[PATCH v2] libtftpfs: Change to BSD-2-Clause license
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Tue Mar 15 17:45:33 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
Eric Norum's permission to change the license can be found here:
https://devel.rtems.org/attachment/ticket/3053/EricNorum-Permission.pdf
Update #3053
cpukit/include/rtems/tftp.h | 72 +++++++++++++++++++++++------
cpukit/libfs/src/ftpfs/tftpDriver.c | 44 ++++++++++++++----
2 files changed, 93 insertions(+), 23 deletions(-)
diff --git a/cpukit/include/rtems/tftp.h b/cpukit/include/rtems/tftp.h
index ed3ebd7865..2f36a39cd2 100644
--- a/cpukit/include/rtems/tftp.h
+++ b/cpukit/include/rtems/tftp.h
@@ -1,23 +1,69 @@
- * Trivial File Transfer Protocol (TFTP)
+ * @file
- * Transfer file to/from remote host
+ * @ingroup RTEMSTFTPFS
- * W. Eric Norum
- * Saskatchewan Accelerator Laboratory
- * University of Saskatchewan
- * Saskatoon, Saskatchewan, CANADA
- * eric at skatter.usask.ca
+ * @brief This header file provides interfaces and functions used to
+ * implement the TFTP File System.
+ * This file declares the public functions of the Trivial File
+ * Transfer Protocol (TFTP) File System.
- * Usage:
+ * Copyright (C) 1998 W. Eric Norum
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @defgroup RTEMSTFTPFS Trivial File Transfer Protocol (TFTP) File System
+ * @ingroup FileSystemTypesAndMount
+ * @brief The TFTP File System provides the ability to read files from and
+ * to write files to remote servers using the Trivial File Transfer
+ * Protocol (TFTP).
+ * Usage
+ * To open `/bootfiles/image` on `hostname` for reading:
+ * fd = open ("/TFTP/hostname:bootfiles/image", O_RDONLY);
+ * The `TFTP` is the mount path and the `hostname` must be
+ * + an IPv4 address (acceptable to `inet_aton()`) or
+ * + the (full-qualified) name of an IPv4 host (acceptable to
+ * `gethostbyname()`)
- * To open `/bootfiles/image' on `hostname' for reading:
- * fd = open ("/TFTP/hostname/bootfiles/image", O_RDONLY);
+ * IPv6 is currently not supported. `bootfiles/image` is a path on the
+ * TFTP server `hostname` where the file (here `image`) can be found.
- * The 'TFTP' is the mount path and the `hostname' must be four dot-separated
- * decimal values.
+ * See also the _RTEMS Filesystem Design Guide_ Chapter [_Trivial FTP Client
+ * Filesystem_](https://docs.rtems.org/branches/master/filesystem/trivial_ftp.html).
#ifndef _RTEMS_TFTP_H
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
index bc0e74ad86..f4fd93d535 100644
--- a/cpukit/libfs/src/ftpfs/tftpDriver.c
+++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
@@ -1,17 +1,41 @@
- * Trivial File Transfer Protocol (RFC 1350)
+ * @file
+ * @brief This source file contains the implementation of
+ * Trivial File Transfer Protocol (TFTP) File System.
- * W. Eric Norum
+ * The code in this file implements the Trivial File Transfer
+ * Protocol according to RFC 1350.
+ * Copyright (C) 2012 embedded brains GmbH (http://www.embedded-brains.de)
- * Modifications to support reference counting in the file system are
- * Copyright (c) 2012 embedded brains GmbH.
+ * are met:
#ifdef HAVE_CONFIG_H
2.34.1
