[PATCH 10/13] bsps/arm/lpc24xx: Change license to BSD-2
Mon Jun 27 13:53:29 UTC 2022
    Updates #3053.
 bsps/arm/lpc24xx/console/console-config.c     | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/console/uart-probe-1.c       | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/console/uart-probe-2.c       | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/console/uart-probe-3.c       | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/fb/lcd.c                     | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp.h                | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/dma.h            | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/io.h             | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/irq.h            | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/lcd.h            | 25 ++++++++++++++++---
 .../lpc24xx/include/bsp/lpc-clock-config.h    | 25 ++++++++++++++++---
 .../lpc24xx/include/bsp/lpc-ethernet-config.h | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/lpc17xx.h        | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/lpc24xx.h        | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/start-config.h   | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/include/bsp/system-clocks.h  | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/irq/irq-dispatch.c           | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/irq/irq.c                    | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/rtc/rtc-config.c             | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/bspidle.c              | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/bspreset-armv4.c       | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/bspstart.c             | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/bspstarthooks.c        | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/dma-copy.c             | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/dma.c                  | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/fb-config.c            | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/io.c                   | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/restart.c              | 25 ++++++++++++++++---
 .../lpc24xx/start/start-config-emc-dynamic.c  | 25 ++++++++++++++++---
 .../lpc24xx/start/start-config-emc-static.c   | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/start-config-mpu.c     | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/start-config-pinsel.c  | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/system-clocks.c        | 25 ++++++++++++++++---
 bsps/arm/lpc24xx/start/timer.c                | 25 ++++++++++++++++---
 34 files changed, 748 insertions(+), 102 deletions(-)
diff --git a/bsps/arm/lpc24xx/console/console-config.c b/bsps/arm/lpc24xx/console/console-config.c
index 2ca3426468..0160bfcd55 100644
--- a/bsps/arm/lpc24xx/console/console-config.c
+++ b/bsps/arm/lpc24xx/console/console-config.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008-2014 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <rtems/console.h>
diff --git a/bsps/arm/lpc24xx/console/uart-probe-1.c b/bsps/arm/lpc24xx/console/uart-probe-1.c
index 8a4c148a0d..b6ec6e1e0d 100644
--- a/bsps/arm/lpc24xx/console/uart-probe-1.c
+++ b/bsps/arm/lpc24xx/console/uart-probe-1.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011-2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <libchip/ns16550.h>
diff --git a/bsps/arm/lpc24xx/console/uart-probe-2.c b/bsps/arm/lpc24xx/console/uart-probe-2.c
index ec6b5d7fe9..b28d1c83f1 100644
--- a/bsps/arm/lpc24xx/console/uart-probe-2.c
+++ b/bsps/arm/lpc24xx/console/uart-probe-2.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/console/uart-probe-3.c b/bsps/arm/lpc24xx/console/uart-probe-3.c
index 643457520f..feaf105635 100644
--- a/bsps/arm/lpc24xx/console/uart-probe-3.c
+++ b/bsps/arm/lpc24xx/console/uart-probe-3.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/fb/lcd.c b/bsps/arm/lpc24xx/fb/lcd.c
index 5973edf577..875d34ae22 100644
--- a/bsps/arm/lpc24xx/fb/lcd.c
+++ b/bsps/arm/lpc24xx/fb/lcd.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2010-2012 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <assert.h>
diff --git a/bsps/arm/lpc24xx/include/bsp.h b/bsps/arm/lpc24xx/include/bsp.h
index 1a3c57f2f8..9dad56476f 100644
--- a/bsps/arm/lpc24xx/include/bsp.h
+++ b/bsps/arm/lpc24xx/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_BSP_H
diff --git a/bsps/arm/lpc24xx/include/bsp/dma.h b/bsps/arm/lpc24xx/include/bsp/dma.h
index ed7022f9a8..85a70d6061 100644
--- a/bsps/arm/lpc24xx/include/bsp/dma.h
+++ b/bsps/arm/lpc24xx/include/bsp/dma.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008, 2009 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_DMA_H
diff --git a/bsps/arm/lpc24xx/include/bsp/io.h b/bsps/arm/lpc24xx/include/bsp/io.h
index a013a9a3ed..51c45e627e 100644
--- a/bsps/arm/lpc24xx/include/bsp/io.h
+++ b/bsps/arm/lpc24xx/include/bsp/io.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009-2012 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_IO_H
diff --git a/bsps/arm/lpc24xx/include/bsp/irq.h b/bsps/arm/lpc24xx/include/bsp/irq.h
index 47e3592575..524a7f1f51 100644
--- a/bsps/arm/lpc24xx/include/bsp/irq.h
+++ b/bsps/arm/lpc24xx/include/bsp/irq.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008-2012 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_IRQ_H
diff --git a/bsps/arm/lpc24xx/include/bsp/lcd.h b/bsps/arm/lpc24xx/include/bsp/lcd.h
index ce0bb873d5..9b342efcae 100644
--- a/bsps/arm/lpc24xx/include/bsp/lcd.h
+++ b/bsps/arm/lpc24xx/include/bsp/lcd.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_LCD_H
diff --git a/bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h b/bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h
index d15b907852..3b466e0be0 100644
--- a/bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h
+++ b/bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_LPC_CLOCK_CONFIG_H
diff --git a/bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h b/bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h
index 667c1cb08a..ffb580a70d 100644
--- a/bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h
+++ b/bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_LPC_ETHERNET_CONFIG_H
diff --git a/bsps/arm/lpc24xx/include/bsp/lpc17xx.h b/bsps/arm/lpc24xx/include/bsp/lpc17xx.h
index 18841744af..af26d3e7f7 100644
--- a/bsps/arm/lpc24xx/include/bsp/lpc17xx.h
+++ b/bsps/arm/lpc24xx/include/bsp/lpc17xx.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LPC17XX_REGS_H
diff --git a/bsps/arm/lpc24xx/include/bsp/lpc24xx.h b/bsps/arm/lpc24xx/include/bsp/lpc24xx.h
index 291f41d06c..7dd84f0b2d 100644
--- a/bsps/arm/lpc24xx/include/bsp/lpc24xx.h
+++ b/bsps/arm/lpc24xx/include/bsp/lpc24xx.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008-2011 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_LPC24XX_H
diff --git a/bsps/arm/lpc24xx/include/bsp/start-config.h b/bsps/arm/lpc24xx/include/bsp/start-config.h
index 1d97d06d19..f56b49ba44 100644
--- a/bsps/arm/lpc24xx/include/bsp/start-config.h
+++ b/bsps/arm/lpc24xx/include/bsp/start-config.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011-2012 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_START_CONFIG_H
diff --git a/bsps/arm/lpc24xx/include/bsp/system-clocks.h b/bsps/arm/lpc24xx/include/bsp/system-clocks.h
index 98eabbc056..68469ae647 100644
--- a/bsps/arm/lpc24xx/include/bsp/system-clocks.h
+++ b/bsps/arm/lpc24xx/include/bsp/system-clocks.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H
diff --git a/bsps/arm/lpc24xx/irq/irq-dispatch.c b/bsps/arm/lpc24xx/irq/irq-dispatch.c
index 6c17d05658..b244b97b8a 100644
--- a/bsps/arm/lpc24xx/irq/irq-dispatch.c
+++ b/bsps/arm/lpc24xx/irq/irq-dispatch.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <rtems/score/armv4.h>
diff --git a/bsps/arm/lpc24xx/irq/irq.c b/bsps/arm/lpc24xx/irq/irq.c
index e19afb633f..a92763131a 100644
--- a/bsps/arm/lpc24xx/irq/irq.c
+++ b/bsps/arm/lpc24xx/irq/irq.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/rtc/rtc-config.c b/bsps/arm/lpc24xx/rtc/rtc-config.c
index a82a857526..94b9dd0a04 100644
--- a/bsps/arm/lpc24xx/rtc/rtc-config.c
+++ b/bsps/arm/lpc24xx/rtc/rtc-config.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
  * Copyright (c) 2008 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <libchip/rtc.h>
diff --git a/bsps/arm/lpc24xx/start/bspidle.c b/bsps/arm/lpc24xx/start/bspidle.c
index b660dc467a..af141da127 100644
--- a/bsps/arm/lpc24xx/start/bspidle.c
+++ b/bsps/arm/lpc24xx/start/bspidle.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/lpc24xx/start/bspreset-armv4.c b/bsps/arm/lpc24xx/start/bspreset-armv4.c
index ca35d0e3c8..3ca07b3b9c 100644
--- a/bsps/arm/lpc24xx/start/bspreset-armv4.c
+++ b/bsps/arm/lpc24xx/start/bspreset-armv4.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2008-2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/arm/lpc24xx/start/bspstart.c b/bsps/arm/lpc24xx/start/bspstart.c
index 4028e845b3..120bf621b7 100644
--- a/bsps/arm/lpc24xx/start/bspstart.c
+++ b/bsps/arm/lpc24xx/start/bspstart.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/lpc24xx/start/bspstarthooks.c b/bsps/arm/lpc24xx/start/bspstarthooks.c
index a1aa051016..2bc7b75fb3 100644
--- a/bsps/arm/lpc24xx/start/bspstarthooks.c
+++ b/bsps/arm/lpc24xx/start/bspstarthooks.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/lpc24xx/start/dma-copy.c b/bsps/arm/lpc24xx/start/dma-copy.c
index 69410ec2cc..462a836343 100644
--- a/bsps/arm/lpc24xx/start/dma-copy.c
+++ b/bsps/arm/lpc24xx/start/dma-copy.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <bsp/lpc24xx.h>
diff --git a/bsps/arm/lpc24xx/start/dma.c b/bsps/arm/lpc24xx/start/dma.c
index d8fa0f8f53..0eaf54d88a 100644
--- a/bsps/arm/lpc24xx/start/dma.c
+++ b/bsps/arm/lpc24xx/start/dma.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <rtems/endian.h>
diff --git a/bsps/arm/lpc24xx/start/fb-config.c b/bsps/arm/lpc24xx/start/fb-config.c
index fd47a89bf7..59821445c4 100644
--- a/bsps/arm/lpc24xx/start/fb-config.c
+++ b/bsps/arm/lpc24xx/start/fb-config.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp/arm-pl111-fb.h>
diff --git a/bsps/arm/lpc24xx/start/io.c b/bsps/arm/lpc24xx/start/io.c
index 413f50da50..6f8fd09d34 100644
--- a/bsps/arm/lpc24xx/start/io.c
+++ b/bsps/arm/lpc24xx/start/io.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/lpc24xx/start/restart.c b/bsps/arm/lpc24xx/start/restart.c
index c5be93b4ae..2a7b0cad2d 100644
--- a/bsps/arm/lpc24xx/start/restart.c
+++ b/bsps/arm/lpc24xx/start/restart.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/start/start-config-emc-dynamic.c b/bsps/arm/lpc24xx/start/start-config-emc-dynamic.c
index 37f299d2ea..8fcab4f3a1 100644
--- a/bsps/arm/lpc24xx/start/start-config-emc-dynamic.c
+++ b/bsps/arm/lpc24xx/start/start-config-emc-dynamic.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011, 2019 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp/start-config.h>
diff --git a/bsps/arm/lpc24xx/start/start-config-emc-static.c b/bsps/arm/lpc24xx/start/start-config-emc-static.c
index 5f39da3a72..6c48586421 100644
--- a/bsps/arm/lpc24xx/start/start-config-emc-static.c
+++ b/bsps/arm/lpc24xx/start/start-config-emc-static.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/start/start-config-mpu.c b/bsps/arm/lpc24xx/start/start-config-mpu.c
index 9a29cecdd9..807eb45257 100644
--- a/bsps/arm/lpc24xx/start/start-config-mpu.c
+++ b/bsps/arm/lpc24xx/start/start-config-mpu.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/start/start-config-pinsel.c b/bsps/arm/lpc24xx/start/start-config-pinsel.c
index be11f4709c..8018b37b2c 100644
--- a/bsps/arm/lpc24xx/start/start-config-pinsel.c
+++ b/bsps/arm/lpc24xx/start/start-config-pinsel.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc24xx/start/system-clocks.c b/bsps/arm/lpc24xx/start/system-clocks.c
index 4d135aa77c..45aa7fe7d6 100644
--- a/bsps/arm/lpc24xx/start/system-clocks.c
+++ b/bsps/arm/lpc24xx/start/system-clocks.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #include <rtems/counter.h>
diff --git a/bsps/arm/lpc24xx/start/timer.c b/bsps/arm/lpc24xx/start/timer.c
index 8512dbc8d5..46cade964c 100644
--- a/bsps/arm/lpc24xx/start/timer.c
+++ b/bsps/arm/lpc24xx/start/timer.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
