New validation test suites
Sebastian Huber
Thu Mar 10 08:19:51 UTC 2022
Hello Chris,
On 23/02/2022 10:17, Sebastian Huber wrote:
> I added a --diff option to the spec2modules.py script in
> rtems-central.git. You can now unpack a release archive of
> rtems-central.git and then do the following:
> 1. Unpack the RTEMS release archive to "modules/rtems".
> 2. Unpack the RTEMS documentation source release archive to
> "modules/rtems-docs".
> 3. Run "./spec2modules.py --diff". This command will output the
> differences between the specification point of view of the sources and
> the actual sources (or nothing).
is there something left which prevents an integration of the new
validation tests?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
