RTEMS-specific Newlib patches for aarch64
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 17 15:40:57 UTC 2022
On 3/17/2022 07:30, Kinsey Moore wrote:
> On 3/17/2022 05:00, Sebastian Huber wrote:
>> Hello,
>> the current Newlib build fails for aarch64 due to RTEMS-specific
>> patches:
>>   CC       libc/string/libc_a-wcscmp.o
>> ../../../gnu-mirror-gcc-0f001dd/newlib/libc/machine/aarch64/setjmp.S:29:10:
>> fatal error: ../asmdefs.h: No such file or directory
>>    29 | #include <../asmdefs.h>
>> Why are these patches not in upstream Newlib?
> The only patch I'm aware of should be for ILP32 support in the
> hand-coded AArch64 assembly in newlib.
> The short answer as to why the patch isn't upstream is that newlib
> hasn't committed it yet.
> The longer answer is that the hand-coded AArch64 ASM in newlib is
> sourced from ARM's optimized-routines repository. I provided a patch
> to newlib's specifications at which point they suggested I get it
> committed upstream in the optimized-routines repo, first. I did that
> and then requested they pull the changes, but they were in the middle
> of a release cycle. Having the patch locally was the interim solution
> while we waited for that release to finish and for newlib to pull in
> the changes. I'll take a look and see what the current status on that
> is and what changes prompted the patch to break.
I just rebuilt this on the current RTEMS6 GCC10 branch with current
newlib (ed32020) and had no problems building it. It's odd that the file
is missing given that it's newly written by the patch. What else is
necessary to reproduce the build failure?
Kinsey
