[PATCH 27/40] bsps/shared: Manual file header clean up
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Mar 7 13:23:25 UTC 2022
Updates #4625.
bsps/shared/dev/display/disp_fonts.h | 32 ++++++++++--------------
bsps/shared/dev/display/disp_hcms29xx.c | 33 +++++++++++--------------
bsps/shared/dev/display/font_hcms29xx.c | 31 ++++++++++-------------
bsps/shared/dev/display/font_hcms29xx.h | 31 ++++++++++-------------
bsps/shared/dev/i2c/spi-flash-m25p40.c | 28 +++++++++------------
bsps/shared/dev/i2c/spi-fram-fm25l256.c | 28 +++++++++------------
bsps/shared/dev/i2c/spi-memdrv.c | 29 +++++++++-------------
7 files changed, 87 insertions(+), 125 deletions(-)
diff --git a/bsps/shared/dev/display/disp_fonts.h b/bsps/shared/dev/display/disp_fonts.h
index b988db531d..49caf05906 100644
--- a/bsps/shared/dev/display/disp_fonts.h
+++ b/bsps/shared/dev/display/disp_fonts.h
@@ -1,22 +1,16 @@
-| Project: display driver for HCMS29xx |
-| File: disp_fonts.h |
-| Copyright (c) 2008 |
-| embedded brains GmbH |
-| Obere Lagerstr. 30 |
-| 82178 Puchheim |
-| Germany |
-| rtems at embedded-brains.de |
-| The license and distribution terms for this file may be |
-| found in the file LICENSE in this distribution or at |
-| http://www.rtems.org/license/LICENSE. |
-| This file declares general data structures for font management |
+ * Display driver for HCMS29xx.
+ * This file declares general data structures for font management.
+ * Copyright (c) 2008 embedded brains GmbH. All rights reserved.
#ifndef DISP_FONTS_H
#define DISP_FONTS_H
diff --git a/bsps/shared/dev/display/disp_hcms29xx.c b/bsps/shared/dev/display/disp_hcms29xx.c
index 656820fb50..6990f042db 100644
--- a/bsps/shared/dev/display/disp_hcms29xx.c
+++ b/bsps/shared/dev/display/disp_hcms29xx.c
@@ -1,22 +1,17 @@
-| File: disp_hcms29xx.c |
-| 82178 Puchheim |
-| Germany |
-| this file contains the SPI based driver for a HCMS29xx 4 digit |
-| alphanumeric LED display |
+ * This file contains the SPI based driver for a HCMS29xx 4 digit
+ * alphanumeric LED display.
diff --git a/bsps/shared/dev/display/font_hcms29xx.c b/bsps/shared/dev/display/font_hcms29xx.c
index 07bf61c3dd..8e8d25f7b6 100644
--- a/bsps/shared/dev/display/font_hcms29xx.c
+++ b/bsps/shared/dev/display/font_hcms29xx.c
@@ -1,21 +1,16 @@
-| File: font_hcms29xx.c |
-| 82178 Puchheim |
-| Germany |
-| This file defines the 5x7 bit font used in disp_hcms29xx |
+ * This file defines the 5x7 bit font used in disp_hcms29xx.
#include <stddef.h>
#include "disp_fonts.h"
diff --git a/bsps/shared/dev/display/font_hcms29xx.h b/bsps/shared/dev/display/font_hcms29xx.h
index 9ad8ca0b53..93feec9f94 100644
--- a/bsps/shared/dev/display/font_hcms29xx.h
+++ b/bsps/shared/dev/display/font_hcms29xx.h
@@ -1,21 +1,16 @@
-| File: font_hcms29xx.h |
-| 82178 Puchheim |
-| Germany |
-| This file declares the 5x7 bit font used in disp_hcms29xx |
+ * This file declares the 5x7 bit font used in disp_hcms29xx.
#ifndef FONT_HCMS29XX_H
#define FONT_HCMS29XX_H
diff --git a/bsps/shared/dev/i2c/spi-flash-m25p40.c b/bsps/shared/dev/i2c/spi-flash-m25p40.c
index 961d7607a1..60c29c3011 100644
--- a/bsps/shared/dev/i2c/spi-flash-m25p40.c
+++ b/bsps/shared/dev/i2c/spi-flash-m25p40.c
@@ -1,20 +1,14 @@
-| Project: SPI driver for M25P40 like spi flash device |
-| Copyright (c) 2007 |
-| 82178 Puchheim |
-| Germany |
+ * SPI driver for M25P40 like spi flash device.
+ * Copyright (c) 2007 embedded brains GmbH. All rights reserved.
#include <rtems/libi2c.h>
diff --git a/bsps/shared/dev/i2c/spi-fram-fm25l256.c b/bsps/shared/dev/i2c/spi-fram-fm25l256.c
index 698e6cf2cd..509b4686ca 100644
--- a/bsps/shared/dev/i2c/spi-fram-fm25l256.c
+++ b/bsps/shared/dev/i2c/spi-fram-fm25l256.c
@@ -1,20 +1,14 @@
-| Project: SPI driver for FM25L256 like spi fram device |
-| 82178 Puchheim |
-| Germany |
+ * SPI driver for FM25L256 like spi fram device.
diff --git a/bsps/shared/dev/i2c/spi-memdrv.c b/bsps/shared/dev/i2c/spi-memdrv.c
index 2cea1ba7c2..7656966362 100644
--- a/bsps/shared/dev/i2c/spi-memdrv.c
+++ b/bsps/shared/dev/i2c/spi-memdrv.c
@@ -1,20 +1,15 @@
-| Project: SPI driver for spi memory devices |
-| 82178 Puchheim |
-| Germany |
+ * SPI driver for spi memory devices.
* FIXME: currently, this driver only supports read/write accesses
* erase accesses are to be completed
2.34.1
