[PATCH 00/13] Refactor Arm GICv3 support
Sebastian Huber
Fri Mar 18 07:19:02 UTC 2022
Separate the Interrupt Manager implementation from the generic Arm GICv3
support. Move parts of the Arm GICv3 support into a new header file. This
helps to support systems with a clustered structure in which multiple GICv3
instances are present. For example, two clusters of two Cortex-R52 cores where
each cluster has a dededicated GICv3 instance.
Sebastian Huber (13):
bsps: Add <dev/irq/arm-gicv3.h>
bsps: Add gicv3_sgi_ppi_is_pending()
bsps: Add gicv3_trigger_sgi()
bsps: Add gicv3_ppi_set_pending()
bsps: Add gicv3_ppi_clear_pending()
bsps: Add gicv3_sgi_ppi_is_enabled()
bsps: Add gicv3_sgi_ppi_enable()
bsps: Add gicv3_sgi_ppi_disable()
bsps: Move gicv3_init_dist()
bsps: Move gicv3_init_cpu_interface()
bsps: Add gicv3_sgi_ppi_set_priority()
bsps: Add gicv3_sgi_ppi_get_priority()
bsps: Add gicv3_get_attributes()
bsps/include/dev/irq/arm-gicv3.h | 366 +++++++++++++++++++++++++++++++
bsps/shared/dev/irq/arm-gicv3.c | 286 ++----------------------
spec/build/bsps/aarch64/grp.yml | 1 +
spec/build/bsps/arm/grp.yml | 1 +
4 files changed, 389 insertions(+), 265 deletions(-)
create mode 100644 bsps/include/dev/irq/arm-gicv3.h
2.34.1
