[PATCH rtems-lwip] Add missing COPYING files from lwip and uLan
Vijay Kumar Banerjee vijay at rtems.org
Fri Mar 4 17:26:04 UTC 2022
Hi Kinsey,
Thanks for the patch.
I was wondering if it would be a good idea to use this patch and add a
comment in the respective source files that they are based on an
external repository and the related copying files are
COPYING.something ?
On Fri, Mar 4, 2022 at 7:49 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> These are the original COPYING files from the upstream projects.
>  COPYING.lwip | 25 +++++++++++++++++++++++++
>  COPYING.uLan | 33 +++++++++++++++++++++++++++++++++
>  2 files changed, 58 insertions(+)
>  create mode 100644 COPYING.lwip
>  create mode 100644 COPYING.uLan
> diff --git a/COPYING.lwip b/COPYING.lwip
> new file mode 100644
> index 0000000..90465f5
> --- /dev/null
> +++ b/COPYING.lwip
> @@ -0,0 +1,25 @@
> +Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> +All rights reserved.
> +Redistribution and use in source and binary forms, with or without modification,
> +are permitted provided that the following conditions are met:
> +1. Redistributions of source code must retain the above copyright notice,
> +   this list of conditions and the following disclaimer.
> +2. Redistributions in binary form must reproduce the above copyright notice,
> +   this list of conditions and the following disclaimer in the documentation
> +   and/or other materials provided with the distribution.
> +3. The name of the author may not be used to endorse or promote products
> +   derived from this software without specific prior written permission.
> +THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
> +WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> +MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
> +SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> +EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> +OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> +IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> +OF SUCH DAMAGE.
> diff --git a/COPYING.uLan b/COPYING.uLan
> index 0000000..e23898b
> --- /dev/null
> +++ b/COPYING.uLan
> @@ -0,0 +1,33 @@
> + * Copyright (c) 2001, 2002 Swedish Institute of Computer Science.
> + * All rights reserved.
> + * Redistribution and use in source and binary forms, with or without modification,
> + * are permitted provided that the following conditions are met:
> + * 1. Redistributions of source code must retain the above copyright notice,
> + *    this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright notice,
> + *    this list of conditions and the following disclaimer in the documentation
> + *    and/or other materials provided with the distribution.
> + * 3. The name of the author may not be used to endorse or promote products
> + *    derived from this software without specific prior written permission.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
> + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> + * OF SUCH DAMAGE.
> + * This file is part of the lwIP TCP/IP stack.
> + * Author: Adam Dunkels <adam at sics.se>
> 2.30.2
> devel mailing list
> devel at rtems.org
