[PATCH 13/13] bsps/arm/realview-pbx-a9: Change license to BSD-2
Mon Jun 27 13:53:32 UTC 2022
    Updates #3053.
 .../realview-pbx-a9/console/console-config.c  | 25 ++++++++++++++++---
 .../realview-pbx-a9/console/console-polled.c  | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/include/bsp.h        | 25 ++++++++++++++++---
 .../arm/realview-pbx-a9/include/bsp/console.h | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/include/bsp/irq.h    | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/include/tm27.h       | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/start/bspreset.c     | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/start/bspsmp.c       | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/start/bspstart.c     | 25 ++++++++++++++++---
 .../arm/realview-pbx-a9/start/bspstarthooks.c | 25 ++++++++++++++++---
 bsps/arm/realview-pbx-a9/start/fb-config.c    | 25 ++++++++++++++++---
 11 files changed, 242 insertions(+), 33 deletions(-)
diff --git a/bsps/arm/realview-pbx-a9/console/console-config.c b/bsps/arm/realview-pbx-a9/console/console-config.c
index 73523660a5..17fe7ef3cb 100644
--- a/bsps/arm/realview-pbx-a9/console/console-config.c
+++ b/bsps/arm/realview-pbx-a9/console/console-config.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <rtems/serial_mouse.h>
diff --git a/bsps/arm/realview-pbx-a9/console/console-polled.c b/bsps/arm/realview-pbx-a9/console/console-polled.c
index 2b6044846c..25f4583cf2 100644
--- a/bsps/arm/realview-pbx-a9/console/console-polled.c
+++ b/bsps/arm/realview-pbx-a9/console/console-polled.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp/console.h>
diff --git a/bsps/arm/realview-pbx-a9/include/bsp.h b/bsps/arm/realview-pbx-a9/include/bsp.h
index 39023c3c91..d49c97663a 100644
--- a/bsps/arm/realview-pbx-a9/include/bsp.h
+++ b/bsps/arm/realview-pbx-a9/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_REALVIEW_PBX_A9_BSP_H
diff --git a/bsps/arm/realview-pbx-a9/include/bsp/console.h b/bsps/arm/realview-pbx-a9/include/bsp/console.h
index b4b95ba84b..f153eaa2d5 100644
--- a/bsps/arm/realview-pbx-a9/include/bsp/console.h
+++ b/bsps/arm/realview-pbx-a9/include/bsp/console.h
@@ -1,9 +1,28 @@
  * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_REALVIEW_PBX_A9_BSP_CONSOLE_H
diff --git a/bsps/arm/realview-pbx-a9/include/bsp/irq.h b/bsps/arm/realview-pbx-a9/include/bsp/irq.h
index 4d5836725e..adb548c33f 100644
--- a/bsps/arm/realview-pbx-a9/include/bsp/irq.h
+++ b/bsps/arm/realview-pbx-a9/include/bsp/irq.h
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_REALVIEW_PBX_A9_IRQ_H
diff --git a/bsps/arm/realview-pbx-a9/include/tm27.h b/bsps/arm/realview-pbx-a9/include/tm27.h
index cabc19b2e9..f2a5d1f070 100644
--- a/bsps/arm/realview-pbx-a9/include/tm27.h
+++ b/bsps/arm/realview-pbx-a9/include/tm27.h
@@ -1,3 +1,5 @@
  * @file
@@ -18,9 +20,26 @@
+ * are met:
 #ifndef _RTEMS_TMTEST27
diff --git a/bsps/arm/realview-pbx-a9/start/bspreset.c b/bsps/arm/realview-pbx-a9/start/bspreset.c
index 31150ab5eb..154efd22d7 100644
--- a/bsps/arm/realview-pbx-a9/start/bspreset.c
+++ b/bsps/arm/realview-pbx-a9/start/bspreset.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/bootcard.h>
diff --git a/bsps/arm/realview-pbx-a9/start/bspsmp.c b/bsps/arm/realview-pbx-a9/start/bspsmp.c
index 21ea37e046..99d1f35c6a 100644
--- a/bsps/arm/realview-pbx-a9/start/bspsmp.c
+++ b/bsps/arm/realview-pbx-a9/start/bspsmp.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <rtems/score/smpimpl.h>
diff --git a/bsps/arm/realview-pbx-a9/start/bspstart.c b/bsps/arm/realview-pbx-a9/start/bspstart.c
index 563cfb53ee..a018bcc780 100644
--- a/bsps/arm/realview-pbx-a9/start/bspstart.c
+++ b/bsps/arm/realview-pbx-a9/start/bspstart.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/realview-pbx-a9/start/bspstarthooks.c b/bsps/arm/realview-pbx-a9/start/bspstarthooks.c
index 64b74095f3..f0c126df5a 100644
--- a/bsps/arm/realview-pbx-a9/start/bspstarthooks.c
+++ b/bsps/arm/realview-pbx-a9/start/bspstarthooks.c
@@ -1,9 +1,28 @@
+ * are met:
 #define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
diff --git a/bsps/arm/realview-pbx-a9/start/fb-config.c b/bsps/arm/realview-pbx-a9/start/fb-config.c
index ce60a51860..b3f2077c88 100644
--- a/bsps/arm/realview-pbx-a9/start/fb-config.c
+++ b/bsps/arm/realview-pbx-a9/start/fb-config.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/arm-pl111-fb.h>
2.24.4
