Warnings when building sparc/leon3
Tue Mar 8 14:31:20 UTC 2022
On 08/03/2022 15:23, Joel Sherrill wrote:
> On Tue, Mar 8, 2022 at 12:45 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 07/03/2022 19:19, Joel Sherrill wrote:
>      > On Mon, Mar 7, 2022 at 11:54 AM Sebastian Huber
>     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>      >     On 07/03/2022 17:48, Joel Sherrill wrote:
>      >      > This appears to be because
>      >      > rtems_configuration_get_user_multiprocessing_table()
>     always returns a
>      >      > non-NULL value when RTEMS_MULTIPROCESSING is defined. This
>     must
>      >     be a change
>      >      > versus previous behavior.
>      >      > Ryan and I noticed that the specific cases cited here
>     appeared to be
>      >      > wrapped in ifdef RTEMS_MULTIPROCESSING so didn't need to worry
>      >     about it.
>      >      > But something has changed that impacts public facing behavior.
>      >     I think this is the related ticket:
>      > https://devel.rtems.org/ticket/3735
>     <https://devel.rtems.org/ticket/3735>
>     <https://devel.rtems.org/ticket/3735>>
>      > OK. But apparently this was used to tell the difference between a
>      > single node system in MP configuration and a node within an
>      > MP configuration.  My grep shows some uses are really dereferencing
>      > the table but others like the one in amba.h:153 to define the clock
>      > index looks wrong. THere is similar code in leon.h:
>      > #if defined(RTEMS_MULTIPROCESSING)
>      >    #define LEON3_CLOCK_INDEX \
>      >     (rtems_configuration_get_user_multiprocessing_table() ?
>      > LEON3_Cpu_Index : 0)
>      > #else
>      >    #define LEON3_CLOCK_INDEX 0
>      > #endif
>      > That's the type of pattern that needs addressing. That test is
>      > asking in multiprocessing is configured in the application not
>      > in the build.
>     The rtems_configuration_get_user_multiprocessing_table() ? X : Y
>     expressions can be simplified to X.
> That does not preserve the semantics of the original. In the original
> implementation, it could return NULL for an application configured
> to be a single processor with no distributed multiprocessing in use.
> The change gets rid of the warning but doesn't 'retain the intent.
If you think the original behaviour of
rtems_configuration_get_user_multiprocessing_table() is important, then
it should be documented and tested.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
