[PATCH rtems-lwip] Add missing COPYING files from lwip and uLan
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Mar 4 14:48:44 UTC 2022
These are the original COPYING files from the upstream projects.
COPYING.lwip | 25 +++++++++++++++++++++++++
COPYING.uLan | 33 +++++++++++++++++++++++++++++++++
2 files changed, 58 insertions(+)
create mode 100644 COPYING.lwip
create mode 100644 COPYING.uLan
diff --git a/COPYING.lwip b/COPYING.lwip
new file mode 100644
index 0000000..90465f5
--- /dev/null
+++ b/COPYING.lwip
@@ -0,0 +1,25 @@
+Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
+All rights reserved.
+Redistribution and use in source and binary forms, with or without modification,
+are permitted provided that the following conditions are met:
+1. Redistributions of source code must retain the above copyright notice,
+ this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the above copyright notice,
+ this list of conditions and the following disclaimer in the documentation
+ and/or other materials provided with the distribution.
+3. The name of the author may not be used to endorse or promote products
+ derived from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+OF SUCH DAMAGE.
diff --git a/COPYING.uLan b/COPYING.uLan
index 0000000..e23898b
--- /dev/null
+++ b/COPYING.uLan
@@ -0,0 +1,33 @@
+ * Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+ * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * This file is part of the lwIP TCP/IP stack.
+ * Author: Adam Dunkels <adam at sics.se>
2.30.2
