+ uint32_t produce_index = 0;
+ uint32_t consume_index = 0;
+ LPC_ETH_PRINTF("%s\n", __func__);
+ /* Main event loop */
+ while (true) {
+ /* Wait for events */
+ sc = rtems_bsdnet_event_receive(
+ LPC_ETH_EVENT_INITIALIZE
+ | LPC_ETH_EVENT_STOP
+ | LPC_ETH_EVENT_INTERRUPT,
+ RTEMS_EVENT_ANY | RTEMS_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &events
+ LPC_ETH_PRINTF("rx: wake up: 0x%08" PRIx32 "\n", events);
+ /* Stop receiver? */
+ if ((events & LPC_ETH_EVENT_STOP) != 0) {
+ lpc_eth_control_request_complete(e);
+ continue;
+ /* Initialize receiver? */
+ if ((events & LPC_ETH_EVENT_INITIALIZE) != 0) {
+ /* Disable receive interrupts */
+ lpc_eth_disable_receive_interrupts();
+ /* Disable receiver */
+ lpc_eth->command &= ~ETH_CMD_RX_ENABLE;
+ /* Wait for inactive status */
+ while ((lpc_eth->status & ETH_STAT_RX_ACTIVE) != 0) {
+ /* Wait */
+ /* Reset */
+ lpc_eth->command |= ETH_CMD_RX_RESET;
+ /* Clear receive interrupts */
+ lpc_eth->intclear = LPC_ETH_INTERRUPT_RECEIVE;
+ /* Move existing mbufs to the front */
+ consume_index = 0;
+ for (produce_index = 0; produce_index <= index_max; ++produce_index) {
+ if (mbufs [produce_index] != NULL) {
+ mbufs [consume_index] = mbufs [produce_index];
+ ++consume_index;
+ /* Fill receive queue */
+ for (
+ produce_index = consume_index;
+ produce_index <= index_max;
+ ++produce_index
+ lpc_eth_add_new_mbuf(ifp, desc, mbufs, produce_index, true);
+ /* Receive descriptor table */
+ lpc_eth->rxdescriptornum = index_max;
+ lpc_eth->rxdescriptor = (uint32_t) desc;
+ lpc_eth->rxstatus = (uint32_t) status;
+ /* Initialize indices */
+ produce_index = lpc_eth->rxproduceindex;
+ consume_index = lpc_eth->rxconsumeindex;
+ /* Enable receiver */
+ lpc_eth->command |= ETH_CMD_RX_ENABLE;
+ /* Enable receive interrupts */
+ lpc_eth_enable_receive_interrupts();
+ continue;
+ while (true) {
+ /* Clear receive interrupt status */
+ /* Get current produce index */
+ if (consume_index != produce_index) {
+ uint32_t stat = 0;
+ /* Fragment status */
+ (void *) &status [consume_index],
+ sizeof(status [0])
+ stat = status [consume_index].info;
+ if (
+ (stat & ETH_RX_STAT_LAST_FLAG) != 0
+ && (stat & LPC_ETH_RX_STAT_ERRORS) == 0
+ /* Received mbuf */
+ struct mbuf *m = mbufs [consume_index];
+ if (lpc_eth_add_new_mbuf(ifp, desc, mbufs, consume_index, false)) {
+ /* Ethernet header */
+ struct ether_header *eh = mtod(m, struct ether_header *);
+ /* Discard Ethernet header and CRC */
+ int sz = (int) (stat & ETH_RX_STAT_RXSIZE_MASK) + 1
+ - ETHER_HDR_LEN - ETHER_CRC_LEN;
+ /* Update mbuf */
+ m->m_len = sz;
+ m->m_pkthdr.len = sz;
+ m->m_data = mtod(m, char *) + ETHER_HDR_LEN;
+ LPC_ETH_PRINTF("rx: %02" PRIu32 ": %u\n", consume_index, sz);
+ /* Hand over */
+ ether_input(ifp, eh, m);
+ /* Increment received frames counter */
+ ++e->received_frames;
+ } else {
+ ++e->receive_drop_errors;
+ } else {
+ /* Update error counters */
+ if ((stat & ETH_RX_STAT_OVERRUN) != 0) {
+ ++e->receive_overrun_errors;
+ if ((stat & ETH_RX_STAT_LAST_FLAG) == 0) {
+ ++e->receive_fragment_errors;
+ if ((stat & ETH_RX_STAT_CRC_ERROR) != 0) {
+ ++e->receive_crc_errors;
+ if ((stat & ETH_RX_STAT_SYMBOL_ERROR) != 0) {
+ ++e->receive_symbol_errors;
+ if ((stat & ETH_RX_STAT_LENGTH_ERROR) != 0) {
+ ++e->receive_length_errors;
+ if ((stat & ETH_RX_STAT_ALIGNMENT_ERROR) != 0) {
+ ++e->receive_alignment_errors;
+ if ((stat & ETH_RX_STAT_NO_DESCRIPTOR) != 0) {
+ ++e->receive_no_descriptor_errors;
+ /* Increment and update consume index */
+ consume_index = lpc_eth_increment(consume_index, index_max);
+ lpc_eth->rxconsumeindex = consume_index;
+ } else {
+ /* Nothing to do, enable receive interrupts */
+ break;
-static void
-lpe_stop(struct lpe_softc *sc)
+static struct mbuf *lpc_eth_next_fragment(
+ struct mbuf *m,
+ uint32_t *ctrl
- lpe_lock(sc);
- lpe_stop_locked(sc);
- lpe_unlock(sc);
+ struct mbuf *n = NULL;
+ int size = 0;
+ while (true) {
+ if (m == NULL) {
+ /* Dequeue first fragment of the next frame */
+ IF_DEQUEUE(&ifp->if_snd, m);
+ /* Empty queue? */
+ if (m == NULL) {
+ return m;
+ /* Get fragment size */
+ size = m->m_len;
+ if (size > 0) {
+ /* Now we have a not empty fragment */
+ break;
+ } else {
+ /* Discard empty fragments */
+ m = m_free(m);
+ /* Set fragment size */
+ *ctrl = (uint32_t) (size - 1);
+ /* Discard empty successive fragments */
+ n = m->m_next;
+ while (n != NULL && n->m_len <= 0) {
+ n = m_free(n);
+ m->m_next = n;
+ /* Is our fragment the last in the frame? */
+ if (n == NULL) {
+ *ctrl |= LPC_ETH_LAST_FRAGMENT_FLAGS;
+ return m;
-static void
-lpe_stop_locked(struct lpe_softc *sc)
+static void lpc_eth_transmit_task(void *arg)
- callout_stop(&sc->lpe_tick);
+ struct ifnet *ifp = &e->arpcom.ac_if;
+ volatile lpc_eth_transfer_descriptor *const desc = e->tx_desc_table;
+ volatile uint32_t *const status = e->tx_status_table;
+ #ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
+ struct mbuf **const mbufs = e->tx_buf_table;
+ #else
+ char *const buf = e->tx_buf_table;
+ #endif
+ uint32_t const index_max = e->tx_unit_count - 1;
+ uint32_t ctrl = 0;
+ #ifndef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
+ uint32_t frame_length = 0;
+ char *frame_buffer = NULL;
+ #endif
+ /* Initialize descriptor table */
+ desc [produce_index].start =
+ (uint32_t) (buf + produce_index * LPC_ETH_CONFIG_TX_BUF_SIZE);
+ #endif
+ while (true) {
+ | LPC_ETH_EVENT_TXSTART
+ RTEMS_NO_TIMEOUT,
+ &events
+ LPC_ETH_PRINTF("tx: wake up: 0x%08" PRIx32 "\n", events);
+ /* Stop transmitter? */
+ continue;
+ /* Initialize transmitter? */
+ /* Disable transmit interrupts */
+ lpc_eth_disable_transmit_interrupts();
+ /* Disable transmitter */
+ lpc_eth->command &= ~ETH_CMD_TX_ENABLE;
+ while ((lpc_eth->status & ETH_STAT_TX_ACTIVE) != 0) {
+ /* Wait */
+ /* Reset */
+ lpc_eth->command |= ETH_CMD_TX_RESET;
+ /* Clear transmit interrupts */
+ lpc_eth->intclear = LPC_ETH_INTERRUPT_TRANSMIT;
+ /* Transmit descriptors */
+ lpc_eth->txdescriptornum = index_max;
+ lpc_eth->txdescriptor = (uint32_t) desc;
+ lpc_eth->txstatus = (uint32_t) status;
+ /* Discard outstanding fragments (= data loss) */
+ struct mbuf *victim = mbufs [produce_index];
+ if (victim != NULL) {
+ m_free(victim);
+ mbufs [produce_index] = NULL;
+ #endif
+ produce_index = lpc_eth->txproduceindex;
+ consume_index = lpc_eth->txconsumeindex;
+ /* Fresh frame length and buffer start */
+ frame_length = 0;
+ frame_buffer = (char *) desc [produce_index].start;
+ #endif
+ /* Enable transmitter */
+ lpc_eth->command |= ETH_CMD_TX_ENABLE;
+ /* Free consumed fragments */
+ while (true) {
+ /* Save last known consume index */
+ uint32_t c = consume_index;
+ /* Clear transmit interrupt status */
+ /* Get new consume index */
+ /* Nothing consumed in the meantime? */
+ if (c == consume_index) {
+ break;
+ while (c != consume_index) {
+ uint32_t s = status [c];
+ if ((s & (ETH_TX_STAT_ERROR | ETH_TX_STAT_NO_DESCRIPTOR)) != 0) {
+ if ((s & ETH_TX_STAT_UNDERRUN) != 0) {
+ ++e->transmit_underrun_errors;
+ if ((s & ETH_TX_STAT_LATE_COLLISION) != 0) {
+ ++e->transmit_late_collision_errors;
+ if ((s & ETH_TX_STAT_EXCESSIVE_COLLISION) != 0) {
+ ++e->transmit_excessive_collision_errors;
+ if ((s & ETH_TX_STAT_EXCESSIVE_DEFER) != 0) {
+ ++e->transmit_excessive_defer_errors;
+ if ((s & ETH_TX_STAT_NO_DESCRIPTOR) != 0) {
+ ++e->transmit_no_descriptor_errors;
+ /* Release mbuf */
+ m_free(mbufs [c]);
+ mbufs [c] = NULL;
+ #endif
+ /* Next consume index */
+ c = lpc_eth_increment(c, index_max);
+ /* Transmit new fragments */
+ while (true) {
+ /* Compute next produce index */
+ uint32_t p = lpc_eth_increment(produce_index, index_max);
+ /* Get next fragment and control value */
+ m = lpc_eth_next_fragment(ifp, m, &ctrl);
+ /* Queue full? */
+ if (p == consume_index) {
+ LPC_ETH_PRINTF("tx: full queue: 0x%08x\n", m);
+ /* The queue is full, wait for transmit interrupt */
+ break;
+ /* New fragment? */
+ if (m != NULL) {
+ /* Set the transfer data */
+ mtod(m, const void *),
+ (size_t) m->m_len
+ desc [produce_index].start = mtod(m, uint32_t);
+ desc [produce_index].control = ctrl;
+ (void *) &desc [produce_index],
+ sizeof(desc [0])
+ mbufs [produce_index] = m;
+ LPC_ETH_PRINTF(
+ "tx: %02" PRIu32 ": %u %s\n",
+ produce_index, m->m_len,
+ (ctrl & ETH_TX_CTRL_LAST) != 0 ? "L" : ""
+ /* Next produce index */
+ produce_index = p;
+ /* Last fragment of a frame? */
+ if ((ctrl & ETH_TX_CTRL_LAST) != 0) {
+ /* Update the produce index */
+ lpc_eth->txproduceindex = produce_index;
+ /* Increment transmitted frames counter */
+ ++e->transmitted_frames;
+ /* Next fragment of the frame */
+ m = m->m_next;
+ #else
+ size_t fragment_length = (size_t) m->m_len;
+ void *fragment_start = mtod(m, void *);
+ uint32_t new_frame_length = frame_length + fragment_length;
+ /* Check buffer size */
+ if (new_frame_length > LPC_ETH_CONFIG_TX_BUF_SIZE) {
+ LPC_ETH_PRINTF("tx: overflow\n");
+ /* Discard overflow data */
+ new_frame_length = LPC_ETH_CONFIG_TX_BUF_SIZE;
+ fragment_length = new_frame_length - frame_length;
+ /* Finalize frame */
+ ctrl |= LPC_ETH_LAST_FRAGMENT_FLAGS;
+ /* Update error counter */
+ ++e->transmit_overflow_errors;
+ LPC_ETH_PRINTF(
+ "tx: copy: %" PRIu32 "%s%s\n",
+ fragment_length,
+ (m->m_flags & M_EXT) != 0 ? ", E" : "",
+ (m->m_flags & M_PKTHDR) != 0 ? ", H" : ""
+ /* Copy fragment to buffer in Ethernet RAM */
+ memcpy(frame_buffer, fragment_start, fragment_length);
+ /* Finalize descriptor */
+ desc [produce_index].control = (ctrl & ~ETH_TX_CTRL_SIZE_MASK)
+ | (new_frame_length - 1);
+ LPC_ETH_PRINTF(
+ "tx: %02" PRIu32 ": %" PRIu32 "\n",
+ produce_index,
+ new_frame_length
+ /* Cache flush of data */
+ (const void *) desc [produce_index].start,
+ new_frame_length
+ sizeof(desc [0])
+ frame_length = 0;
+ } else {
+ /* New frame length */
+ frame_length = new_frame_length;
+ /* Update current frame buffer start */
+ frame_buffer += fragment_length;
+ /* Free mbuf and get next */
+ m = m_free(m);
+ #endif
+ } else {
+ /* Nothing to transmit */
+ break;
+ /* No more fragments? */
+ if (m == NULL) {
+ /* Interface is now inactive */
+ ifp->if_flags &= ~IFF_OACTIVE;
+ } else {
+ LPC_ETH_PRINTF("tx: enable interrupts\n");
+ /* Enable transmit interrupts */
+ lpc_eth_enable_transmit_interrupts();
- /* Disable interrupts */
- lpe_write_4(sc, LPE_INTCLEAR, 0xffffffff);
+static int lpc_eth_mdio_wait_for_not_busy(void)
+ rtems_interval one_second = rtems_clock_get_ticks_per_second();
+ rtems_interval i = 0;
- /* Stop EMAC */
- lpe_write_4(sc, LPE_MAC1, 0);
- lpe_write_4(sc, LPE_MAC2, 0);
- lpe_write_4(sc, LPE_COMMAND, 0);
+ while ((lpc_eth->mind & ETH_MIND_BUSY) != 0 && i < one_second) {
+ rtems_task_wake_after(1);
+ ++i;
- sc->lpe_ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
- sc->lpe_ifp->if_drv_flags &= ~IFF_DRV_RUNNING;
+ LPC_ETH_PRINTK("tx: lpc_eth_mdio_wait %s after %d\n",
+ i != one_second? "succeed": "timeout", i);
-static int
-lpe_ioctl(struct ifnet *ifp, u_long cmd, caddr_t data)
- struct lpe_softc *sc = ifp->if_softc;
- struct ifreq *ifr = (struct ifreq *)data;
- int err = 0;
- switch (cmd) {
- case SIOCSIFFLAGS:
- lpe_lock(sc);
- if (ifp->if_flags & IFF_UP) {
- if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
- lpe_set_rxfilter(sc);
- } else
- } else
- lpe_stop(sc);
- lpe_unlock(sc);
- break;
- case SIOCADDMULTI:
- case SIOCDELMULTI:
- lpe_lock(sc);
- lpe_unlock(sc);
- break;
- case SIOCGIFMEDIA:
- case SIOCSIFMEDIA:
- err = ifmedia_ioctl(ifp, ifr, &mii->mii_media, cmd);
- break;
- default:
- err = ether_ioctl(ifp, cmd, data);
- break;
- return (err);
+ return i != one_second ? 0 : ETIMEDOUT;
-static void lpe_set_rxmode(struct lpe_softc *sc)
+static uint32_t lpc_eth_mdio_read_anlpar(int phy)
- uint32_t rxfilt;
+ uint32_t madr = ETH_MADR_REG(MII_ANLPAR) | ETH_MADR_PHY(phy);
+ uint32_t anlpar = 0;
+ int eno = 0;
- rxfilt = LPE_RXFILTER_UNIHASH | LPE_RXFILTER_MULTIHASH | LPE_RXFILTER_PERFECT;
+ if (lpc_eth->madr != madr) {
+ lpc_eth->madr = madr;
- if (ifp->if_flags & IFF_BROADCAST)
- rxfilt |= LPE_RXFILTER_BROADCAST;
+ if (lpc_eth->mcmd != ETH_MCMD_READ) {
+ lpc_eth->mcmd = 0;
+ lpc_eth->mcmd = ETH_MCMD_READ;
- if (ifp->if_flags & IFF_PROMISC)
- rxfilt |= LPE_RXFILTER_UNICAST | LPE_RXFILTER_MULTICAST;
+ eno = lpc_eth_mdio_wait_for_not_busy();
+ if (eno == 0) {
+ anlpar = lpc_eth->mrdd;
- if (ifp->if_flags & IFF_ALLMULTI)
- rxfilt |= LPE_RXFILTER_MULTICAST;
+ /* Start next read */
- lpe_write_4(sc, LPE_RXFILTER_CTRL, rxfilt);
+ return anlpar;
-static void lpe_set_rxfilter(struct lpe_softc *sc)
+static int lpc_eth_mdio_read(
+ int phy,
+ void *arg RTEMS_UNUSED,
+ unsigned reg,
+ uint32_t *val
- struct ifmultiaddr *ifma;
- int index;
- uint32_t hashl, hashh;
- hashl = 0;
- hashh = 0;
- if_maddr_rlock(ifp);
- CK_STAILQ_FOREACH(ifma, &ifp->if_multiaddrs, ifma_link) {
- if (ifma->ifma_addr->sa_family != AF_LINK)
- continue;
- index = ether_crc32_be(LLADDR((struct sockaddr_dl *)
- ifma->ifma_addr), ETHER_ADDR_LEN) >> 23 & 0x3f;
- if (index > 31)
- hashh |= (1 << (index - 32));
- else
- hashl |= (1 << index);
- if_maddr_runlock(ifp);
- /* Program new hash filter */
- lpe_write_4(sc, LPE_HASHFILTER_L, hashl);
- lpe_write_4(sc, LPE_HASHFILTER_H, hashh);
+ int eno = 0;
+ if (0 <= phy && phy <= 31) {
+ lpc_eth->madr = ETH_MADR_REG(reg) | ETH_MADR_PHY(phy);
+ if (eno == 0) {
+ *val = lpc_eth->mrdd;
+ } else {
+ eno = EINVAL;
+ return eno;
-static void
-lpe_intr(void *arg)
+static int lpc_eth_mdio_write(
+ int phy,
+ unsigned reg,
+ uint32_t val
- uint32_t intstatus;
- debugf("status=0x%08x\n", lpe_read_4(sc, LPE_INTSTATUS));
- lpe_lock(sc);
- while ((intstatus = lpe_read_4(sc, LPE_INTSTATUS))) {
- if (intstatus & LPE_INT_RXDONE)
- lpe_rxintr(sc);
-#ifndef __rtems__
- if (intstatus & LPE_INT_TXDONE)
- lpe_txintr(sc);
- if (intstatus & LPE_INT_TXUNDERRUN) {
- if_inc_counter(sc->lpe_ifp, IFCOUNTER_OERRORS, 1);
- else if (intstatus & (LPE_INT_TXERROR | LPE_INT_TXFINISH | LPE_INT_TXDONE))
- lpe_txintr(sc);
- lpe_write_4(sc, LPE_INTCLEAR, 0xffff);
- lpe_unlock(sc);
+ int eno = 0;
-static void
-lpe_rxintr(struct lpe_softc *sc)
- struct lpe_hwstatus *hws;
- struct lpe_rxdesc *rxd;
- struct mbuf *m;
- int prod, cons;
- for (;;) {
- prod = lpe_read_4(sc, LPE_RXDESC_PROD);
- cons = lpe_read_4(sc, LPE_RXDESC_CONS);
- if (prod == cons)
- break;
- rxd = &sc->lpe_cdata.lpe_rx_desc[cons];
- hwd = &sc->lpe_rdata.lpe_rx_ring[cons];
- hws = &sc->lpe_rdata.lpe_rx_status[cons];
-#ifdef __rtems__
- rtems_cache_invalidate_multiple_data_lines(rxd, sizeof(*rxd));
- rtems_cache_invalidate_multiple_data_lines(hwd, sizeof(*hwd));
- rtems_cache_invalidate_multiple_data_lines(hws, sizeof(*hws));
-#endif
- /* Check received frame for errors */
- if (hws->lhs_info & LPE_HWDESC_RXERRS) {
- if_inc_counter(ifp, IFCOUNTER_IERRORS, 1);
- lpe_discard_rxbuf(sc, cons);
- lpe_init_rxbuf(sc, cons);
- goto skip;
- m = rxd->lpe_rxdesc_mbuf;
-#ifdef __rtems__
- rtems_cache_invalidate_multiple_data_lines(m->m_data, m->m_len);
-#endif
- m->m_pkthdr.rcvif = ifp;
- m->m_data += 2;
+ lpc_eth->mwtd = val;
+ } else {
+ eno = EINVAL;
- if_inc_counter(ifp, IFCOUNTER_IPACKETS, 1);
- lpe_unlock(sc);
- (*ifp->if_input)(ifp, m);
- lpe_lock(sc);
-skip:
- LPE_INC(cons, LPE_RXDESC_NUM);
- lpe_write_4(sc, LPE_RXDESC_CONS, cons);
+ return eno;
-static void
-lpe_txintr(struct lpe_softc *sc)
+static int lpc_eth_phy_get_id(int phy, uint32_t *id)
- int cons, last;
- for (;;) {
- cons = lpe_read_4(sc, LPE_TXDESC_CONS);
- last = sc->lpe_cdata.lpe_tx_last;
- if (cons == last)
- break;
- txd = &sc->lpe_cdata.lpe_tx_desc[last];
- hwd = &sc->lpe_rdata.lpe_tx_ring[last];
- hws = &sc->lpe_rdata.lpe_tx_status[last];
-#ifndef __rtems__
- txd->lpe_txdesc_dmamap, BUS_DMASYNC_POSTWRITE);
- rtems_cache_invalidate_multiple_data_lines(txd, sizeof(*txd));
-#endif
+ uint32_t id1 = 0;
+ int eno = lpc_eth_mdio_read(phy, NULL, MII_PHYIDR1, &id1);
- if_inc_counter(ifp, IFCOUNTER_COLLISIONS, LPE_HWDESC_COLLISIONS(hws->lhs_info));
+ if (eno == 0) {
+ uint32_t id2 = 0;
- if (hws->lhs_info & LPE_HWDESC_TXERRS)
- if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
- else
- if_inc_counter(ifp, IFCOUNTER_OPACKETS, 1);
+ eno = lpc_eth_mdio_read(phy, NULL, MII_PHYIDR2, &id2);
+ if (eno == 0) {
+ *id = (id1 << 16) | (id2 & 0xfff0);
- if (txd->lpe_txdesc_first) {
-#ifndef __rtems__
- bus_dmamap_unload(sc->lpe_cdata.lpe_tx_buf_tag,
- txd->lpe_txdesc_dmamap);
+ return eno;
- m_freem(txd->lpe_txdesc_mbuf);
- txd->lpe_txdesc_mbuf = NULL;
- txd->lpe_txdesc_first = 0;
+#define PHY_KSZ80X1RNL 0x221550
+#define PHY_DP83848 0x20005c90
- sc->lpe_cdata.lpe_tx_used--;
- LPE_INC(sc->lpe_cdata.lpe_tx_last, LPE_TXDESC_NUM);
+typedef struct {
+ unsigned reg;
+ uint32_t set;
+ uint32_t clear;
+} lpc_eth_phy_action;
- if (!sc->lpe_cdata.lpe_tx_used)
- sc->lpe_watchdog_timer = 0;
+static int lpc_eth_phy_set_and_clear(
+ const lpc_eth_phy_action *actions,
+ size_t n
+ int eno = 0;
+ size_t i;
+ for (i = 0; eno == 0 && i < n; ++i) {
+ const lpc_eth_phy_action *action = &actions [i];
+ uint32_t val;
+ eno = lpc_eth_mdio_read(e->phy, NULL, action->reg, &val);
+ if (eno == 0) {
+ val |= action->set;
+ val &= ~action->clear;
+ eno = lpc_eth_mdio_write(e->phy, NULL, action->reg, val);
+ return eno;
-static void
-lpe_tick(void *arg)
+static const lpc_eth_phy_action lpc_eth_phy_up_action_default [] = {
+ { MII_BMCR, 0, BMCR_PDOWN },
+ { MII_BMCR, BMCR_RESET, 0 },
+ { MII_BMCR, BMCR_AUTOEN, 0 }
- mii_tick(mii);
- lpe_watchdog(sc);
+static const lpc_eth_phy_action lpc_eth_phy_up_pre_action_KSZ80X1RNL [] = {
+ /* Disable slow oscillator mode */
+ { 0x11, 0, 0x10 }
+static const lpc_eth_phy_action lpc_eth_phy_up_post_action_KSZ80X1RNL [] = {
+ /* Enable energy detect power down (EDPD) mode */
+ { 0x18, 0x0800, 0 },
+ /* Turn PLL of automatically in EDPD mode */
+ { 0x10, 0x10, 0 }
-static void
-lpe_watchdog(struct lpe_softc *sc)
+static int lpc_eth_phy_up(lpc_eth_driver_entry *e)
+ int eno;
+ int retries = 64;
+ uint32_t val;
+ e->phy = DEFAULT_PHY - 1;
+ while (true) {
+ e->phy = (e->phy + 1) % 32;
+ --retries;
+ eno = lpc_eth_phy_get_id(e->phy, &e->phy_id);
+ if (
+ (eno == 0 && e->phy_id != 0xfffffff0 && e->phy_id != 0)
+ || retries <= 0
+ break;
+ LPC_ETH_PRINTF("lpc_eth_phy_get_id: 0x%08" PRIx32 " from phy %d retries %d\n",
+ e->phy_id, e->phy, retries);
+ if (eno == 0) {
+ switch (e->phy_id) {
+ case PHY_KSZ80X1RNL:
+ eno = lpc_eth_phy_set_and_clear(
+ e,
+ &lpc_eth_phy_up_pre_action_KSZ80X1RNL [0],
+ RTEMS_ARRAY_SIZE(lpc_eth_phy_up_pre_action_KSZ80X1RNL)
+ break;
+ case PHY_DP83848:
+ eno = lpc_eth_mdio_read(e->phy, NULL, 0x17, &val);
+ LPC_ETH_PRINTF("phy PHY_DP83848 RBR 0x%08" PRIx32 "\n", val);
+ /* val = 0x21; */
+ val = 0x32 ;
+ eno = lpc_eth_mdio_write(e->phy, NULL, 0x17, val);
+ break;
+ case 0:
+ case 0xfffffff0:
+ eno = EIO;
+ e->phy = DEFAULT_PHY;
+ break;
+ default:
+ break;
+ if (eno == 0) {
+ e,
+ &lpc_eth_phy_up_action_default [0],
+ RTEMS_ARRAY_SIZE(lpc_eth_phy_up_action_default)
+ if (eno == 0) {
+ e,
+ &lpc_eth_phy_up_post_action_KSZ80X1RNL [0],
+ RTEMS_ARRAY_SIZE(lpc_eth_phy_up_post_action_KSZ80X1RNL)
+ break;
+ default:
+ break;
+ } else {
+ e->phy_id = 0;
+ return eno;
- if (sc->lpe_watchdog_timer == 0 || sc->lpe_watchdog_timer--)
- return;
+static const lpc_eth_phy_action lpc_eth_phy_down_action_default [] = {
+ { MII_BMCR, BMCR_PDOWN, 0 }
- /* Chip has stopped responding */
- device_printf(sc->lpe_dev, "WARNING: chip hangup, restarting...\n");
+static const lpc_eth_phy_action lpc_eth_phy_down_post_action_KSZ80X1RNL [] = {
+ /* Enable slow oscillator mode */
+ { 0x11, 0x10, 0 }
- /* Try to resend packets */
- if (!IFQ_DRV_IS_EMPTY(&ifp->if_snd))
+static void lpc_eth_phy_down(lpc_eth_driver_entry *e)
+ int eno = lpc_eth_phy_set_and_clear(
+ e,
+ &lpc_eth_phy_down_action_default [0],
+ RTEMS_ARRAY_SIZE(lpc_eth_phy_down_action_default)
+ if (eno == 0) {
+ e,
+ &lpc_eth_phy_down_post_action_KSZ80X1RNL [0],
+ RTEMS_ARRAY_SIZE(lpc_eth_phy_down_post_action_KSZ80X1RNL)
+ break;
+ default:
+ break;
-static int
-lpe_dma_alloc(struct lpe_softc *sc)
+static void lpc_eth_soft_reset(void)
- int err;
- /* Create parent DMA tag */
- err = bus_dma_tag_create(
- bus_get_dma_tag(sc->lpe_dev),
- 1, 0, /* alignment, boundary */
- BUS_SPACE_MAXADDR_32BIT, /* lowaddr */
- BUS_SPACE_MAXADDR, /* highaddr */
- NULL, NULL, /* filter, filterarg */
- BUS_SPACE_MAXSIZE_32BIT, 0, /* maxsize, nsegments */
- BUS_SPACE_MAXSIZE_32BIT, 0, /* maxsegsize, flags */
- NULL, NULL, /* lockfunc, lockarg */
- &sc->lpe_cdata.lpe_parent_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create parent DMA tag\n");
- return (err);
- err = lpe_dma_alloc_rx(sc);
- if (err)
- return (err);
- err = lpe_dma_alloc_tx(sc);
- if (err)
- return (err);
- return (0);
+ lpc_eth->command = 0x38;
+ lpc_eth->mac1 = 0xcf00;
+ lpc_eth->mac1 = 0x0;
-static int
-lpe_dma_alloc_rx(struct lpe_softc *sc)
+static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
- struct lpe_dmamap_arg ctx;
- int err, i;
- /* Create tag for Rx ring */
- sc->lpe_cdata.lpe_parent_tag,
- LPE_DESC_ALIGN, 0, /* alignment, boundary */
- BUS_SPACE_MAXADDR, /* lowaddr */
- LPE_RXDESC_SIZE, 1, /* maxsize, nsegments */
- LPE_RXDESC_SIZE, 0, /* maxsegsize, flags */
- &sc->lpe_cdata.lpe_rx_ring_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Rx ring DMA tag\n");
- goto fail;
- /* Create tag for Rx status ring */
- LPE_RXSTATUS_SIZE, 1, /* maxsize, nsegments */
- LPE_RXSTATUS_SIZE, 0, /* maxsegsize, flags */
- &sc->lpe_cdata.lpe_rx_status_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Rx status ring DMA tag\n");
- goto fail;
- /* Create tag for Rx buffers */
- MCLBYTES * LPE_RXDESC_NUM, /* maxsize */
- LPE_RXDESC_NUM, /* segments */
- MCLBYTES, 0, /* maxsegsize, flags */
- &sc->lpe_cdata.lpe_rx_buf_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Rx buffers DMA tag\n");
- goto fail;
- /* Allocate Rx DMA ring */
- err = bus_dmamem_alloc(sc->lpe_cdata.lpe_rx_ring_tag,
- (void **)&sc->lpe_rdata.lpe_rx_ring, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
- BUS_DMA_ZERO, &sc->lpe_cdata.lpe_rx_ring_map);
- err = bus_dmamap_load(sc->lpe_cdata.lpe_rx_ring_tag,
- sc->lpe_cdata.lpe_rx_ring_map, sc->lpe_rdata.lpe_rx_ring,
- LPE_RXDESC_SIZE, lpe_dmamap_cb, &ctx, 0);
- sc->lpe_rdata.lpe_rx_ring_phys = ctx.lpe_dma_busaddr;
- /* Allocate Rx status ring */
- err = bus_dmamem_alloc(sc->lpe_cdata.lpe_rx_status_tag,
- (void **)&sc->lpe_rdata.lpe_rx_status, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
- BUS_DMA_ZERO, &sc->lpe_cdata.lpe_rx_status_map);
- err = bus_dmamap_load(sc->lpe_cdata.lpe_rx_status_tag,
- sc->lpe_cdata.lpe_rx_status_map, sc->lpe_rdata.lpe_rx_status,
- sc->lpe_rdata.lpe_rx_status_phys = ctx.lpe_dma_busaddr;
- /* Create Rx buffers DMA map */
- for (i = 0; i < LPE_RXDESC_NUM; i++) {
- rxd = &sc->lpe_cdata.lpe_rx_desc[i];
- rxd->lpe_rxdesc_mbuf = NULL;
-#ifndef __rtems__
- rxd->lpe_rxdesc_dmamap = NULL;
- err = bus_dmamap_create(sc->lpe_cdata.lpe_rx_buf_tag, 0,
- &rxd->lpe_rxdesc_dmamap);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Rx DMA map\n");
- return (err);
- return (0);
-fail:
- return (err);
+ int eno = 0;
+ if (up && e->state == LPC_ETH_STATE_DOWN) {
+ lpc_eth_config_module_enable();
+ /* Enable RX/TX reset and disable soft reset */
+ lpc_eth->mac1 = 0xf00;
+ /* Initialize PHY */
+ /* Clock value 10 (divide by 44 ) is safe on LPC178x up to 100 MHz AHB clock */
+ lpc_eth->mcfg = ETH_MCFG_CLOCK_SELECT(10) | ETH_MCFG_RESETMIIMGMT;
+ lpc_eth->mcfg = ETH_MCFG_CLOCK_SELECT(10);
+ eno = lpc_eth_phy_up(e);
+ if (eno == 0) {
+ * We must have a valid external clock from the PHY at this point,
+ * otherwise the system bus hangs and only a watchdog reset helps.
+ lpc_eth_soft_reset();
+ /* Reinitialize registers */
+ lpc_eth->mac2 = 0x31;
+ lpc_eth->ipgt = 0x15;
+ lpc_eth->ipgr = 0x12;
+ lpc_eth->clrt = 0x370f;
+ lpc_eth->maxf = 0x0600;
+ lpc_eth->supp = ETH_SUPP_SPEED;
+ lpc_eth->test = 0;
+ #ifdef LPC_ETH_CONFIG_RMII
+ lpc_eth->command = 0x0600;
+ #else
+ lpc_eth->command = 0x0400;
+ #endif
+ lpc_eth->intenable = ETH_INT_RX_OVERRUN | ETH_INT_TX_UNDERRUN;
+ lpc_eth->intclear = 0x30ff;
+ lpc_eth->powerdown = 0;
+ /* MAC address */
+ lpc_eth->sa0 = ((uint32_t) e->arpcom.ac_enaddr [5] << 8)
+ | (uint32_t) e->arpcom.ac_enaddr [4];
+ lpc_eth->sa1 = ((uint32_t) e->arpcom.ac_enaddr [3] << 8)
+ | (uint32_t) e->arpcom.ac_enaddr [2];
+ lpc_eth->sa2 = ((uint32_t) e->arpcom.ac_enaddr [1] << 8)
+ | (uint32_t) e->arpcom.ac_enaddr [0];
+ lpc_eth->mac1 = 0x03;
+ /* Initialize tasks */
+ lpc_eth_control_request(e, e->receive_task, LPC_ETH_EVENT_INITIALIZE);
+ lpc_eth_control_request(e, e->transmit_task, LPC_ETH_EVENT_INITIALIZE);
+ /* Install interrupt handler */
+ sc = rtems_interrupt_handler_install(
+ e->interrupt_number,
+ "Ethernet",
+ RTEMS_INTERRUPT_UNIQUE,
+ lpc_eth_interrupt_handler,
+ e
+ /* Start watchdog timer */
+ ifp->if_timer = 1;
+ /* Change state */
+ e->state = LPC_ETH_STATE_UP;
+ if (eno != 0) {
+ ifp->if_flags &= ~IFF_UP;
+ } else if (!up && e->state == LPC_ETH_STATE_UP) {
+ /* Remove interrupt handler */
+ sc = rtems_interrupt_handler_remove(
+ e
+ /* Stop tasks */
+ lpc_eth_control_request(e, e->receive_task, LPC_ETH_EVENT_STOP);
+ lpc_eth_control_request(e, e->transmit_task, LPC_ETH_EVENT_STOP);
+ lpc_eth_phy_down(e);
+ lpc_eth_config_module_disable();
+ /* Stop watchdog timer */
+ ifp->if_timer = 0;
+ e->state = LPC_ETH_STATE_DOWN;
+ return eno;
-static int
-lpe_dma_alloc_tx(struct lpe_softc *sc)
+static void lpc_eth_interface_init(void *arg)
- int err, i;
- /* Create tag for Tx ring */
- LPE_TXDESC_SIZE, 1, /* maxsize, nsegments */
- LPE_TXDESC_SIZE, 0, /* maxsegsize, flags */
- &sc->lpe_cdata.lpe_tx_ring_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Tx ring DMA tag\n");
- goto fail;
- /* Create tag for Tx status ring */
- LPE_TXSTATUS_SIZE, 1, /* maxsize, nsegments */
- LPE_TXSTATUS_SIZE, 0, /* maxsegsize, flags */
- &sc->lpe_cdata.lpe_tx_status_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Tx status ring DMA tag\n");
- goto fail;
- /* Create tag for Tx buffers */
- MCLBYTES * LPE_TXDESC_NUM, /* maxsize */
- LPE_TXDESC_NUM, /* segments */
- &sc->lpe_cdata.lpe_tx_buf_tag);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Tx buffers DMA tag\n");
- goto fail;
- /* Allocate Tx DMA ring */
- err = bus_dmamem_alloc(sc->lpe_cdata.lpe_tx_ring_tag,
- (void **)&sc->lpe_rdata.lpe_tx_ring, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
- BUS_DMA_ZERO, &sc->lpe_cdata.lpe_tx_ring_map);
- err = bus_dmamap_load(sc->lpe_cdata.lpe_tx_ring_tag,
- sc->lpe_cdata.lpe_tx_ring_map, sc->lpe_rdata.lpe_tx_ring,
- sc->lpe_rdata.lpe_tx_ring_phys = ctx.lpe_dma_busaddr;
- /* Allocate Tx status ring */
- err = bus_dmamem_alloc(sc->lpe_cdata.lpe_tx_status_tag,
- (void **)&sc->lpe_rdata.lpe_tx_status, BUS_DMA_WAITOK | BUS_DMA_COHERENT |
- BUS_DMA_ZERO, &sc->lpe_cdata.lpe_tx_status_map);
- err = bus_dmamap_load(sc->lpe_cdata.lpe_tx_status_tag,
- sc->lpe_cdata.lpe_tx_status_map, sc->lpe_rdata.lpe_tx_status,
- sc->lpe_rdata.lpe_tx_status_phys = ctx.lpe_dma_busaddr;
- /* Create Tx buffers DMA map */
- for (i = 0; i < LPE_TXDESC_NUM; i++) {
- txd = &sc->lpe_cdata.lpe_tx_desc[i];
-#ifndef __rtems__
- txd->lpe_txdesc_dmamap = NULL;
-#ifndef __rtems__
- err = bus_dmamap_create(sc->lpe_cdata.lpe_tx_buf_tag, 0,
- &txd->lpe_txdesc_dmamap);
- if (err) {
- device_printf(sc->lpe_dev, "cannot create Tx DMA map\n");
- return (err);
- return (0);
-fail:
- return (err);
+ /* Nothing to do */
-static int
-lpe_init_rx(struct lpe_softc *sc)
+static void lpc_eth_interface_stats(lpc_eth_driver_entry *e)
- int i, err;
- err = lpe_init_rxbuf(sc, i);
- if (err)
- return (err);
- return (0);
+ int eno = EIO;
+ int media = 0;
+ if (e->state == LPC_ETH_STATE_UP) {
+ media = IFM_MAKEWORD(0, 0, 0, 0);
+ eno = rtems_mii_ioctl(&e->mdio, e, SIOCGIFMEDIA, &media);
+ rtems_bsdnet_semaphore_release();
+ if (eno == 0) {
+ rtems_ifmedia2str(media, NULL, 0);
+ printf("\n");
+ printf("received frames: %u\n", e->received_frames);
+ printf("receive interrupts: %u\n", e->receive_interrupts);
+ printf("transmitted frames: %u\n", e->transmitted_frames);
+ printf("transmit interrupts: %u\n", e->transmit_interrupts);
+ printf("receive drop errors: %u\n", e->receive_drop_errors);
+ printf("receive overrun errors: %u\n", e->receive_overrun_errors);
+ printf("receive fragment errors: %u\n", e->receive_fragment_errors);
+ printf("receive CRC errors: %u\n", e->receive_crc_errors);
+ printf("receive symbol errors: %u\n", e->receive_symbol_errors);
+ printf("receive length errors: %u\n", e->receive_length_errors);
+ printf("receive alignment errors: %u\n", e->receive_alignment_errors);
+ printf("receive no descriptor errors: %u\n", e->receive_no_descriptor_errors);
+ printf("receive fatal errors: %u\n", e->receive_fatal_errors);
+ printf("transmit underrun errors: %u\n", e->transmit_underrun_errors);
+ printf("transmit late collision errors: %u\n", e->transmit_late_collision_errors);
+ printf("transmit excessive collision errors: %u\n", e->transmit_excessive_collision_errors);
+ printf("transmit excessive defer errors: %u\n", e->transmit_excessive_defer_errors);
+ printf("transmit no descriptor errors: %u\n", e->transmit_no_descriptor_errors);
+ printf("transmit overflow errors: %u\n", e->transmit_overflow_errors);
+ printf("transmit fatal errors: %u\n", e->transmit_fatal_errors);
+ rtems_bsdnet_semaphore_obtain();
-static int
-lpe_init_rxbuf(struct lpe_softc *sc, int n)
+static int lpc_eth_multicast_control(
+ bool add,
+ struct ifreq *ifr,
+ struct arpcom *ac
-#ifndef __rtems__
- struct mbuf *m;
- bus_dma_segment_t segs[1];
-#ifndef __rtems__
- int nsegs;
- rxd = &sc->lpe_cdata.lpe_rx_desc[n];
- hwd = &sc->lpe_rdata.lpe_rx_ring[n];
-#ifndef __rtems__
- hws = &sc->lpe_rdata.lpe_rx_status[n];
- m = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
- if (!m) {
- device_printf(sc->lpe_dev, "WARNING: mbufs exhausted!\n");
- return (ENOBUFS);
- m->m_len = m->m_pkthdr.len = MCLBYTES;
-#ifndef __rtems__
- bus_dmamap_unload(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap);
- if (bus_dmamap_load_mbuf_sg(sc->lpe_cdata.lpe_rx_buf_tag,
- rxd->lpe_rxdesc_dmamap, m, segs, &nsegs, 0)) {
- m_freem(m);
- return (ENOBUFS);
- bus_dmamap_sync(sc->lpe_cdata.lpe_rx_buf_tag, rxd->lpe_rxdesc_dmamap,
-#endif
- segs[0].ds_addr = mtod(m, bus_addr_t);
- rxd->lpe_rxdesc_mbuf = m;
- hwd->lhr_data = segs[0].ds_addr + 2;
- hwd->lhr_control = (segs[0].ds_len - 1) | LPE_HWDESC_INTERRUPT;
-#ifdef __rtems__
-#endif
- return (0);
+ int eno = 0;
+ if (add) {
+ eno = ether_addmulti(ifr, ac);
+ } else {
+ eno = ether_delmulti(ifr, ac);
+ if (eno == ENETRESET) {
+ struct ether_multistep step;
+ struct ether_multi *enm;
+ eno = 0;
+ lpc_eth->hashfilterl = 0;
+ lpc_eth->hashfilterh = 0;
+ ETHER_FIRST_MULTI(step, ac, enm);
+ while (enm != NULL) {
+ uint64_t addrlo = 0;
+ uint64_t addrhi = 0;
+ memcpy(&addrlo, enm->enm_addrlo, ETHER_ADDR_LEN);
+ memcpy(&addrhi, enm->enm_addrhi, ETHER_ADDR_LEN);
+ while (addrlo <= addrhi) {
+ /* XXX: ether_crc32_le() does not work, why? */
+ uint32_t crc = ether_crc32_be((uint8_t *) &addrlo, ETHER_ADDR_LEN);
+ uint32_t index = (crc >> 23) & 0x3f;
+ if (index < 32) {
+ lpc_eth->hashfilterl |= 1U << index;
+ } else {
+ lpc_eth->hashfilterh |= 1U << (index - 32);
+ ++addrlo;
+ ETHER_NEXT_MULTI(step, enm);
+ return eno;
-static void
-lpe_discard_rxbuf(struct lpe_softc *sc, int n)
+static int lpc_eth_interface_ioctl(
+ ioctl_command_t cmd,
+ caddr_t data
+ lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) ifp->if_softc;
+ struct ifreq *ifr = (struct ifreq *) data;
+ int eno = 0;
+ switch (cmd) {
+ case SIOCGIFMEDIA:
+ case SIOCSIFMEDIA:
+ rtems_mii_ioctl(&e->mdio, e, cmd, &ifr->ifr_media);
+ break;
+ case SIOCGIFADDR:
+ case SIOCSIFADDR:
+ ether_ioctl(ifp, cmd, data);
+ break;
+ case SIOCSIFFLAGS:
+ eno = lpc_eth_up_or_down(e, (ifp->if_flags & IFF_UP) != 0);
+ if (eno == 0 && (ifp->if_flags & IFF_UP) != 0) {
+ lpc_eth_enable_promiscous_mode((ifp->if_flags & IFF_PROMISC) != 0);
+ break;
+ case SIOCADDMULTI:
+ case SIOCDELMULTI:
+ eno = lpc_eth_multicast_control(cmd == SIOCADDMULTI, ifr, &e->arpcom);
+ break;
+ case SIO_RTEMS_SHOW_STATS:
+ lpc_eth_interface_stats(e);
+ break;
+ default:
+ eno = EINVAL;
+ break;
+ return eno;
-#ifndef __rtems__
+static void lpc_eth_interface_start(struct ifnet *ifp)
- hwd->lhr_data = 0;
- hwd->lhr_control = 0;
+ ifp->if_flags |= IFF_OACTIVE;
- if (rxd->lpe_rxdesc_mbuf) {
- m_freem(rxd->lpe_rxdesc_mbuf);
+ sc = rtems_bsdnet_event_send(e->transmit_task, LPC_ETH_EVENT_TXSTART);
-static void
-lpe_dmamap_cb(void *arg, bus_dma_segment_t *segs, int nseg, int error)
+static void lpc_eth_interface_watchdog(struct ifnet *ifp)
- struct lpe_dmamap_arg *ctx;
- if (error)
- return;
- ctx = (struct lpe_dmamap_arg *)arg;
- ctx->lpe_dma_busaddr = segs[0].ds_addr;
+ uint32_t anlpar = lpc_eth_mdio_read_anlpar(e->phy);
+ if (e->anlpar != anlpar) {
+ bool full_duplex = false;
+ bool speed = false;
+ e->anlpar = anlpar;
+ if ((anlpar & ANLPAR_TX_FD) != 0) {
+ full_duplex = true;
+ speed = true;
+ } else if ((anlpar & ANLPAR_T4) != 0) {
+ speed = true;
+ } else if ((anlpar & ANLPAR_TX) != 0) {
+ speed = true;
+ } else if ((anlpar & ANLPAR_10_FD) != 0) {
+ if (full_duplex) {
+ lpc_eth->mac2 |= ETH_MAC2_FULL_DUPLEX;
+ } else {
+ lpc_eth->mac2 &= ~ETH_MAC2_FULL_DUPLEX;
+ if (speed) {
+ lpc_eth->supp |= ETH_SUPP_SPEED;
+ } else {
+ lpc_eth->supp &= ~ETH_SUPP_SPEED;
+ ifp->if_timer = WATCHDOG_TIMEOUT;
-static int
-lpe_ifmedia_upd(struct ifnet *ifp)
+static unsigned lpc_eth_fixup_unit_count(int count, int default_value, int max)
- return (0);
+ if (count <= 0) {
+ count = default_value;
+ } else if (count > max) {
+ count = max;
+ return LPC_ETH_CONFIG_UNIT_MULTIPLE
+ + (((unsigned) count - 1U) & ~(LPC_ETH_CONFIG_UNIT_MULTIPLE - 1U));
-static void
-lpe_ifmedia_sts(struct ifnet *ifp, struct ifmediareq *ifmr)
+static int lpc_eth_attach(struct rtems_bsdnet_ifconfig *config)
- lpe_lock(sc);
- mii_pollstat(mii);
- ifmr->ifm_active = mii->mii_media_active;
- ifmr->ifm_status = mii->mii_media_status;
- lpe_unlock(sc);
+ lpc_eth_driver_entry *e = &lpc_eth_driver_data;
+ char *unit_name = NULL;
+ int unit_index = rtems_bsdnet_parse_driver_name(config, &unit_name);
+ size_t table_area_size = 0;
+ char *table_area = NULL;
+ char *table_location = NULL;
+ /* Check parameter */
+ if (unit_index < 0) {
+ return 0;
+ if (unit_index != 0) {
+ goto cleanup;
+ if (config->hardware_address == NULL) {
+ goto cleanup;
+ if (e->state != LPC_ETH_STATE_NOT_INITIALIZED) {
+ goto cleanup;
+ /* MDIO */
+ e->mdio.mdio_r = lpc_eth_mdio_read;
+ e->mdio.mdio_w = lpc_eth_mdio_write;
+ e->mdio.has_gmii = 0;
+ e->anlpar = 0;
+ /* Interrupt number */
+ config->irno = LPC_ETH_CONFIG_INTERRUPT;
+ /* Device control */
+ config->drv_ctrl = e;
+ /* Receive unit count */
+ e->rx_unit_count = lpc_eth_fixup_unit_count(
+ config->rbuf_count,
+ LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT,
+ LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX
+ config->rbuf_count = (int) e->rx_unit_count;
+ /* Transmit unit count */
+ e->tx_unit_count = lpc_eth_fixup_unit_count(
+ config->xbuf_count,
+ LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT,
+ LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX
+ config->xbuf_count = (int) e->tx_unit_count;
+ /* Remember interrupt number */
+ e->interrupt_number = config->irno;
+ /* Copy MAC address */
+ memcpy(e->arpcom.ac_enaddr, config->hardware_address, ETHER_ADDR_LEN);
+ /* Allocate and clear table area */
+ table_area_size =
+ e->rx_unit_count
+ * (sizeof(lpc_eth_transfer_descriptor)
+ + sizeof(lpc_eth_receive_status)
+ + sizeof(struct mbuf *))
+ + e->tx_unit_count
+ + sizeof(uint32_t)
+ + LPC_ETH_CONFIG_TX_BUF_SIZE);
+ table_area = lpc_eth_config_alloc_table_area(table_area_size);
+ if (table_area == NULL) {
+ goto cleanup;
+ memset(table_area, 0, table_area_size);
+ table_location = table_area;
+ * The receive status table must be the first one since it has the strictest
+ * alignment requirements.
+ e->rx_status_table = (volatile lpc_eth_receive_status *) table_location;
+ table_location += e->rx_unit_count * sizeof(e->rx_status_table [0]);
+ e->rx_desc_table = (volatile lpc_eth_transfer_descriptor *) table_location;
+ table_location += e->rx_unit_count * sizeof(e->rx_desc_table [0]);
+ e->rx_mbuf_table = (struct mbuf **) table_location;
+ table_location += e->rx_unit_count * sizeof(e->rx_mbuf_table [0]);
+ e->tx_desc_table = (volatile lpc_eth_transfer_descriptor *) table_location;
+ table_location += e->tx_unit_count * sizeof(e->tx_desc_table [0]);
+ e->tx_status_table = (volatile uint32_t *) table_location;
+ table_location += e->tx_unit_count * sizeof(e->tx_status_table [0]);
+ e->tx_buf_table = table_location;
+ /* Set interface data */
+ ifp->if_softc = e;
+ ifp->if_unit = (short) unit_index;
+ ifp->if_name = unit_name;
+ ifp->if_mtu = (config->mtu > 0) ? (u_long) config->mtu : ETHERMTU;
+ ifp->if_init = lpc_eth_interface_init;
+ ifp->if_ioctl = lpc_eth_interface_ioctl;
+ ifp->if_start = lpc_eth_interface_start;
+ ifp->if_output = ether_output;
+ ifp->if_watchdog = lpc_eth_interface_watchdog;
+ ifp->if_flags = IFF_MULTICAST | IFF_BROADCAST | IFF_SIMPLEX;
+ ifp->if_snd.ifq_maxlen = ifqmaxlen;
+ /* Create tasks */
+ e->receive_task = rtems_bsdnet_newproc(
+ "ntrx",
+ 4096,
+ lpc_eth_receive_task,
+ e
+ e->transmit_task = rtems_bsdnet_newproc(
+ "nttx",
+ 4096,
+ lpc_eth_transmit_task,
+ e
+ /* Change status */
+ ifp->if_flags |= IFF_RUNNING;
+ /* Attach the interface */
+ if_attach(ifp);
+ ether_ifattach(ifp);
+ return 1;
+cleanup:
+ lpc_eth_config_free_table_area(table_area);
+ /* FIXME: Type */
+ free(unit_name, (int) 0xdeadbeef);
+ return 0;
-static device_method_t lpe_methods[] = {
- /* Device interface */
- DEVMETHOD(device_probe, lpe_probe),
- DEVMETHOD(device_attach, lpe_attach),
- DEVMETHOD(device_detach, lpe_detach),
+static int lpc_eth_detach(
+ struct rtems_bsdnet_ifconfig *config RTEMS_UNUSED
+ /* FIXME: Detach the interface from the upper layers? */
- /* Bus interface */
- DEVMETHOD(bus_print_child, bus_generic_print_child),
+ /* Module soft reset */
- /* MII interface */
- DEVMETHOD(miibus_readreg, lpe_miibus_readreg),
- DEVMETHOD(miibus_writereg, lpe_miibus_writereg),
- DEVMETHOD(miibus_statchg, lpe_miibus_statchg),
- { 0, 0 }
+ /* FIXME: More cleanup */
-static driver_t lpe_driver = {
- "lpe",
- lpe_methods,
- sizeof(struct lpe_softc),
+ return 0;
-static devclass_t lpe_devclass;
-#ifndef __rtems__
-DRIVER_MODULE(lpe, simplebus, lpe_driver, lpe_devclass, 0, 0);
-DRIVER_MODULE(lpe, nexus, lpe_driver, lpe_devclass, 0, 0);
-#endif /* __rtems__ */
-DRIVER_MODULE(miibus, lpe, miibus_driver, miibus_devclass, 0, 0);
-MODULE_DEPEND(lpe, obio, 1, 1, 1);
-MODULE_DEPEND(lpe, miibus, 1, 1, 1);
-MODULE_DEPEND(lpe, ether, 1, 1, 1);
+int lpc_eth_attach_detach(
+ struct rtems_bsdnet_ifconfig *config,
+ int attaching
+ /* FIXME: Return value */
+ if (attaching) {
+ return lpc_eth_attach(config);
+ } else {
+ return lpc_eth_detach(config);
diff --git a/rtemsbsd/sys/arm/lpc/if_lpereg.h b/rtemsbsd/sys/arm/lpc/if_lpereg.h
deleted file mode 100644
index a40bf8b5..00000000
--- a/rtemsbsd/sys/arm/lpc/if_lpereg.h
+++ /dev/null
@@ -1,210 +0,0 @@
- * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
- * Copyright (c) 2011 Jakub Wojciech Klama <jceel at FreeBSD.org>
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifndef _ARM_LPC_IF_LPEREG_H
-#define _ARM_LPC_IF_LPEREG_H
-#define LPE_MAC1 0x000
-#define LPE_MAC1_RXENABLE (1 << 0)
-#define LPE_MAC1_PASSALL (1 << 1)
-#define LPE_MAC1_RXFLOWCTRL (1 << 2)
-#define LPE_MAC1_TXFLOWCTRL (1 << 3)
-#define LPE_MAC1_LOOPBACK (1 << 4)
-#define LPE_MAC1_RESETTX (1 << 8)
-#define LPE_MAC1_RESETMCSTX (1 << 9)
-#define LPE_MAC1_RESETRX (1 << 10)
-#define LPE_MAC1_RESETMCSRX (1 << 11)
-#define LPE_MAC1_SIMRESET (1 << 14)
-#define LPE_MAC1_SOFTRESET (1 << 15)
-#define LPE_MAC2 0x004
-#define LPE_MAC2_FULLDUPLEX (1 << 0)
-#define LPE_MAC2_FRAMELENCHECK (1 << 1)
-#define LPE_MAC2_HUGEFRAME (1 << 2)
-#define LPE_MAC2_DELAYEDCRC (1 << 3)
-#define LPE_MAC2_CRCENABLE (1 << 4)
-#define LPE_MAC2_PADCRCENABLE (1 << 5)
-#define LPE_MAC2_VLANPADENABLE (1 << 6)
-#define LPE_MAC2_AUTOPADENABLE (1 << 7)
-#define LPE_MAC2_PUREPREAMBLE (1 << 8)
-#define LPE_MAC2_LONGPREAMBLE (1 << 9)
-#define LPE_MAC2_NOBACKOFF (1 << 12)
-#define LPE_MAC2_BACKPRESSURE (1 << 13)
-#define LPE_MAC2_EXCESSDEFER (1 << 14)
-#define LPE_IPGT 0x008
-#define LPE_IPGR 0x00c
-#define LPE_CLRT 0x010
-#define LPE_MAXF 0x014
-#define LPE_SUPP 0x018
-#define LPE_SUPP_SPEED (1 << 8)
-#define LPE_TEST 0x01c
-#define LPE_MCFG 0x020
-#define LPE_MCFG_SCANINCR (1 << 0)
-#define LPE_MCFG_SUPPREAMBLE (1 << 1)
-#define LPE_MCFG_CLKSEL(_n) ((_n & 0x7) << 2)
-#define LPC_MCFG_RESETMII (1 << 15)
-#define LPE_MCMD 0x024
-#define LPE_MCMD_READ (1 << 0)
-#define LPE_MCMD_WRITE (0 << 0)
-#define LPE_MCMD_SCAN (1 << 1)
-#define LPE_MADR 0x028
-#define LPE_MADR_REGMASK 0x1f
-#define LPE_MADR_REGSHIFT 0
-#define LPE_MADR_PHYMASK 0x1f
-#define LPE_MADR_PHYSHIFT 8
-#define LPE_MWTD 0x02c
-#define LPE_MWTD_DATAMASK 0xffff
-#define LPE_MRDD 0x030
-#define LPE_MRDD_DATAMASK 0xffff
-#define LPE_MIND 0x034
-#define LPE_MIND_BUSY (1 << 0)
-#define LPE_MIND_SCANNING (1 << 1)
-#define LPE_MIND_INVALID (1 << 2)
-#define LPE_MIND_MIIFAIL (1 << 3)
-#define LPE_SA0 0x040
-#define LPE_SA1 0x044
-#define LPE_SA2 0x048
-#define LPE_COMMAND 0x100
-#define LPE_COMMAND_RXENABLE (1 << 0)
-#define LPE_COMMAND_TXENABLE (1 << 1)
-#define LPE_COMMAND_REGRESET (1 << 3)
-#define LPE_COMMAND_TXRESET (1 << 4)
-#define LPE_COMMAND_RXRESET (1 << 5)
-#define LPE_COMMAND_PASSRUNTFRAME (1 << 6)
-#define LPE_COMMAND_PASSRXFILTER (1 << 7)
-#define LPE_COMMAND_TXFLOWCTL (1 << 8)
-#define LPE_COMMAND_RMII (1 << 9)
-#define LPE_COMMAND_FULLDUPLEX (1 << 10)
-#define LPE_STATUS 0x104
-#define LPE_STATUS_RXACTIVE (1 << 0)
-#define LPE_STATUS_TXACTIVE (1 << 1)
-#define LPE_RXDESC 0x108
-#define LPE_RXSTATUS 0x10c
-#define LPE_RXDESC_NUMBER 0x110
-#define LPE_RXDESC_PROD 0x114
-#define LPE_RXDESC_CONS 0x118
-#define LPE_TXDESC 0x11c
-#define LPE_TXSTATUS 0x120
-#define LPE_TXDESC_NUMBER 0x124
-#define LPE_TXDESC_PROD 0x128
-#define LPE_TXDESC_CONS 0x12c
-#define LPE_TSV0 0x158
-#define LPE_TSV1 0x15c
-#define LPE_RSV 0x160
-#define LPE_FLOWCONTROL_COUNTER 0x170
-#define LPE_FLOWCONTROL_STATUS 0x174
-#define LPE_RXFILTER_CTRL 0x200
-#define LPE_RXFILTER_UNICAST (1 << 0)
-#define LPE_RXFILTER_BROADCAST (1 << 1)
-#define LPE_RXFILTER_MULTICAST (1 << 2)
-#define LPE_RXFILTER_UNIHASH (1 << 3)
-#define LPE_RXFILTER_MULTIHASH (1 << 4)
-#define LPE_RXFILTER_PERFECT (1 << 5)
-#define LPE_RXFILTER_WOL (1 << 12)
-#define LPE_RXFILTER_FILTWOL (1 << 13)
-#define LPE_RXFILTER_WOL_STATUS 0x204
-#define LPE_RXFILTER_WOL_CLEAR 0x208
-#define LPE_HASHFILTER_L 0x210
-#define LPE_HASHFILTER_H 0x214
-#define LPE_INTSTATUS 0xfe0
-#define LPE_INTENABLE 0xfe4
-#define LPE_INTCLEAR 0xfe8
-#define LPE_INTSET 0xfec
-#define LPE_INT_RXOVERRUN (1 << 0)
-#define LPE_INT_RXERROR (1 << 1)
-#define LPE_INT_RXFINISH (1 << 2)
-#define LPE_INT_RXDONE (1 << 3)
-#define LPE_INT_TXUNDERRUN (1 << 4)
-#define LPE_INT_TXERROR (1 << 5)
-#define LPE_INT_TXFINISH (1 << 6)
-#define LPE_INT_TXDONE (1 << 7)
-#define LPE_INT_SOFTINT (1 << 12)
-#define LPE_INTWAKEUPINT (1 << 13)
-#define LPE_POWERDOWN 0xff4
-#define LPE_DESC_ALIGN 8
-#define LPE_TXDESC_NUM 128
-#define LPE_RXDESC_NUM 128
-#define LPE_TXDESC_SIZE (LPE_TXDESC_NUM * sizeof(struct lpe_hwdesc))
-#define LPE_RXDESC_SIZE (LPE_RXDESC_NUM * sizeof(struct lpe_hwdesc))
-#define LPE_TXSTATUS_SIZE (LPE_TXDESC_NUM * sizeof(struct lpe_hwstatus))
-#define LPE_RXSTATUS_SIZE (LPE_RXDESC_NUM * sizeof(struct lpe_hwstatus))
-#define LPE_MAXFRAGS 8
-struct lpe_hwdesc {
- uint32_t lhr_data;
- uint32_t lhr_control;
-struct lpe_hwstatus {
- uint32_t lhs_info;
- uint32_t lhs_crc;
-#define LPE_INC(x, y) (x) = ((x) == ((y)-1)) ? 0 : (x)+1
-/* These are valid for both Rx and Tx descriptors */
-#define LPE_HWDESC_SIZE_MASK (1 << 10)
-#define LPE_HWDESC_INTERRUPT (1U << 31)
-/* These are valid for Tx descriptors */
-#define LPE_HWDESC_LAST (1 << 30)
-#define LPE_HWDESC_CRC (1 << 29)
-#define LPE_HWDESC_PAD (1 << 28)
-#define LPE_HWDESC_HUGE (1 << 27)
-#define LPE_HWDESC_OVERRIDE (1 << 26)
-/* These are valid for Tx status descriptors */
-#define LPE_HWDESC_COLLISIONS(_n) (((_n) >> 21) & 0x7)
-#define LPE_HWDESC_DEFER (1 << 25)
-#define LPE_HWDESC_EXCDEFER (1 << 26)
-#define LPE_HWDESC_EXCCOLL (1 << 27)
-#define LPE_HWDESC_LATECOLL (1 << 28)
-#define LPE_HWDESC_UNDERRUN (1 << 29)
-#define LPE_HWDESC_TXNODESCR (1 << 30)
-#define LPE_HWDESC_ERROR (1U << 31)
-/* These are valid for Rx status descriptors */
-#define LPE_HWDESC_CONTROL (1 << 18)
-#define LPE_HWDESC_VLAN (1 << 19)
-#define LPE_HWDESC_FAILFILTER (1 << 20)
-#define LPE_HWDESC_MULTICAST (1 << 21)
-#define LPE_HWDESC_BROADCAST (1 << 22)
-#define LPE_HWDESC_CRCERROR (1 << 23)
-#define LPE_HWDESC_SYMBOLERROR (1 << 24)
-#define LPE_HWDESC_LENGTHERROR (1 << 25)
-#define LPE_HWDESC_RANGEERROR (1 << 26)
-#define LPE_HWDESC_ALIGNERROR (1 << 27)
-#define LPE_HWDESC_OVERRUN (1 << 28)
-#define LPE_HWDESC_RXNODESCR (1 << 29)
-#define LPE_HWDESC_LASTFLAG (1 << 30)
-#endif /* _ARM_LPC_IF_LPEREG_H */
2.35.3
