[PATCH] mpci: Simplify expressions
Sebastian Huber
Tue Mar 8 06:52:37 UTC 2022
Use that rtems_configuration_get_user_multiprocessing_table() returns never
NULL if RTEMS_MULTIPROCESSING defined.
bsps/m68k/mvme147s/start/bspstart.c | 2 +-
bsps/riscv/griscv/include/amba.h | 3 +--
bsps/sparc/leon3/btimer/btimer.c | 5 ++---
bsps/sparc/leon3/include/leon.h | 3 +--
cpukit/libmisc/monitor/mon-editor.c | 6 ------
cpukit/libmisc/stackchk/check.c | 10 ++++------
6 files changed, 9 insertions(+), 20 deletions(-)
diff --git a/bsps/m68k/mvme147s/start/bspstart.c b/bsps/m68k/mvme147s/start/bspstart.c
index 497b644150..e5eb48f108 100644
--- a/bsps/m68k/mvme147s/start/bspstart.c
+++ b/bsps/m68k/mvme147s/start/bspstart.c
@@ -58,7 +58,7 @@ void bsp_start( void )
#if defined(RTEMS_MULTIPROCESSING)
node_number = (uint8_t)
- (rtems_configuration_get_user_multiprocessing_table()->node - 1) & 0xF;
+ rtems_configuration_get_user_multiprocessing_table()->node - 1;
#else
node_number = 1;
#endif
diff --git a/bsps/riscv/griscv/include/amba.h b/bsps/riscv/griscv/include/amba.h
index 292660d5c1..b615389df4 100644
--- a/bsps/riscv/griscv/include/amba.h
+++ b/bsps/riscv/griscv/include/amba.h
@@ -46,8 +46,7 @@
#define GRLIB_APB_SLAVES 16
- #define GRLIB_CLOCK_INDEX \
- (rtems_configuration_get_user_multiprocessing_table() ? GRLIB_Cpu_Index : 0)
+ #define GRLIB_CLOCK_INDEX GRLIB_Cpu_Index
#else
#define GRLIB_CLOCK_INDEX 0
#endif
diff --git a/bsps/sparc/leon3/btimer/btimer.c b/bsps/sparc/leon3/btimer/btimer.c
index 9e9f2b02fc..03bbfe06e7 100644
--- a/bsps/sparc/leon3/btimer/btimer.c
+++ b/bsps/sparc/leon3/btimer/btimer.c
@@ -23,10 +23,9 @@
#define LEON3_TIMER_INDEX \
- ((rtems_configuration_get_user_multiprocessing_table()) ? \
- (rtems_configuration_get_user_multiprocessing_table()->node) - 1 : 1)
+ (rtems_configuration_get_user_multiprocessing_table()->node)
#else
- #define LEON3_TIMER_INDEX 0
+ #define LEON3_TIMER_INDEX 1
#endif
bool benchmark_timer_find_average_overhead;
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 5fadb08052..e03185f927 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -325,8 +325,7 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
#define LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK 0x00000003
- #define LEON3_CLOCK_INDEX \
- (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
+ #define LEON3_CLOCK_INDEX LEON3_Cpu_Index
#else
#define LEON3_CLOCK_INDEX 0
#endif
diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
index 6957fee9c8..bea0fc28ba 100644
--- a/cpukit/libmisc/monitor/mon-editor.c
+++ b/cpukit/libmisc/monitor/mon-editor.c
@@ -499,12 +499,6 @@ rtems_monitor_command_read(char *command,
* put node number in the prompt if we are multiprocessing
-#if defined(RTEMS_MULTIPROCESSING)
- if (!rtems_configuration_get_user_multiprocessing_table ())
- snprintf (monitor_prompt, sizeof(monitor_prompt), "%s",
- (env_prompt == NULL) ? MONITOR_PROMPT: env_prompt);
- else /* .... */
-#endif
if (rtems_monitor_default_node != rtems_monitor_node)
"%" PRId32 "-%s-%" PRId32 "", rtems_monitor_node,
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index fa0c3ea1ed..437a0476c3 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -278,12 +278,10 @@ static void Stack_check_report_blown_task(
- if (rtems_configuration_get_user_multiprocessing_table()) {
- printk(
- "node: 0x%08" PRIxPTR "\n",
- (intptr_t) rtems_configuration_get_user_multiprocessing_table()->node
+ printk(
+ "node: 0x%08" PRIxPTR "\n",
+ (intptr_t) rtems_configuration_get_user_multiprocessing_table()->node
#endif
rtems_fatal(
2.34.1
