[PATCH] microblaze: Add AXI GPIO driver
Alex White
alex.white at oarcorp.com
Tue Mar 15 20:27:35 UTC 2022
bsps/include/dev/gpio/xilinx-axi-gpio.h | 311 ++++++++++++++++++
bsps/shared/dev/gpio/xilinx-axi-gpio.c | 221 +++++++++++++
.../bsps/microblaze/microblaze_fpga/obj.yml | 2 +
3 files changed, 534 insertions(+)
create mode 100644 bsps/include/dev/gpio/xilinx-axi-gpio.h
create mode 100644 bsps/shared/dev/gpio/xilinx-axi-gpio.c
diff --git a/bsps/include/dev/gpio/xilinx-axi-gpio.h b/bsps/include/dev/gpio/xilinx-axi-gpio.h
new file mode 100644
index 0000000000..dbd8748f34
--- /dev/null
+++ b/bsps/include/dev/gpio/xilinx-axi-gpio.h
@@ -0,0 +1,311 @@
+ * @file
+ * @ingroup RTEMSBSPsShared
+ * @brief Xilinx AXI GPIO definitions
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef XILINX_AXI_GPIO_H
+#define XILINX_AXI_GPIO_H
+#include <bspopts.h>
+#include <bsp/utility.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+typedef struct {
+ /* Channel 1 data values */
+ * Used to read general purpose input ports and write to general purpose
+ * output ports from channel 1.
+ uint32_t gpio_data;
+ * The 3-state control register for channel 1 is used for the dynamic
+ * configuration of ports as input or output. When a bit is set to 1, the
+ * corresponding I/O port is an input port. When a bit is set to 0, it is an
+ * output port.
+ uint32_t gpio_tri;
+ /* Channel 2 data values */
+ * output ports from channel 2.
+ uint32_t gpio2_data;
+ * The 3-state control register for channel 2 is used for the dynamic
+ * output port.
+ uint32_t gpio2_tri;
+ char _unused[272];
+ /* Only the 31st bit is used to enable interrupts globally */
+ #define GLOBAL_INTERRUPT_REGISTER_ENABLE BSP_BIT32(31)
+ * Global Interrupt Enable Register
+ * Determines whether interrupts are enabled or disabled.
+ * 0 - Disabled
+ * 1 - Enabled
+ uint32_t gier;
+ char _unused2[12];
+ /* Used with ip_isr and ip_ier member variables */
+ #define CHANNEL_1_INTERRUPT_REGISTER BSP_BIT32(0)
+ #define CHANNEL_2_INTERRUPT_REGISTER BSP_BIT32(1)
+ * IP Status Registers
+ * Contains the status bit for each channel.
+ * 0 - Disabled
+ * 1 - Enabled
+ uint32_t ip_isr;
+ char _unused3[4];
+ * IP Interrupt Enable Register
+ * Provides the ability to independtly control whether interrupts for each
+ * channel are enabled or disabled.
+ * 0 - No Channel input interrupt
+ * 1 - Channel input interrupt
+ uint32_t ip_ier;
+} xilinx_axi_gpio;
+typedef struct {
+ volatile xilinx_axi_gpio *regs;
+ bool is_dual;
+ uint32_t irq;
+ bool has_interrupts;
+} xilinx_axi_gpio_context;
+ * @brief Set pin configuration for the specified GPIO channel.
+ * Changes the pin configuration for a channel. Bits set to 0 are output, and
+ * bits set to 1 are input.
+ * @param[in] ctx the GPIO context
+ * @param[in] channel the GPIO channel
+ * @param[in] mask the mask to be applied to @ channel
+ * @retval None
+void axi_gpio_set_data_direction(
+ xilinx_axi_gpio_context *ctx,
+ uint32_t channel,
+ uint32_t mask
+ * @brief Get pin configuration for specified GPIO channel.
+ * Gets the current pin configuration for a specified GPIO channel. Bits set to
+ * 0 are output, and bits set to 1 are input.
+ * @retval bitmask specifiying which pins on a channel are input or output
+uint32_t axi_gpio_get_data_direction(
+ uint32_t channel
+ * @brief Reads data for specified GPIO channel.
+ * @retval Current values in discretes register.
+uint32_t axi_gpio_discrete_read(
+ uint32_t channel
+ * @brief Writes to data register for specified GPIO channel.
+ * @retval None
+void axi_gpio_discrete_write(
+ uint32_t channel,
+ uint32_t mask
+ * @brief Set bits to 1 on specified GPIO channel.
+ * @retval None
+void axi_gpio_discrete_set(
+ uint32_t channel,
+ uint32_t mask
+ * @brief Set bits to 0 on specified GPIO channel.
+ * @retval None
+void axi_gpio_discrete_clear(
+ uint32_t channel,
+ uint32_t mask
+ * @brief Returns the vector number of the interrupt handler.
+ * @retval the vector number
+rtems_vector_number axi_gpio_get_irq( xilinx_axi_gpio_context *ctx );
+ * @brief Turns on interrupts globally.
+ * @retval None
+void axi_gpio_interrupt_global_enable( xilinx_axi_gpio_context *ctx );
+ * @brief Turns off interrupts globally.
+ * @retval None
+void axi_gpio_interrupt_global_disable( xilinx_axi_gpio_context *ctx );
+ * @brief Enables interrupts on specified channel
+ * @param[in] channel the channel to enable interrupts on
+ * @retval None
+void axi_gpio_interrupt_enable(
+ uint32_t channel
+ * @brief Disables interrupts on specified channel
+ * @param[in] channel the channel to turn interrupts on for
+ * @retval None
+void axi_gpio_interrupt_disable(
+ uint32_t channel
+ * @brief Clear status of interrupt signals on a specific channel
+ * @param[in] channel the channel to clear the interrupt pending status from
+ * @retval None
+void axi_gpio_interrupt_clear(
+ uint32_t channel
+ * @brief Return a bitmask of the interrupts that are enabled
+ * @retval the bitmask of enabled interrupts
+uint32_t axi_gpio_interrupt_get_enabled( xilinx_axi_gpio_context *ctx );
+ * @brief Return a bitmask of the status of the interrupt signals
+ * @retval bitmask containing statuses of interrupt signals
+uint32_t axi_gpio_interrupt_get_status( xilinx_axi_gpio_context *ctx );
+#ifdef __cplusplus
+#endif /* XILINX_AXI_GPIO_H */
diff --git a/bsps/shared/dev/gpio/xilinx-axi-gpio.c b/bsps/shared/dev/gpio/xilinx-axi-gpio.c
index 0000000000..53146a7bf0
--- /dev/null
+++ b/bsps/shared/dev/gpio/xilinx-axi-gpio.c
@@ -0,0 +1,221 @@
+ * @file
+ * @brief Xilinx AXI GPIO implementation
+ * are met:
+#include <assert.h>
+#include <bsp/fatal.h>
+#include <dev/gpio/xilinx-axi-gpio.h>
+ uint32_t channel,
+ uint32_t mask
+ assert( channel == 1 || (ctx->is_dual && channel == 2) );
+ if ( channel == 1 ) {
+ ctx->regs->gpio_tri = mask;
+ } else if ( ctx->is_dual && channel == 2 ) {
+ ctx->regs->gpio2_tri = mask;
+ uint32_t channel
+ return ctx->regs->gpio_tri;
+ return ctx->regs->gpio2_tri;
+ return 0;
+ uint32_t channel
+ return ctx->regs->gpio_data;
+ return 0;
+ uint32_t channel,
+ uint32_t mask
+ ctx->regs->gpio_data = mask;
+ uint32_t channel,
+ uint32_t mask
+ ctx->regs->gpio_data |= mask;
+ ctx->regs->gpio2_tri |= mask;
+ uint32_t channel,
+ uint32_t mask
+ ctx->regs->gpio_data &= ~mask;
+ ctx->regs->gpio2_tri &= ~mask;
+ return ctx->irq;
+ assert( ctx->has_interrupts );
+ if ( ctx->has_interrupts ) {
+ ctx->regs->gier = GLOBAL_INTERRUPT_REGISTER_ENABLE;
+ ctx->regs->gier = 0x0;
+ uint32_t channel
+ ctx->regs->ip_ier |= CHANNEL_1_INTERRUPT_REGISTER;
+ ctx->regs->ip_ier |= CHANNEL_2_INTERRUPT_REGISTER;
+ uint32_t channel
+ ctx->regs->ip_ier &= ~CHANNEL_1_INTERRUPT_REGISTER;
+ ctx->regs->ip_ier &= ~CHANNEL_2_INTERRUPT_REGISTER;
+ uint32_t channel
+ ctx->regs->ip_isr &= CHANNEL_1_INTERRUPT_REGISTER;
+ ctx->regs->ip_isr &= CHANNEL_2_INTERRUPT_REGISTER;
+ return ctx->regs->ip_ier;
+ return 0;
+ return ctx->regs->ip_isr;
+ return 0;
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 993ba04004..3d151db193 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -14,6 +14,7 @@ install:
- bsps/microblaze/microblaze_fpga/include/tm27.h
- destination: ${BSP_INCLUDEDIR}/bsp
source:
+ - bsps/include/dev/gpio/xilinx-axi-gpio.h
- bsps/microblaze/microblaze_fpga/include/bsp/irq.h
- bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
- bsps/microblaze/include/common/xil_types.h
@@ -44,6 +45,7 @@ source:
- bsps/shared/dev/cpucounter/cpucounterfrequency.c
- bsps/shared/dev/cpucounter/cpucounterread.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/gpio/xilinx-axi-gpio.c
- bsps/shared/dev/serial/console-termios-init.c
- bsps/shared/dev/serial/console-termios.c
- bsps/shared/irq/irq-default-handler.c
2.32.0
