hello world with devfs has no output
Ryan Long ral051 at oarcorp.com
Wed Mar 9 15:43:28 UTC 2022
On 3/7/2022 10:33 AM, Sebastian Huber wrote:
> On 07/03/2022 16:18, Joel Sherrill wrote:
>> On Mon, Mar 7, 2022 at 12:46 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     On 03/03/2022 00:06, Joel Sherrill wrote:
>>      > What's the missing capability now in devfs? This used to work.
>>     Is this problem detected by one of the testsuites/libtests/devfs*
>>     tests?
>>     If not, could you add a test case which shows the problem?
>> It was actually the hello_world_c example from rtems-examples BEFORE
>> this patch from Ryan:
>> https://git.rtems.org/rtems-examples/commit/?id=5799ab5a8c4e5d6de6532ecea3d895bb01cfb9c9
>> <https://git.rtems.org/rtems-examples/commit/?id=5799ab5a8c4e5d6de6532ecea3d895bb01cfb9c9>
>> Pretty minimal. Does it need to be added to the devfs* tests?
> Adding a test case which fails currently would be good.
I've tried to make a new devfs to show this failure, but I can't get it
to produce the same results. Can you take a look at it in rtems-examples?
