[PATCH 08/13] bsps: Add gicv3_sgi_ppi_disable()
Sebastian Huber
Fri Mar 18 07:19:10 UTC 2022
bsps/include/dev/irq/arm-gicv3.h | 10 ++++++++++
bsps/shared/dev/irq/arm-gicv3.c | 5 +----
2 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index effa7a8ffb..37e0d433cc 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -171,6 +171,16 @@ static inline void gicv3_sgi_ppi_enable(
sgi_ppi->icspiser[0] = 1U << vector;
+static inline void gicv3_sgi_ppi_disable(
+ rtems_vector_number vector,
+ uint32_t cpu_index
+ volatile gic_sgi_ppi *sgi_ppi = gicv3_get_sgi_ppi(cpu_index);
+ sgi_ppi->icspicer[0] = 1U << vector;
static inline bool gicv3_sgi_ppi_is_enabled(
uint32_t cpu_index
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index c71a9f15ab..6c623f0ccb 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -192,10 +192,7 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
gic_id_disable(dist, vector);
} else {
- volatile gic_sgi_ppi *sgi_ppi =
- gicv3_get_sgi_ppi(_SMP_Get_current_processor());
- sgi_ppi->icspicer[0] = 1U << vector;
+ gicv3_sgi_ppi_disable(vector, _SMP_Get_current_processor());
return RTEMS_SUCCESSFUL;
2.34.1
