[PATCH 35/40] bsps and cpukit: Manual file header clean up
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Mar 7 13:23:33 UTC 2022
Updates #4625.
bsps/i386/pc386/ata/ide.c | 41 ++++++++++-------------
bsps/i386/pc386/ata/idecfg.c | 33 +++++++++---------
cpukit/include/rtems/fsmount.h | 13 +++----
cpukit/include/rtems/serdbg.h | 34 +++++++++----------
cpukit/include/rtems/serdbgcnf.h | 27 +++++----------
cpukit/include/rtems/termios_printk.h | 32 ++++++++----------
cpukit/include/rtems/termios_printk_cnf.h | 27 +++++----------
cpukit/libfs/src/dosfs/msdos_format.c | 13 +++----
cpukit/libmisc/fsmount/fsmount.c | 16 ++++-----
cpukit/libmisc/serdbg/serdbg.c | 33 +++++++++---------
10 files changed, 113 insertions(+), 156 deletions(-)
diff --git a/bsps/i386/pc386/ata/ide.c b/bsps/i386/pc386/ata/ide.c
index 52877cf60b..8b0b585d22 100644
--- a/bsps/i386/pc386/ata/ide.c
+++ b/bsps/i386/pc386/ata/ide.c
@@ -1,27 +1,20 @@
-| Project: RTEMS PC386 IDE harddisc driver |
-| File: ide.c |
-| Copyright (c) 2003 IMD |
-| Ingenieurbuero fuer Microcomputertechnik Th. Doerfler |
-| <Thomas.Doerfler at imd-systems.de> |
-| all rights reserved |
-| this file contains the BSP layer for IDE access below the |
-| libchip IDE harddisc driver |
-| based on a board specific driver from |
-| Eugeny S. Mints, Oktet |
-| The license and distribution terms for this file may be |
-| found in the file LICENSE in this distribution or at |
-| http://www.rtems.org/license/LICENSE. |
-| date history ID |
-| 01.14.03 creation doe |
+ * RTEMS PC386 IDE harddisc driver
+ * This file contains the BSP layer for IDE access below the
+ * libchip IDE harddisc driver.
+ * based on a board specific driver from
+ * Eugeny S. Mints, Oktet
+ * Copyright (c) 2003 Ingenieurbuero fuer Microcomputertechnik Th. Doerfler
+ * All rights reserved.
#include <inttypes.h>
diff --git a/bsps/i386/pc386/ata/idecfg.c b/bsps/i386/pc386/ata/idecfg.c
index 371a6eea53..777b8bcbe0 100644
--- a/bsps/i386/pc386/ata/idecfg.c
+++ b/bsps/i386/pc386/ata/idecfg.c
@@ -1,21 +1,18 @@
-| Project: RTEMS PC386 IDE harddisc driver tables |
-| File: idecfg.c |
-| this file contains the table of functions for the BSP layer |
-| for IDE access below the libchip IDE harddisc driver |
+ * RTEMS PC386 IDE harddisc driver tables
+ * This file contains the table of functions for the BSP layer
+ * for IDE access below the libchip IDE harddisc driver.
#include <bsp.h>
diff --git a/cpukit/include/rtems/fsmount.h b/cpukit/include/rtems/fsmount.h
index 7c6d4558c3..b9897f6340 100644
--- a/cpukit/include/rtems/fsmount.h
+++ b/cpukit/include/rtems/fsmount.h
@@ -12,14 +12,11 @@
- * Copyright (c) 2003 IMD
- * Ingenieurbuero fuer Microcomputertechnik Th. Doerfler
- * <Thomas.Doerfler at imd-systems.de>
- * all rights reserved
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
diff --git a/cpukit/include/rtems/serdbg.h b/cpukit/include/rtems/serdbg.h
index fe106bce44..411e5251fc 100644
--- a/cpukit/include/rtems/serdbg.h
+++ b/cpukit/include/rtems/serdbg.h
@@ -1,21 +1,19 @@
-| Project: RTEMS remote gdb over serial line |
-| File: serdbg.h |
-| Copyright (c) 2002 IMD |
-| this file declares intialization functions to add |
-| a gdb remote debug stub to an RTEMS system |
-| 04.04.02 creation doe |
+ * RTEMS remote gdb over serial line
+ * This file declares intialization functions to add
+ * a gdb remote debug stub to an RTEMS system.
+ * Copyright (c) 2002 Ingenieurbuero fuer Microcomputertechnik Th. Doerfler
#ifndef _SERDBG_H
#define _SERDBG_H
diff --git a/cpukit/include/rtems/serdbgcnf.h b/cpukit/include/rtems/serdbgcnf.h
index 9d4087ae69..1ec9905d7a 100644
--- a/cpukit/include/rtems/serdbgcnf.h
+++ b/cpukit/include/rtems/serdbgcnf.h
@@ -4,24 +4,15 @@
* @brief Adds a GDB remote Debug Stub to an RTEMS System
-| Project: RTEMS configure remote gdb over serial line |
-| File: serdbgcnf.h |
-| 13.05.02 creation doe |
#ifndef _SERDBGCNF_H
#define _SERDBGCNF_H
diff --git a/cpukit/include/rtems/termios_printk.h b/cpukit/include/rtems/termios_printk.h
index dcb183533a..04772e00f5 100644
--- a/cpukit/include/rtems/termios_printk.h
+++ b/cpukit/include/rtems/termios_printk.h
@@ -1,21 +1,17 @@
-| File: termios_printk.h |
-| printk polled output via termios polled drivers |
-| 13.04.02 creation doe |
+ * printk polled output via termios polled drivers.
#ifndef _TERMIOS_PRINTK_H
#define _TERMIOS_PRINTK_H
diff --git a/cpukit/include/rtems/termios_printk_cnf.h b/cpukit/include/rtems/termios_printk_cnf.h
index 03c3090c38..29943f57b6 100644
--- a/cpukit/include/rtems/termios_printk_cnf.h
+++ b/cpukit/include/rtems/termios_printk_cnf.h
@@ -4,24 +4,15 @@
* @brief Adds printk Support via Polled termios
-| File: termios_printk_cnf.h |
-| printk support via polled termios |
#ifndef _TERMIOS_PRINTK_CNF_H
#define _TERMIOS_PRINTK_CNF_H
diff --git a/cpukit/libfs/src/dosfs/msdos_format.c b/cpukit/libfs/src/dosfs/msdos_format.c
index 5786b0b1cb..8ffeb2935a 100644
--- a/cpukit/libfs/src/dosfs/msdos_format.c
+++ b/cpukit/libfs/src/dosfs/msdos_format.c
@@ -9,15 +9,12 @@
- * Copyright (C) 2004 IMD
+ * Copyright (c) 2004 Ingenieurbuero fuer Microcomputertechnik Th. Doerfler
- * All rights reserved.
- * http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/fsmount/fsmount.c b/cpukit/libmisc/fsmount/fsmount.c
index 190d0dd511..deb8e8b56a 100644
--- a/cpukit/libmisc/fsmount/fsmount.c
+++ b/cpukit/libmisc/fsmount/fsmount.c
@@ -7,18 +7,18 @@
* This file contains the fsmount functions. These functions
* are used to mount a list of filesystems (and create their mount
* points before).
#ifndef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/serdbg/serdbg.c b/cpukit/libmisc/serdbg/serdbg.c
index 5460567fd5..817564edb7 100644
--- a/cpukit/libmisc/serdbg/serdbg.c
+++ b/cpukit/libmisc/serdbg/serdbg.c
@@ -1,21 +1,18 @@
-| File: serdbg.c |
-| this file contains intialization and utility functions to add |
+ * This file contains intialization and utility functions to add
#include "config.h"
2.34.1
