[PATCH 01/13] bsps: Add <dev/irq/arm-gicv3.h>
Kinsey Moore kinsey.moore at oarcorp.com
Fri Mar 18 13:13:20 UTC 2022
Nit in the commit message: "dededicated"
On 3/18/2022 02:19, Sebastian Huber wrote:
> Separate the Interrupt Manager implementation from the generic Arm GICv3
> support.  Move parts of the Arm GICv3 support into a new header file.  This
> helps to support systems with a clustered structure in which multiple GICv3
> instances are present.  For example, two clusters of two Cortex-R52 cores where
> each cluster has a dededicated GICv3 instance.
>   bsps/include/dev/irq/arm-gicv3.h | 162 +++++++++++++++++++++++++++++++
>   bsps/shared/dev/irq/arm-gicv3.c  | 122 +----------------------
>   spec/build/bsps/aarch64/grp.yml  |   1 +
>   spec/build/bsps/arm/grp.yml      |   1 +
>   4 files changed, 165 insertions(+), 121 deletions(-)
>   create mode 100644 bsps/include/dev/irq/arm-gicv3.h
> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
> new file mode 100644
> index 0000000000..60bc315962
> --- /dev/null
> +++ b/bsps/include/dev/irq/arm-gicv3.h
> @@ -0,0 +1,162 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup arm_gic
> + * @brief This header file contains interfaces to access an Arm GICv3.
> + * Copyright (C) 2019 On-Line Applications Research Corporation (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_DEV_IRQ_ARM_GICV3_H
> +#define _RTEMS_DEV_IRQ_ARM_GICV3_H
> +#include <dev/irq/arm-gic.h>
> +#include <dev/irq/arm-gic-arch.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#define PRIORITY_DEFAULT 127
> +#define MPIDR_AFFINITY2(val) BSP_FLD64(val, 16, 23)
> +#define MPIDR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 16, 23)
> +#define MPIDR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
> +#define MPIDR_AFFINITY1(val) BSP_FLD64(val, 8, 15)
> +#define MPIDR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 8, 15)
> +#define MPIDR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 8, 15)
> +#define MPIDR_AFFINITY0(val) BSP_FLD64(val, 0, 7)
> +#define MPIDR_AFFINITY0_GET(reg) BSP_FLD64GET(reg, 0, 7)
> +#define MPIDR_AFFINITY0_SET(reg, val) BSP_FLD64SET(reg, val, 0, 7)
> +#define ICC_SGIR_AFFINITY3(val) BSP_FLD64(val, 48, 55)
> +#define ICC_SGIR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 48, 55)
> +#define ICC_SGIR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 48, 55)
> +#define ICC_SGIR_IRM BSP_BIT32(40)
> +#define ICC_SGIR_AFFINITY2(val) BSP_FLD64(val, 32, 39)
> +#define ICC_SGIR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 32, 39)
> +#define ICC_SGIR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39)
> +#define ICC_SGIR_INTID(val) BSP_FLD64(val, 24, 27)
> +#define ICC_SGIR_INTID_GET(reg) BSP_FLD64GET(reg, 24, 27)
> +#define ICC_SGIR_INTID_SET(reg, val) BSP_FLD64SET(reg, val, 24, 27)
> +#define ICC_SGIR_AFFINITY1(val) BSP_FLD64(val, 16, 23)
> +#define ICC_SGIR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 16, 23)
> +#define ICC_SGIR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
> +#define ICC_SGIR_CPU_TARGET_LIST(val) BSP_FLD64(val, 0, 15)
> +#define ICC_SGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD64GET(reg, 0, 15)
> +#define ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD64SET(reg, val, 0, 15)
> +#ifdef ARM_MULTILIB_ARCH_V4
> +/* cpuif->iccicr */
> +#define ICC_CTLR    "p15, 0, %0, c12, c12, 4"
> +/* cpuif->iccpmr */
> +#define ICC_PMR     "p15, 0, %0,  c4,  c6, 0"
> +/* cpuif->iccbpr */
> +#define ICC_BPR0    "p15, 0, %0, c12,  c8, 3"
> +#define ICC_BPR1    "p15, 0, %0, c12, c12, 3"
> +/* cpuif->icciar */
> +#define ICC_IAR0    "p15, 0, %0, c12,  c8, 0"
> +#define ICC_IAR1    "p15, 0, %0, c12, c12, 0"
> +/* cpuif->icceoir */
> +#define ICC_EOIR0   "p15, 0, %0, c12,  c8, 1"
> +#define ICC_EOIR1   "p15, 0, %0, c12, c12, 1"
> +#define ICC_SRE     "p15, 0, %0, c12, c12, 5"
> +#define ICC_IGRPEN0 "p15, 0, %0, c12, c12, 6"
> +#define ICC_IGRPEN1 "p15, 0, %0, c12, c12, 7"
> +#define MPIDR       "p15, 0, %0, c0, c0, 5"
> +#define READ_SR(SR_NAME) \
> +  uint32_t value; \
> +  __asm__ volatile("mrc    " SR_NAME : "=r" (value) ); \
> +  value; \
> +#define WRITE_SR(SR_NAME, VALUE) \
> +    __asm__ volatile("mcr    " SR_NAME "  \n" : : "r" (VALUE) );
> +#define ICC_SGI1    "p15, 0, %Q0, %R0, c12"
> +#define WRITE64_SR(SR_NAME, VALUE) \
> +    __asm__ volatile("mcrr    " SR_NAME "  \n" : : "r" (VALUE) );
> +#else /* ARM_MULTILIB_ARCH_V4 */
> +/* AArch64 GICv3 registers are not named in GCC */
> +#define ICC_IGRPEN0 "S3_0_C12_C12_6, %0"
> +#define ICC_IGRPEN1 "S3_0_C12_C12_7, %0"
> +#define ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0"
> +#define ICC_PMR     "S3_0_C4_C6_0, %0"
> +#define ICC_EOIR1   "S3_0_C12_C12_1, %0"
> +#define ICC_SRE     "S3_0_C12_C12_5, %0"
> +#define ICC_BPR0    "S3_0_C12_C8_3, %0"
> +#define ICC_CTLR    "S3_0_C12_C12_4, %0"
> +#define ICC_IAR1    "%0, S3_0_C12_C12_0"
> +#define MPIDR       "%0, mpidr_el1"
> +#define MPIDR_AFFINITY3(val) BSP_FLD64(val, 32, 39)
> +#define MPIDR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 32, 39)
> +#define MPIDR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39)
> +#define ICC_SGI1    "S3_0_C12_C11_5, %0"
> +    __asm__ volatile("msr    " SR_NAME "  \n" : : "r" (VALUE) );
> +#define WRITE_SR(SR_NAME, VALUE) WRITE64_SR(SR_NAME, VALUE)
> +  uint64_t value; \
> +  __asm__ volatile("mrs    " SR_NAME : "=&r" (value) ); \
> +  value; \
> +#endif /* ARM_MULTILIB_ARCH_V4 */
> +static inline volatile gic_redist *gicv3_get_redist(uint32_t cpu_index)
> +  return (volatile gic_redist *)
> +    ((uintptr_t)BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000);
> +static inline volatile gic_sgi_ppi *gicv3_get_sgi_ppi(uint32_t cpu_index)
> +  return (volatile gic_sgi_ppi *)
> +    ((uintptr_t)BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000 + 0x10000);
> +#ifdef __cplusplus
> +#endif
> +#endif /* _RTEMS_DEV_IRQ_ARM_GICV3_H */
> diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
> index afe21a8e15..58f97c4f43 100644
> --- a/bsps/shared/dev/irq/arm-gicv3.c
> +++ b/bsps/shared/dev/irq/arm-gicv3.c
> @@ -25,132 +25,12 @@
> -#include <dev/irq/arm-gic.h>
> -#include <dev/irq/arm-gic-arch.h>
> +#include <dev/irq/arm-gicv3.h>
>   #include <bsp/irq.h>
>   #include <bsp/irq-generic.h>
>   #include <bsp/start.h>
> -#ifdef ARM_MULTILIB_ARCH_V4
> -#include <rtems/score/armv4.h>
> -#else
> -#include <rtems/score/cpu_irq.h>
> -#endif
> -#define PRIORITY_DEFAULT 127
> -#define MPIDR_AFFINITY2(val) BSP_FLD64(val, 16, 23)
> -#define MPIDR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 16, 23)
> -#define MPIDR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
> -#define MPIDR_AFFINITY1(val) BSP_FLD64(val, 8, 15)
> -#define MPIDR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 8, 15)
> -#define MPIDR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 8, 15)
> -#define MPIDR_AFFINITY0(val) BSP_FLD64(val, 0, 7)
> -#define MPIDR_AFFINITY0_GET(reg) BSP_FLD64GET(reg, 0, 7)
> -#define MPIDR_AFFINITY0_SET(reg, val) BSP_FLD64SET(reg, val, 0, 7)
> -#define ICC_SGIR_AFFINITY3(val) BSP_FLD64(val, 48, 55)
> -#define ICC_SGIR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 48, 55)
> -#define ICC_SGIR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 48, 55)
> -#define ICC_SGIR_IRM BSP_BIT32(40)
> -#define ICC_SGIR_AFFINITY2(val) BSP_FLD64(val, 32, 39)
> -#define ICC_SGIR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 32, 39)
> -#define ICC_SGIR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39)
> -#define ICC_SGIR_INTID(val) BSP_FLD64(val, 24, 27)
> -#define ICC_SGIR_INTID_GET(reg) BSP_FLD64GET(reg, 24, 27)
> -#define ICC_SGIR_INTID_SET(reg, val) BSP_FLD64SET(reg, val, 24, 27)
> -#define ICC_SGIR_AFFINITY1(val) BSP_FLD64(val, 16, 23)
> -#define ICC_SGIR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 16, 23)
> -#define ICC_SGIR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23)
> -#define ICC_SGIR_CPU_TARGET_LIST(val) BSP_FLD64(val, 0, 15)
> -#define ICC_SGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD64GET(reg, 0, 15)
> -#define ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD64SET(reg, val, 0, 15)
> -/* cpuif->iccicr */
> -#define ICC_CTLR    "p15, 0, %0, c12, c12, 4"
> -/* cpuif->iccpmr */
> -#define ICC_PMR     "p15, 0, %0,  c4,  c6, 0"
> -/* cpuif->iccbpr */
> -#define ICC_BPR0    "p15, 0, %0, c12,  c8, 3"
> -#define ICC_BPR1    "p15, 0, %0, c12, c12, 3"
> -/* cpuif->icciar */
> -#define ICC_IAR0    "p15, 0, %0, c12,  c8, 0"
> -#define ICC_IAR1    "p15, 0, %0, c12, c12, 0"
> -/* cpuif->icceoir */
> -#define ICC_EOIR0   "p15, 0, %0, c12,  c8, 1"
> -#define ICC_EOIR1   "p15, 0, %0, c12, c12, 1"
> -#define ICC_SRE     "p15, 0, %0, c12, c12, 5"
> -#define ICC_IGRPEN0 "p15, 0, %0, c12, c12, 6"
> -#define ICC_IGRPEN1 "p15, 0, %0, c12, c12, 7"
> -#define MPIDR       "p15, 0, %0, c0, c0, 5"
> -#define READ_SR(SR_NAME) \
> -  uint32_t value; \
> -  __asm__ volatile("mrc    " SR_NAME : "=r" (value) ); \
> -  value; \
> -#define WRITE_SR(SR_NAME, VALUE) \
> -    __asm__ volatile("mcr    " SR_NAME "  \n" : : "r" (VALUE) );
> -#define ICC_SGI1    "p15, 0, %Q0, %R0, c12"
> -#define WRITE64_SR(SR_NAME, VALUE) \
> -    __asm__ volatile("mcrr    " SR_NAME "  \n" : : "r" (VALUE) );
> -#else /* ARM_MULTILIB_ARCH_V4 */
> -/* AArch64 GICv3 registers are not named in GCC */
> -#define ICC_IGRPEN0 "S3_0_C12_C12_6, %0"
> -#define ICC_IGRPEN1 "S3_0_C12_C12_7, %0"
> -#define ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0"
> -#define ICC_PMR     "S3_0_C4_C6_0, %0"
> -#define ICC_EOIR1   "S3_0_C12_C12_1, %0"
> -#define ICC_SRE     "S3_0_C12_C12_5, %0"
> -#define ICC_BPR0    "S3_0_C12_C8_3, %0"
> -#define ICC_CTLR    "S3_0_C12_C12_4, %0"
> -#define ICC_IAR1    "%0, S3_0_C12_C12_0"
> -#define MPIDR       "%0, mpidr_el1"
> -#define MPIDR_AFFINITY3(val) BSP_FLD64(val, 32, 39)
> -#define MPIDR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 32, 39)
> -#define MPIDR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39)
> -#define ICC_SGI1    "S3_0_C12_C11_5, %0"
> -    __asm__ volatile("msr    " SR_NAME "  \n" : : "r" (VALUE) );
> -#define WRITE_SR(SR_NAME, VALUE) WRITE64_SR(SR_NAME, VALUE)
> -  uint64_t value; \
> -  __asm__ volatile("mrs    " SR_NAME : "=&r" (value) ); \
> -  value; \
> -#endif /* ARM_MULTILIB_ARCH_V4 */
> -static volatile gic_redist *gicv3_get_redist(uint32_t cpu_index)
> -  return (volatile gic_redist *)
> -    ((uintptr_t)BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000);
> -static volatile gic_sgi_ppi *gicv3_get_sgi_ppi(uint32_t cpu_index)
> -  return (volatile gic_sgi_ppi *)
> -    ((uintptr_t)BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000 + 0x10000);
>   void bsp_interrupt_dispatch(void)
>     uint32_t icciar = READ_SR(ICC_IAR1);
> diff --git a/spec/build/bsps/aarch64/grp.yml b/spec/build/bsps/aarch64/grp.yml
> index a6bc0d5a31..8f204b5945 100644
> --- a/spec/build/bsps/aarch64/grp.yml
> +++ b/spec/build/bsps/aarch64/grp.yml
> @@ -19,6 +19,7 @@ install:
>     - bsps/include/dev/irq/arm-gic-regs.h
>     - bsps/include/dev/irq/arm-gic-tm27.h
>     - bsps/include/dev/irq/arm-gic.h
> +  - bsps/include/dev/irq/arm-gicv3.h
>   - destination: ${BSP_LIBDIR}
>     source:
>     - bsps/aarch64/shared/start/linkcmds.base
> diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
> index dbd21638fd..a8ebe07f15 100644
> --- a/spec/build/bsps/arm/grp.yml
> +++ b/spec/build/bsps/arm/grp.yml
> @@ -42,6 +42,7 @@ install:
>   - destination: ${BSP_INCLUDEDIR}/libcpu
>     source:
>     - bsps/arm/include/libcpu/am335x.h
