Support for test coverage analysis in RTEMS 6
    Jerzy Jaskuc
    jaskucj at tcd.ie
    Wed Mar 16 16:45:55 UTC 2022
Hi,
I've been looking into generating code coverage reports from RTEMS tests in
RTEMS 6.
I'm using SPARC with gr712rc BSP.
I'm following the steps outlined in the coverage analysis documentation
https://docs.rtems.org/branches/master/user/testing/coverage.html
However, when I run it on any tests, even sample/hello.exe
I get the logs in lines of the following:
`RTEMS Testing - Tester, 6.0.not_released
 Command Line: ./rtems-test --rtems-tools=/home/yoman/RTEMS/rtems/6
--log=log_leon3_sis --rtems-bsp=leon3-sis-cov --coverage
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-validation-0.exe
 Host: Linux ubuntu 5.13.0-35-generic #40~20.04.1-Ubuntu SMP Mon Mar 7
09:18:32 UTC 2022 x86_64
 Python: 3.8.10 (default, Nov 26 2021, 20:14:08) [GCC 9.3.0]
Host: Linux-5.13.0-35-generic-x86_64-with-glibc2.29 (Linux ubuntu
5.13.0-35-generic #40~20.04.1-Ubuntu SMP Mon Mar 7 09:18:32 UTC 2022 x86_64
x86_64)
[1/1] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:0 W:0 | sparc/leon3-sis:
ts-validation-0.exe
Passed:        1
Failed:        0
User Input:    0
Expected Fail: 0
Indeterminate: 0
Benchmark:     0
Timeout:       0
Test too long: 0
Invalid:       0
Wrong Version: 0
Wrong Build:   0
Wrong Tools:   0
Wrong Header:  0
Total:         1
Average test time: 0:00:02.008333
Testing time     : 0:00:02.008333
Running coverage analysis (/home/yoman/RTEMS/rtems/6/bin/leon3-sis-coverage)
Function is both external and inlined: _Message_queue_Create
Function is both external and inlined: _Thread_Initialize_information
Function is both external and inlined: _Thread_queue_Initialize
Function is both external and inlined: _Thread_queue_Resume
Function is both external and inlined: _Thread_queue_FIFO_first
Function is both external and inlined: _Thread_CPU_budget_consume_and_yield
Function is both external and inlined: _Thread_Join
Function is both external and inlined: _Thread_Set_state_locked
Function is both external and inlined: _Timecounter_Binuptime
Function is both external and inlined: _Timecounter_Bintime
Function is both external and inlined: _Timecounter_Getboottimebin
Function is both external and inlined: _Thread_Priority_perform_actions
Function is both external and inlined: _Thread_Clear_state_locked
Function is both external and inlined: _Malloc_System_state
Function is both external and inlined: rtems_counter_initialize_converter
Function is both external and inlined: rtems_version_minor
Function is both external and inlined: _Heap_Get_first_and_last_block
Error while running sparc-rtems6-objdump on
Objdump error in generating objdump
Coverage time: 0:00:01.085511
Coverage generating reports
Coverage analysis finished: /home/yoman/RTEMS/rtems/6/bin`
I've tried to do a fresh VM fresh RTEMS build, results are exactly the
same.
It seems like it's something to do with `objdump`? That would explain the
generated report containing only unreferenced symbols.
Any tips on what's wrong or where to start looking to try and fix it?
I wanted to generate coverage reports for the tests I developed, but not
sure if there's any other way than through making this part work.
Thanks and all the best!
Jerzy
