[PATCH 1/1] libtftpfs: Change to BSD-2-Clause license
Joel Sherrill
joel at rtems.org
Tue Mar 15 17:25:37 UTC 2022
On Tue, Mar 15, 2022, 12:12 PM Frank Kühndel <
frank.kuehndel at embedded-brains.de> wrote:
> Hi Sebastian,
> On 3/15/22 17:46, Sebastian Huber wrote:
> > On 15/03/2022 17:27, Frank Kuehndel wrote:
> >> + * Copyright (C) W. Eric Norum
> > Copyright statements should have a year. You can use the Git history to
> > get it.
> Yes, I know. But I can only trace the history back to
> commit 39e6e65a2c5a3312f365d59f23c469641e049c82
> Author: Joel Sherrill <joel.sherrill at OARcorp.com>
> Date: Wed Aug 19 21:32:28 1998 +0000
> This commit is apparently not the one for the author. I can only guess:
> These files where imported from FreeBSD??? - and most likely from
> another RCS??? They originally contain the famous CVS and SVN tag $Id$
> (without date unfortunately)
The git conversion made whoever commited to CVS the author. Since I tended
to commit all submissions for a long time, I'm noted as the author.
Put 1998 since that's when it was committed and most likely authored.
--joel
> Hence, I concluded the simplest solution is not to provide the year.
> Greetings,
> fk
> embedded brains GmbH
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: frank.kuehndel at embedded-brains.de
> phone: +49-89-18 94 741 - 23
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
