[PATCH 03/26] cpukit/libdrvmsg: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:10 UTC 2022
Updates #3053.
cpukit/libdrvmgr/drvmgr.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_by_id.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_by_name.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_dev_by_name.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_drvinf.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_for_each_dev.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_for_each_list_dev.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_func.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_func_call.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_init.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_internal.h | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_list.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_lock.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_print.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_res.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_rw.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_translate.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_translate_check.c | 25 ++++++++++++++++++---
cpukit/libdrvmgr/drvmgr_unregister.c | 25 ++++++++++++++++++---
19 files changed, 418 insertions(+), 57 deletions(-)
diff --git a/cpukit/libdrvmgr/drvmgr.c b/cpukit/libdrvmgr/drvmgr.c
index 4f48a9e2fc..aa70f17842 100644
--- a/cpukit/libdrvmgr/drvmgr.c
+++ b/cpukit/libdrvmgr/drvmgr.c
@@ -1,10 +1,29 @@
/* Driver Manager Interface Implementation.
* COPYRIGHT (c) 2009 Cobham Gaisler AB.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/cpukit/libdrvmgr/drvmgr_by_id.c b/cpukit/libdrvmgr/drvmgr_by_id.c
index 84164e3864..c3c2a9b1b2 100644
--- a/cpukit/libdrvmgr/drvmgr_by_id.c
+++ b/cpukit/libdrvmgr/drvmgr_by_id.c
@@ -1,10 +1,29 @@
/* Find driver by driver-ID
* COPYRIGHT (c) 2011 Cobham Gaisler AB.
+ * are met:
#include <drvmgr/drvmgr.h>
diff --git a/cpukit/libdrvmgr/drvmgr_by_name.c b/cpukit/libdrvmgr/drvmgr_by_name.c
index b095589076..dfb854abec 100644
--- a/cpukit/libdrvmgr/drvmgr_by_name.c
+++ b/cpukit/libdrvmgr/drvmgr_by_name.c
@@ -1,10 +1,29 @@
/* Find driver by driver-name
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_dev_by_name.c b/cpukit/libdrvmgr/drvmgr_dev_by_name.c
index 350902497c..13c7c95992 100644
--- a/cpukit/libdrvmgr/drvmgr_dev_by_name.c
+++ b/cpukit/libdrvmgr/drvmgr_dev_by_name.c
@@ -1,10 +1,29 @@
/* Find device by device name
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_drvinf.c b/cpukit/libdrvmgr/drvmgr_drvinf.c
index 346a66fef9..11ba1eabb7 100644
--- a/cpukit/libdrvmgr/drvmgr_drvinf.c
+++ b/cpukit/libdrvmgr/drvmgr_drvinf.c
@@ -1,10 +1,29 @@
/* Driver Manager Driver Interface Implementation.
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_for_each_dev.c b/cpukit/libdrvmgr/drvmgr_for_each_dev.c
index 288360bdbf..1b27ce856b 100644
--- a/cpukit/libdrvmgr/drvmgr_for_each_dev.c
+++ b/cpukit/libdrvmgr/drvmgr_for_each_dev.c
@@ -1,10 +1,29 @@
/* Iterate over device tree topology, breadth or depth-first
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c b/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
index 860e871ec7..1ef6a47424 100644
--- a/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
+++ b/cpukit/libdrvmgr/drvmgr_for_each_list_dev.c
@@ -1,10 +1,29 @@
/* Iterate over one list of devices used internally by driver manager
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_func.c b/cpukit/libdrvmgr/drvmgr_func.c
index 8d506d68fb..aea52e1e8d 100644
--- a/cpukit/libdrvmgr/drvmgr_func.c
+++ b/cpukit/libdrvmgr/drvmgr_func.c
@@ -1,10 +1,29 @@
/* Driver Manager optional dynamic function interface
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_func_call.c b/cpukit/libdrvmgr/drvmgr_func_call.c
index d06b0527a7..22c892dca5 100644
--- a/cpukit/libdrvmgr/drvmgr_func_call.c
+++ b/cpukit/libdrvmgr/drvmgr_func_call.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_init.c b/cpukit/libdrvmgr/drvmgr_init.c
index 891ba0303c..b7d02e5ab8 100644
--- a/cpukit/libdrvmgr/drvmgr_init.c
+++ b/cpukit/libdrvmgr/drvmgr_init.c
@@ -1,10 +1,29 @@
/* Driver Manager Initialization
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_internal.h b/cpukit/libdrvmgr/drvmgr_internal.h
index 78617e5a2b..94d46ab552 100644
--- a/cpukit/libdrvmgr/drvmgr_internal.h
+++ b/cpukit/libdrvmgr/drvmgr_internal.h
@@ -1,10 +1,29 @@
/* Private driver manager declarations
+ * are met:
#include <rtems/score/apimutex.h>
diff --git a/cpukit/libdrvmgr/drvmgr_list.c b/cpukit/libdrvmgr/drvmgr_list.c
index 111bbc160a..fc868d7b44 100644
--- a/cpukit/libdrvmgr/drvmgr_list.c
+++ b/cpukit/libdrvmgr/drvmgr_list.c
@@ -1,10 +1,29 @@
/* Driver Manager List Interface Implementation.
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_lock.c b/cpukit/libdrvmgr/drvmgr_lock.c
index 5b7cbcff25..38708a72a6 100644
--- a/cpukit/libdrvmgr/drvmgr_lock.c
+++ b/cpukit/libdrvmgr/drvmgr_lock.c
@@ -1,10 +1,29 @@
/* Driver Manager Internal locking implementation
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_print.c b/cpukit/libdrvmgr/drvmgr_print.c
index 4b3f8c3c0f..2c043e5105 100644
--- a/cpukit/libdrvmgr/drvmgr_print.c
+++ b/cpukit/libdrvmgr/drvmgr_print.c
@@ -1,10 +1,29 @@
/* Driver Manager Information printing Interface Implementation
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_res.c b/cpukit/libdrvmgr/drvmgr_res.c
index 0322a9897a..8a447dab48 100644
--- a/cpukit/libdrvmgr/drvmgr_res.c
+++ b/cpukit/libdrvmgr/drvmgr_res.c
@@ -1,10 +1,29 @@
/* Driver Manager Driver Resource Interface Implementation.
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_rw.c b/cpukit/libdrvmgr/drvmgr_rw.c
index c974366e56..d4efb3c4e2 100644
--- a/cpukit/libdrvmgr/drvmgr_rw.c
+++ b/cpukit/libdrvmgr/drvmgr_rw.c
@@ -1,10 +1,29 @@
/* Driver Manager Read/Write Interface Implementation.
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_translate.c b/cpukit/libdrvmgr/drvmgr_translate.c
index e12546a3f6..2e8233e610 100644
--- a/cpukit/libdrvmgr/drvmgr_translate.c
+++ b/cpukit/libdrvmgr/drvmgr_translate.c
@@ -1,10 +1,29 @@
/* Driver Manager Driver Translate Interface Implementation
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_translate_check.c b/cpukit/libdrvmgr/drvmgr_translate_check.c
index 5ee0930402..9459def64a 100644
--- a/cpukit/libdrvmgr/drvmgr_translate_check.c
+++ b/cpukit/libdrvmgr/drvmgr_translate_check.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/cpukit/libdrvmgr/drvmgr_unregister.c b/cpukit/libdrvmgr/drvmgr_unregister.c
index fae5363651..391594279e 100644
--- a/cpukit/libdrvmgr/drvmgr_unregister.c
+++ b/cpukit/libdrvmgr/drvmgr_unregister.c
@@ -1,10 +1,29 @@
/* Driver Manager Device Unregister (removal) implementation
+ * are met:
