[PATCH 26/40] bsps/m68k: Manual file header clean up
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Mar 7 13:23:24 UTC 2022
Updates #4625.
bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 | 75 +++++++------------
.../genmcf548x/start/linkcmds.m5484FireEngine | 74 +++++++-----------
.../start/linkcmds.m5484FireEngine.flash | 74 +++++++-----------
bsps/m68k/genmcf548x/start/start.S | 70 +++++++----------
bsps/m68k/include/mcf548x/mcdma_glue.h | 32 ++++----
bsps/m68k/include/mcf548x/mcf548x.h | 72 +++++++-----------
6 files changed, 151 insertions(+), 246 deletions(-)
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 b/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
index 6c3a56b5cf..9e446651a5 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
+++ b/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
@@ -1,50 +1,31 @@
-| Project: RTEMS generic mcf548x BSP |
-| File: linkcmds.COBRA5475 |
-| The file contains the linker directives for the generic MCF548x |
-| BSP to be used with an COBRA5475 board to load and execute |
-| code in the RAM. |
-| Copyright (c) 2007 |
-| embedded brains GmbH |
-| Obere Lagerstr. 30 |
-| 82178 Puchheim |
-| Germany |
-| rtems at embedded-brains.de |
-| Parts of the code has been derived from the "dBUG source code" |
-| package Freescale is providing for M548X EVBs. The usage of |
-| the modified or unmodified code and it's integration into the |
-| generic mcf548x BSP has been done according to the Freescale |
-| license terms. |
-| The Freescale license terms can be reviewed in the file |
-| Freescale_license.txt |
-| The generic mcf548x BSP has been developed on the basic |
-| structures and modules of the av5282 BSP. |
-| The license and distribution terms for this file may be |
-| found in the file LICENSE in this distribution or at |
-| http://www.rtems.org/license/LICENSE. |
-| date history ID |
-| 12.11.07 1.0 ras |
-| 15.10.09 1.1, adapted to COBRA5475 doe |
+ * RTEMS generic mcf548x BSP
+ * The file contains the linker directives for the generic MCF548x
+ * BSP to be used with an COBRA5475 board to load and execute
+ * code in the RAM.
+ * Parts of the code has been derived from the "dBUG source code"
+ * package Freescale is providing for M548X EVBs. The usage of
+ * the modified or unmodified code and it's integration into the
+ * generic mcf548x BSP has been done according to the Freescale
+ * license terms.
+ * The Freescale license terms can be reviewed in the file
+ * Freescale_license.txt
+ * The generic mcf548x BSP has been developed on the basic
+ * structures and modules of the av5282 BSP.
+ * Copyright (c) 2007 embedded brains GmbH. All rights reserved.
* Location and size of on-chip devices
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
index b99840197c..fe4566534b 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
+++ b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
@@ -1,49 +1,31 @@
-| File: linkcmd |
-| BSP to be used with an m5484FireEngine EVB to load and execute |
-| 82178 Puchheim |
-| Germany |
-| license terms. |
+ * BSP to be used with an m5484FireEngine EVB to load and execute
+ * license terms.
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
index 8a7051bb63..01f37aa3aa 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
+++ b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
@@ -1,49 +1,31 @@
-| File: linkcmd.m5484FireEngine.flash |
-| code in the boot FLASH. |
-| 82178 Puchheim |
-| Germany |
-| license terms. |
+ * code in the boot FLASH.
+ * license terms.
diff --git a/bsps/m68k/genmcf548x/start/start.S b/bsps/m68k/genmcf548x/start/start.S
index 3b0c3b2264..415d6c2a9d 100644
--- a/bsps/m68k/genmcf548x/start/start.S
+++ b/bsps/m68k/genmcf548x/start/start.S
@@ -1,47 +1,29 @@
-| File: start.S |
-| The file contains the assembly part of MCF548x init code |
-| 82178 Puchheim |
-| Germany |
-| license terms. |
+ * The file contains the assembly part of MCF548x init code.
+ * license terms.
| Includes |
diff --git a/bsps/m68k/include/mcf548x/mcdma_glue.h b/bsps/m68k/include/mcf548x/mcdma_glue.h
index 6235dd0174..775b0486e9 100644
--- a/bsps/m68k/include/mcf548x/mcdma_glue.h
+++ b/bsps/m68k/include/mcf548x/mcdma_glue.h
@@ -1,21 +1,17 @@
-| Project: RTEMS generic MFC548x BSP |
-| Copyright (c) 2004-2009 |
-| 82178 Puchheim |
-| Germany |
-| this file declares glue functions to the Freescale Mcdma API |
+ * This file declares glue functions to the Freescale Mcdma API.
+ * Copyright (c) 2004-2009 embedded brains GmbH. All rights reserved.
#ifndef _MCDMA_GLUE_H
#define _MCDMA_GLUE_H
diff --git a/bsps/m68k/include/mcf548x/mcf548x.h b/bsps/m68k/include/mcf548x/mcf548x.h
index e29122a35f..a8546df018 100644
--- a/bsps/m68k/include/mcf548x/mcf548x.h
+++ b/bsps/m68k/include/mcf548x/mcf548x.h
@@ -1,48 +1,30 @@
-| File: mcf548x.h |
-| The file contains all register an bit definitions of the |
-| generic MCF548x BSP. |
-| 82178 Puchheim |
-| Germany |
-| license terms. |
+ * The file contains all register an bit definitions of the
+ * generic MCF548x BSP.
+ * license terms.
#ifndef __MCF548X_H__
#define __MCF548X_H__
2.34.1
