[PATCH 12/13] bsps/arm/raspberrypi: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jun 27 13:53:31 UTC 2022
Updates #3053.
bsps/arm/raspberrypi/start/bspsmp.c | 25 +++++++++++++++++++++---
bsps/arm/raspberrypi/start/bspsmp_init.c | 25 +++++++++++++++++++++---
2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/bsps/arm/raspberrypi/start/bspsmp.c b/bsps/arm/raspberrypi/start/bspsmp.c
index 9dcfb0fb03..0ea54c1442 100644
--- a/bsps/arm/raspberrypi/start/bspsmp.c
+++ b/bsps/arm/raspberrypi/start/bspsmp.c
@@ -1,3 +1,5 @@
* @file
@@ -18,9 +20,26 @@
* GSoC 2015 project and Altera Cyclone-V SMP code
* by embedded brains GmbH
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <rtems/score/smpimpl.h>
diff --git a/bsps/arm/raspberrypi/start/bspsmp_init.c b/bsps/arm/raspberrypi/start/bspsmp_init.c
index eed5b44fa9..600eb63d47 100644
--- a/bsps/arm/raspberrypi/start/bspsmp_init.c
+++ b/bsps/arm/raspberrypi/start/bspsmp_init.c
@@ -1,3 +1,5 @@
* @file
@@ -18,9 +20,26 @@
+ * are met:
2.24.4
