New validation test suites
Chris Johns
chrisj at rtems.org
Thu Mar 10 08:42:22 UTC 2022
On 10/3/2022 7:19 pm, Sebastian Huber wrote:
> Hello Chris,
> On 23/02/2022 10:17, Sebastian Huber wrote:
>> I added a --diff option to the spec2modules.py script in rtems-central.git.
>> You can now unpack a release archive of rtems-central.git and then do the
>> following:
>> 1. Unpack the RTEMS release archive to "modules/rtems".
>> 2. Unpack the RTEMS documentation source release archive to "modules/rtems-docs".
>> 3. Run "./spec2modules.py --diff". This command will output the differences
>> between the specification point of view of the sources and the actual sources
>> (or nothing).
> is there something left which prevents an integration of the new validation tests?
No, the tests are ok to be committed.
If anything shows up in further testing and when a release is created we can
address it then.
That you for this, your patience and understanding.
