Warnings when building sparc/leon3
Sebastian Huber
Tue Mar 8 14:46:19 UTC 2022
On 08/03/2022 15:40, Joel Sherrill wrote:
> On Tue, Mar 8, 2022 at 8:31 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 08/03/2022 15:23, Joel Sherrill wrote:
> > On Tue, Mar 8, 2022 at 12:45 AM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > On 07/03/2022 19:19, Joel Sherrill wrote:
> > > On Mon, Mar 7, 2022 at 11:54 AM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
> > > On 07/03/2022 17:48, Joel Sherrill wrote:
> > > > This appears to be because
> > > > rtems_configuration_get_user_multiprocessing_table()
> > always returns a
> > > > non-NULL value when RTEMS_MULTIPROCESSING is
> defined. This
> > must
> > > be a change
> > > > versus previous behavior.
> > > > Ryan and I noticed that the specific cases cited here
> > appeared to be
> > > > wrapped in ifdef RTEMS_MULTIPROCESSING so didn't
> need to worry
> > > about it.
> > > > But something has changed that impacts public
> facing behavior.
> > > I think this is the related ticket:
> > > https://devel.rtems.org/ticket/3735
> <https://devel.rtems.org/ticket/3735>
> <https://devel.rtems.org/ticket/3735>>
> <https://devel.rtems.org/ticket/3735>>>
> > > OK. But apparently this was used to tell the difference
> between a
> > > single node system in MP configuration and a node within an
> > > MP configuration. My grep shows some uses are really
> dereferencing
> > > the table but others like the one in amba.h:153 to define
> the clock
> > > index looks wrong. THere is similar code in leon.h:
> > > #if defined(RTEMS_MULTIPROCESSING)
> > > #define LEON3_CLOCK_INDEX \
> > > (rtems_configuration_get_user_multiprocessing_table() ?
> > > LEON3_Cpu_Index : 0)
> > > #else
> > > #define LEON3_CLOCK_INDEX 0
> > > #endif
> > > That's the type of pattern that needs addressing. That test is
> > > asking in multiprocessing is configured in the application not
> > > in the build.
> > The rtems_configuration_get_user_multiprocessing_table() ? X : Y
> > expressions can be simplified to X.
> > That does not preserve the semantics of the original. In the original
> > implementation, it could return NULL for an application configured
> > to be a single processor with no distributed multiprocessing in use.
> > The change gets rid of the warning but doesn't 'retain the intent.
> If you think the original behaviour of
> rtems_configuration_get_user_multiprocessing_table() is important, then
> it should be documented and tested.
> The original behavior can't be re-implemented. When you made changes
> so there was always an MPCI Table, it fundamentally broke the assumption
> that one might not be present when MP is enabled.
We could change rtems_configuration_get_user_multiprocessing_table() to
return NULL if CONFIGURE_MP_APPLICATION is not defined.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
