New validation test suites
Sebastian Huber
Thu Mar 10 12:46:16 UTC 2022
On 10/03/2022 09:42, Chris Johns wrote:
> On 10/3/2022 7:19 pm, Sebastian Huber wrote:
>> Hello Chris,
>> On 23/02/2022 10:17, Sebastian Huber wrote:
>>> I added a --diff option to the spec2modules.py script in rtems-central.git.
>>> You can now unpack a release archive of rtems-central.git and then do the
>>> following:
>>> 1. Unpack the RTEMS release archive to "modules/rtems".
>>> 2. Unpack the RTEMS documentation source release archive to "modules/rtems-docs".
>>> 3. Run "./spec2modules.py --diff". This command will output the differences
>>> between the specification point of view of the sources and the actual sources
>>> (or nothing).
>> is there something left which prevents an integration of the new validation tests?
> No, the tests are ok to be committed.
> If anything shows up in further testing and when a release is created we can
> address it then.
> That you for this, your patience and understanding.
Thanks for the review. I will integrate it once the powerpc issues with
GCC 10 are fixed. Currently, the virtex4 and virtex5 BSPs don't build.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
