[libbsd 01/22] Fix default NET_CFG_NFS_MOUNT_PATH
Fri Jun 24 06:33:29 UTC 2022
The hostname and path must be separated by a ':'.
 waf_libbsd.py | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/waf_libbsd.py b/waf_libbsd.py
index acf93a2f..60ea7535 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -308,7 +308,7 @@ class Builder(builder.ModuleManager):
             'NET_CFG_PEER_IP': { 'mandatory': True },
             'NET_CFG_GATEWAY_IP': { 'manditory': True },
             'NET_CFG_NFS_MOUNT_PATH': { 'mandatory': False,
-                                        'default': '@NET_CFG_PEER_IP@/rtems' },
+                                        'default': '@NET_CFG_PEER_IP@:/rtems' },
             'NET_CFG_NFS_MOUNT_OPTIONS': { 'mandatory': False,
                                            'default': 'nfsv4,minorversion=1' }
2.35.3
