Warnings when building sparc/leon3
Joel Sherrill
joel at rtems.org
Tue Mar 8 14:52:19 UTC 2022
On Tue, Mar 8, 2022 at 8:46 AM Sebastian Huber <
> On 08/03/2022 15:40, Joel Sherrill wrote:
> > On Tue, Mar 8, 2022 at 8:31 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 08/03/2022 15:23, Joel Sherrill wrote:
> > > On Tue, Mar 8, 2022 at 12:45 AM Sebastian Huber
> > <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > > On 07/03/2022 19:19, Joel Sherrill wrote:
> > > > On Mon, Mar 7, 2022 at 11:54 AM Sebastian Huber
> > <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
> > > > On 07/03/2022 17:48, Joel Sherrill wrote:
> > > > > This appears to be because
> > > > > rtems_configuration_get_user_multiprocessing_table()
> > > always returns a
> > > > > non-NULL value when RTEMS_MULTIPROCESSING is
> > defined. This
> > > must
> > > > be a change
> > > > > versus previous behavior.
> > > > > Ryan and I noticed that the specific cases cited
> here
> > > appeared to be
> > > > > wrapped in ifdef RTEMS_MULTIPROCESSING so didn't
> > need to worry
> > > > about it.
> > > > > But something has changed that impacts public
> > facing behavior.
> > > > I think this is the related ticket:
> > > > https://devel.rtems.org/ticket/3735
> > <https://devel.rtems.org/ticket/3735>
> > <https://devel.rtems.org/ticket/3735>>
> > <https://devel.rtems.org/ticket/3735>>>
> > > > OK. But apparently this was used to tell the difference
> > between a
> > > > single node system in MP configuration and a node within an
> > > > MP configuration. My grep shows some uses are really
> > dereferencing
> > > > the table but others like the one in amba.h:153 to define
> > the clock
> > > > index looks wrong. THere is similar code in leon.h:
> > > > #if defined(RTEMS_MULTIPROCESSING)
> > > > #define LEON3_CLOCK_INDEX \
> > > > (rtems_configuration_get_user_multiprocessing_table() ?
> > > > LEON3_Cpu_Index : 0)
> > > > #else
> > > > #define LEON3_CLOCK_INDEX 0
> > > > #endif
> > > > That's the type of pattern that needs addressing. That
> test is
> > > > asking in multiprocessing is configured in the application
> not
> > > > in the build.
> > > The rtems_configuration_get_user_multiprocessing_table() ? X
> : Y
> > > expressions can be simplified to X.
> > > That does not preserve the semantics of the original. In the
> original
> > > implementation, it could return NULL for an application configured
> > > to be a single processor with no distributed multiprocessing in
> use.
> > > The change gets rid of the warning but doesn't 'retain the intent.
> > If you think the original behaviour of
> > rtems_configuration_get_user_multiprocessing_table() is important,
> then
> > it should be documented and tested.
> > The original behavior can't be re-implemented. When you made changes
> > so there was always an MPCI Table, it fundamentally broke the assumption
> > that one might not be present when MP is enabled.
> We could change rtems_configuration_get_user_multiprocessing_table() to
> return NULL if CONFIGURE_MP_APPLICATION is not defined.
That's how it is now.
#define rtems_configuration_get_user_multiprocessing_table() \
( &_MPCI_Configuration )
#else
#define rtems_configuration_get_user_multiprocessing_table() NULL
#endif
I think all the use cases Ryan and I saw were protected by ifdef
RTEMS_MULTIPROCESSING. Perhaps this just should not be defined
if it isn't configured.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
