[PATCH 11/13] bsps/arm/lpc32xx: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jun 27 13:53:30 UTC 2022
Updates #3053.
bsps/arm/lpc32xx/console/console-config.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/console/hsu.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/i2c/i2c.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/boot.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/emc.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/hsu.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/i2c.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/irq.h | 25 ++++++++++++++++---
.../lpc32xx/include/bsp/lpc-clock-config.h | 25 ++++++++++++++++---
.../lpc32xx/include/bsp/lpc-ethernet-config.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/bsp/mmu.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/include/tm27.h | 25 ++++++++++++++++---
bsps/arm/lpc32xx/irq/irq.c | 25 ++++++++++++++++---
.../lpc32xx/nand/nand-mlc-erase-block-safe.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/nand/nand-mlc.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/nand/nand-select.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/rtc/rtc-config.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/boot.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/bspidle.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/bspreset.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/bspstart.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/bspstarthooks.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/emc.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/restart.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/system-clocks.c | 25 ++++++++++++++++---
bsps/arm/lpc32xx/start/timer.c | 25 ++++++++++++++++---
29 files changed, 638 insertions(+), 87 deletions(-)
diff --git a/bsps/arm/lpc32xx/console/console-config.c b/bsps/arm/lpc32xx/console/console-config.c
index 9d7b76fe9a..f89d8af66e 100644
--- a/bsps/arm/lpc32xx/console/console-config.c
+++ b/bsps/arm/lpc32xx/console/console-config.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2009-2014 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <libchip/ns16550.h>
diff --git a/bsps/arm/lpc32xx/console/hsu.c b/bsps/arm/lpc32xx/console/hsu.c
index 5f0a42a797..9181d6f734 100644
--- a/bsps/arm/lpc32xx/console/hsu.c
+++ b/bsps/arm/lpc32xx/console/hsu.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2010-2014 embedded brains GmbH. All rights reserved.
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/lpc32xx/i2c/i2c.c b/bsps/arm/lpc32xx/i2c/i2c.c
index c17c99d294..14ab508687 100644
--- a/bsps/arm/lpc32xx/i2c/i2c.c
+++ b/bsps/arm/lpc32xx/i2c/i2c.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2010-2011 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/bsps/arm/lpc32xx/include/bsp.h b/bsps/arm/lpc32xx/include/bsp.h
index 91367a4a96..eaa59980a1 100644
--- a/bsps/arm/lpc32xx/include/bsp.h
+++ b/bsps/arm/lpc32xx/include/bsp.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2009-2011 embedded brains GmbH. All rights reserved.
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_BSP_H
diff --git a/bsps/arm/lpc32xx/include/bsp/boot.h b/bsps/arm/lpc32xx/include/bsp/boot.h
index 3f1c3531b2..f8d837460b 100644
--- a/bsps/arm/lpc32xx/include/bsp/boot.h
+++ b/bsps/arm/lpc32xx/include/bsp/boot.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2010 embedded brains GmbH. All rights reserved.
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_BOOT_H
diff --git a/bsps/arm/lpc32xx/include/bsp/emc.h b/bsps/arm/lpc32xx/include/bsp/emc.h
index cb6f00b6c9..0e84ad2031 100644
--- a/bsps/arm/lpc32xx/include/bsp/emc.h
+++ b/bsps/arm/lpc32xx/include/bsp/emc.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_EMC_H
diff --git a/bsps/arm/lpc32xx/include/bsp/hsu.h b/bsps/arm/lpc32xx/include/bsp/hsu.h
index 785de6164c..fc1c9fe101 100644
--- a/bsps/arm/lpc32xx/include/bsp/hsu.h
+++ b/bsps/arm/lpc32xx/include/bsp/hsu.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_HSU_H
diff --git a/bsps/arm/lpc32xx/include/bsp/i2c.h b/bsps/arm/lpc32xx/include/bsp/i2c.h
index 81a04ec4cd..541b282542 100644
--- a/bsps/arm/lpc32xx/include/bsp/i2c.h
+++ b/bsps/arm/lpc32xx/include/bsp/i2c.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_I2C_H
diff --git a/bsps/arm/lpc32xx/include/bsp/irq.h b/bsps/arm/lpc32xx/include/bsp/irq.h
index 255c556a96..ea3c116a58 100644
--- a/bsps/arm/lpc32xx/include/bsp/irq.h
+++ b/bsps/arm/lpc32xx/include/bsp/irq.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2009 embedded brains GmbH. All rights reserved.
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_IRQ_H
diff --git a/bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h b/bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h
index d90c16cdcb..92c07c1b82 100644
--- a/bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h
+++ b/bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_LPC_CLOCK_CONFIG_H
diff --git a/bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h b/bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h
index 790cb72788..bee9f79d50 100644
--- a/bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h
+++ b/bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_LPC_ETHERNET_CONFIG_H
diff --git a/bsps/arm/lpc32xx/include/bsp/mmu.h b/bsps/arm/lpc32xx/include/bsp/mmu.h
index d638bb2c01..5155a97f3a 100644
--- a/bsps/arm/lpc32xx/include/bsp/mmu.h
+++ b/bsps/arm/lpc32xx/include/bsp/mmu.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#ifndef LIBBSP_ARM_LPC32XX_MMU_H
diff --git a/bsps/arm/lpc32xx/include/tm27.h b/bsps/arm/lpc32xx/include/tm27.h
index ae3c471fb1..3708909bb7 100644
--- a/bsps/arm/lpc32xx/include/tm27.h
+++ b/bsps/arm/lpc32xx/include/tm27.h
@@ -1,3 +1,5 @@
/* @file
* @ingroup RTEMSBSPsARMLPC32XX
@@ -8,9 +10,26 @@
+ * are met:
#ifndef _RTEMS_TMTEST27
diff --git a/bsps/arm/lpc32xx/irq/irq.c b/bsps/arm/lpc32xx/irq/irq.c
index 959829b047..18b47fc34a 100644
--- a/bsps/arm/lpc32xx/irq/irq.c
+++ b/bsps/arm/lpc32xx/irq/irq.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (C) 2009, 2022 embedded brains GmbH
+ * are met:
#include <rtems/score/armv4.h>
diff --git a/bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c b/bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c
index b3318ea653..37243ca0ce 100644
--- a/bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c
+++ b/bsps/arm/lpc32xx/nand/nand-mlc-erase-block-safe.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* Copyright (c) 2011 embedded brains GmbH. All rights reserved.
+ * are met:
#include <bsp/nand-mlc.h>
diff --git a/bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c b/bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c
index 671c2ec505..05a710ddc3 100644
--- a/bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c
+++ b/bsps/arm/lpc32xx/nand/nand-mlc-read-blocks.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c b/bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c
index f5157c46e5..934c56f465 100644
--- a/bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c
+++ b/bsps/arm/lpc32xx/nand/nand-mlc-write-blocks.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc32xx/nand/nand-mlc.c b/bsps/arm/lpc32xx/nand/nand-mlc.c
index ed60fa93d0..ed5d265e6b 100644
--- a/bsps/arm/lpc32xx/nand/nand-mlc.c
+++ b/bsps/arm/lpc32xx/nand/nand-mlc.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <bsp/lpc32xx.h>
diff --git a/bsps/arm/lpc32xx/nand/nand-select.c b/bsps/arm/lpc32xx/nand/nand-select.c
index 4f37afa301..426f779f4d 100644
--- a/bsps/arm/lpc32xx/nand/nand-select.c
+++ b/bsps/arm/lpc32xx/nand/nand-select.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/lpc32xx/rtc/rtc-config.c b/bsps/arm/lpc32xx/rtc/rtc-config.c
index 4f5b31f3b1..484c23f6f4 100644
--- a/bsps/arm/lpc32xx/rtc/rtc-config.c
+++ b/bsps/arm/lpc32xx/rtc/rtc-config.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <libchip/rtc.h>
diff --git a/bsps/arm/lpc32xx/start/boot.c b/bsps/arm/lpc32xx/start/boot.c
index ec0d22a6f2..474ff5f65b 100644
--- a/bsps/arm/lpc32xx/start/boot.c
+++ b/bsps/arm/lpc32xx/start/boot.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/arm/lpc32xx/start/bspidle.c b/bsps/arm/lpc32xx/start/bspidle.c
index d6a6c54fef..4556c5b079 100644
--- a/bsps/arm/lpc32xx/start/bspidle.c
+++ b/bsps/arm/lpc32xx/start/bspidle.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/lpc32xx/start/bspreset.c b/bsps/arm/lpc32xx/start/bspreset.c
index 306c86ba2e..110b57bcc4 100644
--- a/bsps/arm/lpc32xx/start/bspreset.c
+++ b/bsps/arm/lpc32xx/start/bspreset.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2009-2010 embedded brains GmbH. All rights reserved.
+ * are met:
#include <stdbool.h>
diff --git a/bsps/arm/lpc32xx/start/bspstart.c b/bsps/arm/lpc32xx/start/bspstart.c
index 1655602528..ec4be955a8 100644
--- a/bsps/arm/lpc32xx/start/bspstart.c
+++ b/bsps/arm/lpc32xx/start/bspstart.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <rtems/counter.h>
diff --git a/bsps/arm/lpc32xx/start/bspstarthooks.c b/bsps/arm/lpc32xx/start/bspstarthooks.c
index cf4f327bd3..4e596d0cc5 100644
--- a/bsps/arm/lpc32xx/start/bspstarthooks.c
+++ b/bsps/arm/lpc32xx/start/bspstarthooks.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2009-2013 embedded brains GmbH. All rights reserved.
+ * are met:
#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
diff --git a/bsps/arm/lpc32xx/start/emc.c b/bsps/arm/lpc32xx/start/emc.c
index 41ae91f32b..c16ea11ca3 100644
--- a/bsps/arm/lpc32xx/start/emc.c
+++ b/bsps/arm/lpc32xx/start/emc.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <bsp/emc.h>
diff --git a/bsps/arm/lpc32xx/start/restart.c b/bsps/arm/lpc32xx/start/restart.c
index 275e8e8403..acb75a7f2d 100644
--- a/bsps/arm/lpc32xx/start/restart.c
+++ b/bsps/arm/lpc32xx/start/restart.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2010, 2011 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/bsps/arm/lpc32xx/start/system-clocks.c b/bsps/arm/lpc32xx/start/system-clocks.c
index 76415d708d..37c3153cf9 100644
--- a/bsps/arm/lpc32xx/start/system-clocks.c
+++ b/bsps/arm/lpc32xx/start/system-clocks.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/lpc32xx/start/timer.c b/bsps/arm/lpc32xx/start/timer.c
index 6f6087760b..7c3ac14d09 100644
--- a/bsps/arm/lpc32xx/start/timer.c
+++ b/bsps/arm/lpc32xx/start/timer.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2008, 2009 embedded brains GmbH. All rights reserved.
+ * are met:
