[PATCH v2] libtftpfs: Change to BSD-2-Clause license
Tue Mar 15 18:10:09 UTC 2022
This looks ok.
On Tue, Mar 15, 2022 at 12:45 PM Frank Kuehndel <
frank.kuehndel at embedded-brains.de> wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> Eric Norum's permission to change the license can be found here:
> https://devel.rtems.org/attachment/ticket/3053/EricNorum-Permission.pdf
> Update #3053
>  cpukit/include/rtems/tftp.h         | 72 +++++++++++++++++++++++------
>  cpukit/libfs/src/ftpfs/tftpDriver.c | 44 ++++++++++++++----
>  2 files changed, 93 insertions(+), 23 deletions(-)
> diff --git a/cpukit/include/rtems/tftp.h b/cpukit/include/rtems/tftp.h
> index ed3ebd7865..2f36a39cd2 100644
> --- a/cpukit/include/rtems/tftp.h
> +++ b/cpukit/include/rtems/tftp.h
> @@ -1,23 +1,69 @@
> - * Trivial File Transfer Protocol (TFTP)
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> - * Transfer file to/from remote host
> + * @ingroup RTEMSTFTPFS
> - * W. Eric Norum
> - * Saskatchewan Accelerator Laboratory
> - * University of Saskatchewan
> - * Saskatoon, Saskatchewan, CANADA
> - * eric at skatter.usask.ca
> + * @brief This header file provides interfaces and functions used to
> + *   implement the TFTP File System.
> + * This file declares the public functions of the Trivial File
> + * Transfer Protocol (TFTP) File System.
> - * Usage:
> + * Copyright (C) 1998 W. Eric Norum
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * @defgroup RTEMSTFTPFS Trivial File Transfer Protocol (TFTP) File System
> + * @ingroup FileSystemTypesAndMount
> + * @brief The TFTP File System provides the ability to read files from and
> + *   to write files to remote servers using the Trivial File Transfer
> + *   Protocol (TFTP).
> + * Usage
> + * To open `/bootfiles/image` on `hostname` for reading:
> + *     fd = open ("/TFTP/hostname:bootfiles/image", O_RDONLY);
> + * The `TFTP` is the mount path and the `hostname` must be
> + * + an IPv4 address (acceptable to `inet_aton()`) or
> + * + the (full-qualified) name of an IPv4 host (acceptable to
> + *  `gethostbyname()`)
> - * To open `/bootfiles/image' on `hostname' for reading:
> - *         fd = open ("/TFTP/hostname/bootfiles/image", O_RDONLY);
> + * IPv6 is currently not supported. `bootfiles/image` is a path on the
> + * TFTP server `hostname` where the file (here `image`) can be found.
> - * The 'TFTP' is the mount path and the `hostname' must be four
> dot-separated
> - * decimal values.
> + * See also the _RTEMS Filesystem Design Guide_ Chapter [_Trivial FTP
> Client
> + * Filesystem_](
> https://docs.rtems.org/branches/master/filesystem/trivial_ftp.html).
>  #ifndef _RTEMS_TFTP_H
> diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c
> b/cpukit/libfs/src/ftpfs/tftpDriver.c
> index bc0e74ad86..f4fd93d535 100644
> --- a/cpukit/libfs/src/ftpfs/tftpDriver.c
> +++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
> @@ -1,17 +1,41 @@
> - * Trivial File Transfer Protocol (RFC 1350)
> + * @file
> + * @brief This source file contains the implementation of
> + * Trivial File Transfer Protocol (TFTP) File System.
> - * W. Eric Norum
> + * The code in this file implements the Trivial File Transfer
> + * Protocol according to RFC 1350.
> + * Copyright (C) 2012 embedded brains GmbH (http://www.embedded-brains.de
> - * Modifications to support reference counting in the file system are
> - * Copyright (c) 2012 embedded brains GmbH.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
>  #ifdef HAVE_CONFIG_H
> 2.34.1
> devel mailing list
> devel at rtems.org
