Warnings when building sparc/leon3
Joel Sherrill
joel at rtems.org
Tue Mar 8 14:23:35 UTC 2022
On Tue, Mar 8, 2022 at 12:45 AM Sebastian Huber <
> On 07/03/2022 19:19, Joel Sherrill wrote:
> > On Mon, Mar 7, 2022 at 11:54 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 07/03/2022 17:48, Joel Sherrill wrote:
> > > This appears to be because
> > > rtems_configuration_get_user_multiprocessing_table() always
> returns a
> > > non-NULL value when RTEMS_MULTIPROCESSING is defined. This must
> > be a change
> > > versus previous behavior.
> > > Ryan and I noticed that the specific cases cited here appeared to
> be
> > > wrapped in ifdef RTEMS_MULTIPROCESSING so didn't need to worry
> > about it.
> > > But something has changed that impacts public facing behavior.
> > I think this is the related ticket:
> > https://devel.rtems.org/ticket/3735
> > <https://devel.rtems.org/ticket/3735>
> > OK. But apparently this was used to tell the difference between a
> > single node system in MP configuration and a node within an
> > MP configuration. My grep shows some uses are really dereferencing
> > the table but others like the one in amba.h:153 to define the clock
> > index looks wrong. THere is similar code in leon.h:
> > #if defined(RTEMS_MULTIPROCESSING)
> > #define LEON3_CLOCK_INDEX \
> > (rtems_configuration_get_user_multiprocessing_table() ?
> > LEON3_Cpu_Index : 0)
> > #else
> > #define LEON3_CLOCK_INDEX 0
> > #endif
> > That's the type of pattern that needs addressing. That test is
> > asking in multiprocessing is configured in the application not
> > in the build.
> The rtems_configuration_get_user_multiprocessing_table() ? X : Y
> expressions can be simplified to X.
That does not preserve the semantics of the original. In the original
implementation, it could return NULL for an application configured
to be a single processor with no distributed multiprocessing in use.
The change gets rid of the warning but doesn't 'retain the intent.
> This change needs to be looked at (the comment in the file header makes
> no sense after this change):
> commit 7f3c6cee09ee44b627b11de34248aba485c789b3
> Author: Joel Sherrill <joel.sherrill at OARcorp.com>
> Date: Tue Dec 4 22:20:55 2007 +0000
> 2007-12-04 Joel Sherrill <joel.sherrill at OARcorp.com>
> * amba/amba.c, clock/ckinit.c, console/console.c,
> include/bsp.h,
> startup/bspstart.c, timer/timer.c: Move
> interrupt_stack_size field
> from CPU Table to Configuration Table. Eliminate CPU Table
> from all
> ports. Delete references to CPU Table in all forms.
> diff --git a/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> index 9d6f89a593..2c1127a30a 100644
> --- a/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> +++ b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> @@ -22,12 +22,13 @@
> #include <bsp.h>
> -extern rtems_configuration_table Configuration;
> -#define LEON3_TIMER_INDEX \
> - (Configuration.User_multiprocessing_table ? \
> - (Configuration.User_multiprocessing_table)->maximum_nodes + \
> - (Configuration.User_multiprocessing_table)->node - 1 : 1)
> +#if defined(RTEMS_MULTIPROCESSING)
> + #define LEON3_TIMER_INDEX \
> + (rtems_configuration_get_user_multiprocessing_table() ? : \
> + (rtems_configuration_get_user_multiprocessing_table()->node) -
> 1 : 1)
> +#else
> + #define LEON3_TIMER_INDEX 0
> +#endif
> rtems_boolean Timer_driver_Find_average_overhead;
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
