[PATCH] mpci: Simplify expressions
Gedare Bloom
gedare at rtems.org
Tue Mar 8 13:56:07 UTC 2022
On Mon, Mar 7, 2022 at 11:52 PM Sebastian Huber
> Use that rtems_configuration_get_user_multiprocessing_table() returns never
> NULL if RTEMS_MULTIPROCESSING defined.
> bsps/m68k/mvme147s/start/bspstart.c | 2 +-
> bsps/riscv/griscv/include/amba.h | 3 +--
> bsps/sparc/leon3/btimer/btimer.c | 5 ++---
> bsps/sparc/leon3/include/leon.h | 3 +--
> cpukit/libmisc/monitor/mon-editor.c | 6 ------
> cpukit/libmisc/stackchk/check.c | 10 ++++------
> 6 files changed, 9 insertions(+), 20 deletions(-)
> diff --git a/bsps/m68k/mvme147s/start/bspstart.c b/bsps/m68k/mvme147s/start/bspstart.c
> index 497b644150..e5eb48f108 100644
> --- a/bsps/m68k/mvme147s/start/bspstart.c
> +++ b/bsps/m68k/mvme147s/start/bspstart.c
> @@ -58,7 +58,7 @@ void bsp_start( void )
> #if defined(RTEMS_MULTIPROCESSING)
> node_number = (uint8_t)
> - (rtems_configuration_get_user_multiprocessing_table()->node - 1) & 0xF;
> + rtems_configuration_get_user_multiprocessing_table()->node - 1;
node is never 0?
> #else
> node_number = 1;
> #endif
> diff --git a/bsps/riscv/griscv/include/amba.h b/bsps/riscv/griscv/include/amba.h
> index 292660d5c1..b615389df4 100644
> --- a/bsps/riscv/griscv/include/amba.h
> +++ b/bsps/riscv/griscv/include/amba.h
> @@ -46,8 +46,7 @@
> #define GRLIB_APB_SLAVES 16
> - #define GRLIB_CLOCK_INDEX \
> - (rtems_configuration_get_user_multiprocessing_table() ? GRLIB_Cpu_Index : 0)
> + #define GRLIB_CLOCK_INDEX GRLIB_Cpu_Index
> #else
> #define GRLIB_CLOCK_INDEX 0
> #endif
> diff --git a/bsps/sparc/leon3/btimer/btimer.c b/bsps/sparc/leon3/btimer/btimer.c
> index 9e9f2b02fc..03bbfe06e7 100644
> --- a/bsps/sparc/leon3/btimer/btimer.c
> +++ b/bsps/sparc/leon3/btimer/btimer.c
> @@ -23,10 +23,9 @@
> #define LEON3_TIMER_INDEX \
> - ((rtems_configuration_get_user_multiprocessing_table()) ? \
> - (rtems_configuration_get_user_multiprocessing_table()->node) - 1 : 1)
> + (rtems_configuration_get_user_multiprocessing_table()->node)
This is not the same value, but
> #else
> - #define LEON3_TIMER_INDEX 0
> + #define LEON3_TIMER_INDEX 1
I guess this corrects the off-by-1?
> #endif
> bool benchmark_timer_find_average_overhead;
> diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
> index 5fadb08052..e03185f927 100644
> --- a/bsps/sparc/leon3/include/leon.h
> +++ b/bsps/sparc/leon3/include/leon.h
> @@ -325,8 +325,7 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
> #define LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK 0x00000003
> - #define LEON3_CLOCK_INDEX \
> - (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
> + #define LEON3_CLOCK_INDEX LEON3_Cpu_Index
> #else
> #define LEON3_CLOCK_INDEX 0
> #endif
> diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
> index 6957fee9c8..bea0fc28ba 100644
> --- a/cpukit/libmisc/monitor/mon-editor.c
> +++ b/cpukit/libmisc/monitor/mon-editor.c
> @@ -499,12 +499,6 @@ rtems_monitor_command_read(char *command,
> * put node number in the prompt if we are multiprocessing
> -#if defined(RTEMS_MULTIPROCESSING)
> - if (!rtems_configuration_get_user_multiprocessing_table ())
> - snprintf (monitor_prompt, sizeof(monitor_prompt), "%s",
> - (env_prompt == NULL) ? MONITOR_PROMPT: env_prompt);
> - else /* .... */
> -#endif
> if (rtems_monitor_default_node != rtems_monitor_node)
> "%" PRId32 "-%s-%" PRId32 "", rtems_monitor_node,
> diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
> index fa0c3ea1ed..437a0476c3 100644
> --- a/cpukit/libmisc/stackchk/check.c
> +++ b/cpukit/libmisc/stackchk/check.c
> @@ -278,12 +278,10 @@ static void Stack_check_report_blown_task(
> - if (rtems_configuration_get_user_multiprocessing_table()) {
> - printk(
> - "node: 0x%08" PRIxPTR "\n",
> - (intptr_t) rtems_configuration_get_user_multiprocessing_table()->node
> + printk(
> + "node: 0x%08" PRIxPTR "\n",
> + (intptr_t) rtems_configuration_get_user_multiprocessing_table()->node
> #endif
> rtems_fatal(
> 2.34.1
> devel mailing list
> devel at rtems.org
