[libbsd 22/22] Disable UNIX Domain Sockets credentials
Sebastian Huber
Fri Jun 24 06:33:50 UTC 2022
freebsd/sys/kern/uipc_usrreq.c | 8 ++++++++
freebsd/sys/sys/unpcb.h | 2 +-
2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/freebsd/sys/kern/uipc_usrreq.c b/freebsd/sys/kern/uipc_usrreq.c
index 47cdcfbd..164f9ee3 100644
--- a/freebsd/sys/kern/uipc_usrreq.c
+++ b/freebsd/sys/kern/uipc_usrreq.c
@@ -1038,7 +1038,9 @@ uipc_listen(struct socket *so, int backlog, struct thread *td)
SOCK_LOCK(so);
error = solisten_proto_check(so);
if (error == 0) {
+#ifndef __rtems__
cru2x(td->td_ucred, &unp->unp_peercred);
+#endif /* __rtems__ */
solisten_proto(so, backlog);
SOCK_UNLOCK(so);
@@ -1566,14 +1568,18 @@ uipc_ctloutput(struct socket *so, struct sockopt *sopt)
switch (sopt->sopt_name) {
case LOCAL_PEERCRED:
UNP_PCB_LOCK(unp);
+#ifndef __rtems__
if (unp->unp_flags & UNP_HAVEPC)
xu = unp->unp_peercred;
else {
if (so->so_type == SOCK_STREAM)
error = ENOTCONN;
else
error = EINVAL;
+#ifndef __rtems__
UNP_PCB_UNLOCK(unp);
if (error == 0)
error = sooptcopyout(sopt, &xu, sizeof(xu));
@@ -1843,6 +1849,7 @@ void
unp_copy_peercred(struct thread *td, struct unpcb *client_unp,
struct unpcb *server_unp, struct unpcb *listen_unp)
+#ifndef __rtems__
cru2x(td->td_ucred, &client_unp->unp_peercred);
client_unp->unp_flags |= UNP_HAVEPC;
@@ -1851,6 +1858,7 @@ unp_copy_peercred(struct thread *td, struct unpcb *client_unp,
server_unp->unp_flags |= UNP_HAVEPC;
if (listen_unp->unp_flags & UNP_WANTCRED)
client_unp->unp_flags |= UNP_WANTCRED;
static int
diff --git a/freebsd/sys/sys/unpcb.h b/freebsd/sys/sys/unpcb.h
index 3ea20b1d..43320481 100644
--- a/freebsd/sys/sys/unpcb.h
+++ b/freebsd/sys/sys/unpcb.h
@@ -80,10 +80,10 @@ struct unpcb {
/* Cache line 2 */
#ifndef __rtems__
struct vnode *unp_vnode; /* if associated with file */
+ struct xucred unp_peercred; /* peer credentials, if applicable */
#else /* __rtems__ */
void *unp_vnode; /* if associated with file */
- struct xucred unp_peercred; /* peer credentials, if applicable */
LIST_ENTRY(unpcb) unp_reflink; /* link in unp_refs list */
LIST_ENTRY(unpcb) unp_link; /* glue on list of all PCBs */
struct unp_head unp_refs; /* referencing socket linked list */
2.35.3
