[PATCH] microblaze: Add JFFS2 AXI QSPI driver
Alex White alex.white at oarcorp.com
Thu Mar 3 02:29:48 UTC 2022
This driver has been tested with Micron NOR Flash via AXI Quad SPI.
 .../microblaze_fpga/fs/jffs2_qspi.c           | 319 ++++++++++++++++++
 .../microblaze_fpga/include/bsp/jffs2_qspi.h  |  56 +++
 .../bsps/microblaze/microblaze_fpga/grp.yml   |   6 +
 .../bsps/microblaze/microblaze_fpga/obj.yml   |   2 +
 .../microblaze_fpga/optspibaseaddress.yml     |  18 +
 .../microblaze/microblaze_fpga/optspiirq.yml  |  17 +
 6 files changed, 418 insertions(+)
 create mode 100644 bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
 create mode 100644 bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml
diff --git a/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c b/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
new file mode 100644
index 0000000000..39328b6b7c
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
@@ -0,0 +1,319 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroblaze
+ * @brief MicroBlaze AXI QSPI JFFS2 flash driver implementation
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#include <assert.h>
+#include <errno.h>
+#include <string.h>
+#include <fcntl.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <bspopts.h>
+#include <dev/spi/xilinx-axi-spi.h>
+#include <linux/spi/spidev.h>
+#include <rtems/jffs2.h>
+#include <rtems/libio.h>
+#include <bsp/jffs2_qspi.h>
+#define BLOCK_SIZE (64UL * 1024UL)
+#define FLASH_SIZE (32UL * BLOCK_SIZE)
+#define FLASH_PAGE_SIZE        256
+#define FLASH_NUM_CS           2
+#define FLASH_DEVICE_ID        0xbb19 /* Type: 0xbb, Capacity: 0x19 */
+#define BUS_PATH          "/dev/spi-0"
+#define FLASH_MOUNT_POINT "/mnt"
+#define READ_WRITE_EXTRA_BYTES 4
+#define WRITE_ENABLE_BYTES     1
+#define SECTOR_ERASE_BYTES     4
+#define COMMAND_QUAD_WRITE     0x32
+#define COMMAND_SECTOR_ERASE   0xD8
+#define COMMAND_QUAD_READ      0x6B
+#define COMMAND_STATUSREG_READ 0x05
+#define COMMAND_WRITE_ENABLE   0x06
+#define FLASH_SR_IS_READY_MASK 0x01
+typedef struct {
+  rtems_jffs2_flash_control super;
+  int                       fd;
+} flash_control;
+static uint8_t ReadBuffer[FLASH_PAGE_SIZE + READ_WRITE_EXTRA_BYTES + 4];
+static uint8_t WriteBuffer[FLASH_PAGE_SIZE + READ_WRITE_EXTRA_BYTES + 4];
+static flash_control *get_flash_control( rtems_jffs2_flash_control *super )
+  return (flash_control *) super;
+static int flash_wait_for_ready( flash_control *self )
+  uint8_t rv     = 0;
+  uint8_t status = 0;
+  WriteBuffer[0] = COMMAND_STATUSREG_READ;
+  struct spi_ioc_transfer mesg = {
+    .tx_buf        = WriteBuffer,
+    .rx_buf        = ReadBuffer,
+    .len           = 2,
+    .bits_per_word = 8,
+    .cs            = 0
+  do {
+    rv = ioctl( self->fd, SPI_IOC_MESSAGE( 1 ), &mesg );
+    if ( rv != 0 ) {
+      return -EIO;
+    status = ReadBuffer[1];
+  } while ( (status & FLASH_SR_IS_READY_MASK) != 0 );
+  return 0;
+static int flash_write_enable( flash_control *self )
+  uint8_t rv = 0;
+  rv = flash_wait_for_ready( self );
+  if ( rv != 0 ) {
+    return rv;
+  WriteBuffer[0] = COMMAND_WRITE_ENABLE;
+    .len           = WRITE_ENABLE_BYTES,
+    .cs            = 0
+  if ( rv != 0 ) {
+    return -EIO;
+  return 0;
+static int flash_read(
+  rtems_jffs2_flash_control *super,
+  uint32_t                   offset,
+  unsigned char             *buffer,
+  size_t                     size_of_buffer
+  int rv = 0;
+  uint32_t current_offset = offset;
+  uint32_t bytes_left     = size_of_buffer;
+  flash_control *self = get_flash_control( super );
+  if ( rv != 0 ) {
+    return rv;
+  WriteBuffer[0] = COMMAND_QUAD_READ;
+  /* Read in 256-byte chunks */
+  do {
+    uint32_t chunk_size = bytes_left > FLASH_PAGE_SIZE ? FLASH_PAGE_SIZE : bytes_left;
+      .len           = chunk_size + 8,
+      .cs            = 0
+    WriteBuffer[1] = (uint8_t) (current_offset >> 16);
+    WriteBuffer[2] = (uint8_t) (current_offset >> 8);
+    WriteBuffer[3] = (uint8_t) current_offset;
+    if ( rv != 0 ) {
+      return -EIO;
+    memcpy( &buffer[current_offset - offset], &ReadBuffer[8], chunk_size );
+    current_offset += chunk_size;
+    bytes_left     -= chunk_size;
+  } while ( bytes_left > 0 );
+  return 0;
+static int flash_write(
+  uint32_t                   offset,
+  const unsigned char       *buffer,
+  int rv = 0;
+  rv = flash_write_enable( self );
+  if ( rv != 0 ) {
+    return rv;
+  if ( rv != 0 ) {
+    return rv;
+  WriteBuffer[0] = COMMAND_QUAD_WRITE;
+  WriteBuffer[1] = (uint8_t) (offset >> 16);
+  WriteBuffer[2] = (uint8_t) (offset >> 8);
+  WriteBuffer[3] = (uint8_t) offset;
+  memcpy( &WriteBuffer[4], buffer, size_of_buffer );
+    .len           = size_of_buffer + 4,
+    .cs            = 0
+  if ( rv != 0 ) {
+    return -EIO;
+  return 0;
+static int flash_erase(
+  uint32_t                   offset
+  int rv = 0;
+  if ( rv != 0 ) {
+    return rv;
+  if ( rv != 0 ) {
+    return rv;
+  WriteBuffer[0] = COMMAND_SECTOR_ERASE;
+    .len           = SECTOR_ERASE_BYTES,
+    .cs            = 0
+  if ( rv != 0 ) {
+    return -EIO;
+  return 0;
+static flash_control flash_instance = {
+  .super = {
+    .block_size        = BLOCK_SIZE,
+    .flash_size        = FLASH_SIZE,
+    .read              = flash_read,
+    .write             = flash_write,
+    .erase             = flash_erase,
+    .device_identifier = FLASH_DEVICE_ID
+static rtems_jffs2_mount_data mount_data = {
+  .flash_control      = &flash_instance.super,
+  .compressor_control = NULL
+int microblaze_jffs2_initialize( const char* mount_dir )
+  int rv = 0;
+  int fd = -1;
+  rv = spi_bus_register_xilinx_axi(
+    BUS_PATH,
+    BSP_MICROBLAZE_FPGA_SPI_BASE,
+    FLASH_PAGE_SIZE,
+    FLASH_NUM_CS,
+    BSP_MICROBLAZE_FPGA_SPI_IRQ_NUM
+  if ( rv != 0 ) {
+    return rv;
+  fd = open( BUS_PATH, O_RDWR );
+  if ( fd < 0 ) {
+    return -1;
+  flash_instance.fd = fd;
+  rv = mount_and_make_target_path(
+    NULL,
+    mount_dir,
+    RTEMS_FILESYSTEM_TYPE_JFFS2,
+    RTEMS_FILESYSTEM_READ_WRITE,
+    &mount_data
+  if ( rv != 0 ) {
+    return rv;
+  return 0;
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h b/bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
index 0000000000..9c071c4977
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
@@ -0,0 +1,56 @@
+ * @file
+ * @brief MicroBlaze AXI QSPI JFFS2 flash driver definitions
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H
+#define LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Mount jffs2 filesystem.
+ * @param[in] mount_dir The directory to mount the filesystem at.
+ * @retval 0 Successful operation. Negative number otherwise.
+int microblaze_jffs2_initialize( const char* mount_dir );
+#ifdef __cplusplus
+#endif /* LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H */
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index 11df1802f1..bb9b82c250 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -35,6 +35,10 @@ links:
   uid: optintcbaseaddress
 - role: build-dependency
   uid: optramlen
+- role: build-dependency
+  uid: optspibaseaddress
+  uid: optspiirq
   uid: opttimerbaseaddress
@@ -43,6 +47,8 @@ links:
   uid: optuartlitebaseaddress
   uid: ../../obj
+  uid: ../../objdevspixil
   uid: ../../objirq
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 37096cdc84..993ba04004 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -15,6 +15,7 @@ install:
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/microblaze/microblaze_fpga/include/bsp/irq.h
+  - bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
   - bsps/microblaze/include/common/xil_types.h
   - bsps/microblaze/include/dev/serial/uartlite.h
   - bsps/microblaze/include/dev/serial/uartlite_l.h
@@ -24,6 +25,7 @@ source:
 - bsps/microblaze/microblaze_fpga/console/console-io.c
 - bsps/microblaze/microblaze_fpga/console/debug-io.c
 - bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
+- bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
 - bsps/microblaze/microblaze_fpga/irq/irq.c
 - bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
 - bsps/microblaze/microblaze_fpga/start/_exception_handler.S
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml
index 0000000000..86907b70ab
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optspibaseaddress.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+default: 0x44a00000
+default-by-variant: []
+description: |
+  base address of the AXI Quad SPI
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_SPI_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml
index 0000000000..7186c6b8e1
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optspiirq.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 3
+description: |
+  IRQ number of the AXI SPI
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_SPI_IRQ_NUM
+type: build
2.32.0
