[PATCH 09/13] bsps: Move gicv3_init_dist()
Fri Mar 18 07:19:11 UTC 2022
Make the distributor register block a parameter.
 bsps/include/dev/irq/arm-gicv3.h | 37 +++++++++++++++++++++++++++++
 bsps/shared/dev/irq/arm-gicv3.c  | 40 +-------------------------------
 2 files changed, 38 insertions(+), 39 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index 37e0d433cc..de15b5cc81 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -242,6 +242,43 @@ static inline void gicv3_trigger_sgi(
   WRITE64_SR(ICC_SGI1, value);
+static inline uint32_t gicv3_get_id_count(volatile gic_dist *dist)
+  uint32_t id_count = GIC_DIST_ICDICTR_IT_LINES_NUMBER_GET(dist->icdictr);
+  id_count = 32 * (id_count + 1);
+  id_count = id_count <= 1020 ? id_count : 1020;
+  return id_count;
+static void gicv3_init_dist(volatile gic_dist *dist)
+  uint32_t id_count = gicv3_get_id_count(dist);
+  uint32_t id;
+  dist->icddcr = GIC_DIST_ICDDCR_ARE_NS | GIC_DIST_ICDDCR_ARE_S
+               | GIC_DIST_ICDDCR_ENABLE_GRP1S | GIC_DIST_ICDDCR_ENABLE_GRP1NS
+               | GIC_DIST_ICDDCR_ENABLE_GRP0;
+  for (id = 0; id < id_count; id += 32) {
+    /* Disable all interrupts */
+    dist->icdicer[id / 32] = 0xffffffff;
+    /* Set G1NS */
+    dist->icdigr[id / 32] = 0xffffffff;
+    dist->icdigmr[id / 32] = 0;
+  for (id = 0; id < id_count; ++id) {
+    gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
+  for (id = 32; id < id_count; ++id) {
+    gic_id_set_targets(dist, id, 0x01);
 #ifdef __cplusplus
 #endif
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 6c623f0ccb..29ef2bb1a3 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -198,44 +198,6 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
   return RTEMS_SUCCESSFUL;
-static inline uint32_t get_id_count(volatile gic_dist *dist)
-  uint32_t id_count = GIC_DIST_ICDICTR_IT_LINES_NUMBER_GET(dist->icdictr);
-  id_count = 32 * (id_count + 1);
-  id_count = id_count <= 1020 ? id_count : 1020;
-  return id_count;
-static void gicv3_init_dist(void)
-  volatile gic_dist *dist = ARM_GIC_DIST;
-  uint32_t id_count = get_id_count(dist);
-  uint32_t id;
-  dist->icddcr = GIC_DIST_ICDDCR_ARE_NS | GIC_DIST_ICDDCR_ARE_S
-               | GIC_DIST_ICDDCR_ENABLE_GRP1S | GIC_DIST_ICDDCR_ENABLE_GRP1NS
-               | GIC_DIST_ICDDCR_ENABLE_GRP0;
-  for (id = 0; id < id_count; id += 32) {
-    /* Disable all interrupts */
-    dist->icdicer[id / 32] = 0xffffffff;
-    /* Set G1NS */
-    dist->icdigr[id / 32] = 0xffffffff;
-    dist->icdigmr[id / 32] = 0;
-  for (id = 0; id < id_count; ++id) {
-    gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
-  for (id = 32; id < id_count; ++id) {
-    gic_id_set_targets(dist, id, 0x01);
 static void gicv3_init_cpu_interface(void)
   uint32_t cpu_index = _SMP_Get_current_processor();
@@ -267,7 +229,7 @@ static void gicv3_init_cpu_interface(void)
 void bsp_interrupt_facility_initialize(void)
   arm_interrupt_facility_set_exception_handler();
-  gicv3_init_dist();
+  gicv3_init_dist(ARM_GIC_DIST);
   gicv3_init_cpu_interface();
2.34.1
