[PATCH 04/26] cpukit/libfs/src/defaults: Change license to BSD-2
Fri Mar 18 16:21:11 UTC 2022
Updates #3053.
 .../src/defaults/default_are_nodes_equal.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_chown.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_clone.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_close.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_eval_path.c | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_fchmod.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_fcntl.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_freenode.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_fstat.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_fsunmount.c | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_fsync.c     | 25 ++++++++++++++++---
 .../src/defaults/default_fsync_success.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_ftruncate.c | 25 ++++++++++++++++---
 .../defaults/default_ftruncate_directory.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_handlers.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_ioctl.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_kqfilter.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_link.c      | 25 ++++++++++++++++---
 .../src/defaults/default_lock_and_unlock.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_lseek.c     | 25 ++++++++++++++++---
 .../src/defaults/default_lseek_directory.c    | 25 ++++++++++++++++---
 .../libfs/src/defaults/default_lseek_file.c   | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_mknod.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_mmap.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_mount.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_open.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_poll.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_read.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_readlink.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_readv.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_rename.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_rmnod.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_statvfs.c   | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_symlink.c   | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_unmount.c   | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_write.c     | 25 ++++++++++++++++---
 cpukit/libfs/src/defaults/default_writev.c    | 25 ++++++++++++++++---
 37 files changed, 814 insertions(+), 111 deletions(-)
diff --git a/cpukit/libfs/src/defaults/default_are_nodes_equal.c b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
index e9e89e1088..bdcac110d5 100644
--- a/cpukit/libfs/src/defaults/default_are_nodes_equal.c
+++ b/cpukit/libfs/src/defaults/default_are_nodes_equal.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libfs/src/defaults/default_chown.c b/cpukit/libfs/src/defaults/default_chown.c
index b3da5dc3e6..cae32e3a3a 100644
--- a/cpukit/libfs/src/defaults/default_chown.c
+++ b/cpukit/libfs/src/defaults/default_chown.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
  *  COPYRIGHT (c) 2010.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_clone.c b/cpukit/libfs/src/defaults/default_clone.c
index 7f27998df1..7d42355fa0 100644
--- a/cpukit/libfs/src/defaults/default_clone.c
+++ b/cpukit/libfs/src/defaults/default_clone.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_close.c b/cpukit/libfs/src/defaults/default_close.c
index eb9e429c67..bf97ca24d9 100644
--- a/cpukit/libfs/src/defaults/default_close.c
+++ b/cpukit/libfs/src/defaults/default_close.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
 #include <rtems/libio.h>
diff --git a/cpukit/libfs/src/defaults/default_eval_path.c b/cpukit/libfs/src/defaults/default_eval_path.c
index 5dcc52eaac..c2514df93d 100644
--- a/cpukit/libfs/src/defaults/default_eval_path.c
+++ b/cpukit/libfs/src/defaults/default_eval_path.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fchmod.c b/cpukit/libfs/src/defaults/default_fchmod.c
index b3a3d3ae9c..2cdb42b4ff 100644
--- a/cpukit/libfs/src/defaults/default_fchmod.c
+++ b/cpukit/libfs/src/defaults/default_fchmod.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fcntl.c b/cpukit/libfs/src/defaults/default_fcntl.c
index a9d9995bc2..ad5cc58c25 100644
--- a/cpukit/libfs/src/defaults/default_fcntl.c
+++ b/cpukit/libfs/src/defaults/default_fcntl.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_freenode.c b/cpukit/libfs/src/defaults/default_freenode.c
index da502a5882..002e6b5d70 100644
--- a/cpukit/libfs/src/defaults/default_freenode.c
+++ b/cpukit/libfs/src/defaults/default_freenode.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fstat.c b/cpukit/libfs/src/defaults/default_fstat.c
index 4b0e151ea5..2966c4c458 100644
--- a/cpukit/libfs/src/defaults/default_fstat.c
+++ b/cpukit/libfs/src/defaults/default_fstat.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fsunmount.c b/cpukit/libfs/src/defaults/default_fsunmount.c
index 65d42bbce7..3c42478044 100644
--- a/cpukit/libfs/src/defaults/default_fsunmount.c
+++ b/cpukit/libfs/src/defaults/default_fsunmount.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fsync.c b/cpukit/libfs/src/defaults/default_fsync.c
index a7ff75d11f..c87227eb5b 100644
--- a/cpukit/libfs/src/defaults/default_fsync.c
+++ b/cpukit/libfs/src/defaults/default_fsync.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_fsync_success.c b/cpukit/libfs/src/defaults/default_fsync_success.c
index 19a171373e..bbbeb1c8b8 100644
--- a/cpukit/libfs/src/defaults/default_fsync_success.c
+++ b/cpukit/libfs/src/defaults/default_fsync_success.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_ftruncate.c b/cpukit/libfs/src/defaults/default_ftruncate.c
index 194a94cf98..6aa2493f1b 100644
--- a/cpukit/libfs/src/defaults/default_ftruncate.c
+++ b/cpukit/libfs/src/defaults/default_ftruncate.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_ftruncate_directory.c b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
index 0d5b499975..33ae65ffcf 100644
--- a/cpukit/libfs/src/defaults/default_ftruncate_directory.c
+++ b/cpukit/libfs/src/defaults/default_ftruncate_directory.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_handlers.c b/cpukit/libfs/src/defaults/default_handlers.c
index 572e39ffce..0e61c5a24c 100644
--- a/cpukit/libfs/src/defaults/default_handlers.c
+++ b/cpukit/libfs/src/defaults/default_handlers.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_ioctl.c b/cpukit/libfs/src/defaults/default_ioctl.c
index 5c21ffcf34..1d55281941 100644
--- a/cpukit/libfs/src/defaults/default_ioctl.c
+++ b/cpukit/libfs/src/defaults/default_ioctl.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_kqfilter.c b/cpukit/libfs/src/defaults/default_kqfilter.c
index 14ed85045c..3f060845fd 100644
--- a/cpukit/libfs/src/defaults/default_kqfilter.c
+++ b/cpukit/libfs/src/defaults/default_kqfilter.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2013, 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_link.c b/cpukit/libfs/src/defaults/default_link.c
index d40fc663dc..1e0da97bd7 100644
--- a/cpukit/libfs/src/defaults/default_link.c
+++ b/cpukit/libfs/src/defaults/default_link.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_lock_and_unlock.c b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
index 81c5318fbb..584614a8cf 100644
--- a/cpukit/libfs/src/defaults/default_lock_and_unlock.c
+++ b/cpukit/libfs/src/defaults/default_lock_and_unlock.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_lseek.c b/cpukit/libfs/src/defaults/default_lseek.c
index 33724682ee..6a6c20e290 100644
--- a/cpukit/libfs/src/defaults/default_lseek.c
+++ b/cpukit/libfs/src/defaults/default_lseek.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_lseek_directory.c b/cpukit/libfs/src/defaults/default_lseek_directory.c
index 4af6e5566f..4b80c164e3 100644
--- a/cpukit/libfs/src/defaults/default_lseek_directory.c
+++ b/cpukit/libfs/src/defaults/default_lseek_directory.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_lseek_file.c b/cpukit/libfs/src/defaults/default_lseek_file.c
index 30315f246a..e3901b5f9c 100644
--- a/cpukit/libfs/src/defaults/default_lseek_file.c
+++ b/cpukit/libfs/src/defaults/default_lseek_file.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_mknod.c b/cpukit/libfs/src/defaults/default_mknod.c
index 54abc144fa..f5780e9d82 100644
--- a/cpukit/libfs/src/defaults/default_mknod.c
+++ b/cpukit/libfs/src/defaults/default_mknod.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_mmap.c b/cpukit/libfs/src/defaults/default_mmap.c
index 52f5b96faa..90128773c2 100644
--- a/cpukit/libfs/src/defaults/default_mmap.c
+++ b/cpukit/libfs/src/defaults/default_mmap.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2017 Kevin Kirspel (kirspkt at gmail.com)
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_mount.c b/cpukit/libfs/src/defaults/default_mount.c
index ce089c6090..16c9fced02 100644
--- a/cpukit/libfs/src/defaults/default_mount.c
+++ b/cpukit/libfs/src/defaults/default_mount.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_open.c b/cpukit/libfs/src/defaults/default_open.c
index 754620a665..ac3457b127 100644
--- a/cpukit/libfs/src/defaults/default_open.c
+++ b/cpukit/libfs/src/defaults/default_open.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_poll.c b/cpukit/libfs/src/defaults/default_poll.c
index f3e9465af7..afa09c2c20 100644
--- a/cpukit/libfs/src/defaults/default_poll.c
+++ b/cpukit/libfs/src/defaults/default_poll.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_read.c b/cpukit/libfs/src/defaults/default_read.c
index 0c3cacea54..970b8168c9 100644
--- a/cpukit/libfs/src/defaults/default_read.c
+++ b/cpukit/libfs/src/defaults/default_read.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_readlink.c b/cpukit/libfs/src/defaults/default_readlink.c
index c391bd5c76..14ad7aa716 100644
--- a/cpukit/libfs/src/defaults/default_readlink.c
+++ b/cpukit/libfs/src/defaults/default_readlink.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_readv.c b/cpukit/libfs/src/defaults/default_readv.c
index af0fb1aae6..40db4f3054 100644
--- a/cpukit/libfs/src/defaults/default_readv.c
+++ b/cpukit/libfs/src/defaults/default_readv.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_rename.c b/cpukit/libfs/src/defaults/default_rename.c
index b2ae12b260..09b7acad4e 100644
--- a/cpukit/libfs/src/defaults/default_rename.c
+++ b/cpukit/libfs/src/defaults/default_rename.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_rmnod.c b/cpukit/libfs/src/defaults/default_rmnod.c
index 50ce1b427f..b2200825cc 100644
--- a/cpukit/libfs/src/defaults/default_rmnod.c
+++ b/cpukit/libfs/src/defaults/default_rmnod.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_statvfs.c b/cpukit/libfs/src/defaults/default_statvfs.c
index 46e53f62e9..110366b9ec 100644
--- a/cpukit/libfs/src/defaults/default_statvfs.c
+++ b/cpukit/libfs/src/defaults/default_statvfs.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_symlink.c b/cpukit/libfs/src/defaults/default_symlink.c
index a036471ed9..c6a15052c3 100644
--- a/cpukit/libfs/src/defaults/default_symlink.c
+++ b/cpukit/libfs/src/defaults/default_symlink.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_unmount.c b/cpukit/libfs/src/defaults/default_unmount.c
index ca9da15c50..88856e750d 100644
--- a/cpukit/libfs/src/defaults/default_unmount.c
+++ b/cpukit/libfs/src/defaults/default_unmount.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_write.c b/cpukit/libfs/src/defaults/default_write.c
index 49e451968a..aa53dfc75f 100644
--- a/cpukit/libfs/src/defaults/default_write.c
+++ b/cpukit/libfs/src/defaults/default_write.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/defaults/default_writev.c b/cpukit/libfs/src/defaults/default_writev.c
index f29a1a5285..31c1c76da2 100644
--- a/cpukit/libfs/src/defaults/default_writev.c
+++ b/cpukit/libfs/src/defaults/default_writev.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
2.24.4
