[PATCH 08/26] cpukit/libfs/src/rfs: Change license to BSD-2
Fri Mar 18 16:21:15 UTC 2022
Updates #3053.
 cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c      | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-block.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-buffer.c       | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-dir.c          | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-file-system.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-file.c         | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-format.c       | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-group.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-inode.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-link.c         | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-mutex.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c    | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c   | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c  | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-rtems.h        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-shell.c        | 25 ++++++++++++++++---
 cpukit/libfs/src/rfs/rtems-rfs-trace.c        | 25 ++++++++++++++++---
 21 files changed, 462 insertions(+), 63 deletions(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
index 6da555d50e..d756fc4006 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  *  COPYRIGHT (c) 2010 Chris Johns <chrisj at rtems.org>
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-block.c b/cpukit/libfs/src/rfs/rtems-rfs-block.c
index 5dc8634818..1bff094514 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-block.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-block.c
@@ -1,3 +1,5 @@
  * @file
@@ -28,9 +30,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
index b1b6027b83..2148917971 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
index 0f5931141a..88a2909991 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
index 814de10dbe..a79af13bde 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
index 227fda3b91..fb2acd63af 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
@@ -1,3 +1,5 @@
  * @file
@@ -19,9 +21,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
index 11ce9f353c..ebf6cfe234 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-file-system.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-file.c b/cpukit/libfs/src/rfs/rtems-rfs-file.c
index b59768defd..f907d2d6a7 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-file.c
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-format.c b/cpukit/libfs/src/rfs/rtems-rfs-format.c
index 9acf152061..9863efd195 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-format.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-format.c
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-group.c b/cpukit/libfs/src/rfs/rtems-rfs-group.c
index 5f2808f166..b48775f2c0 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-group.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-group.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-inode.c b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
index 644042eb8c..3035e7c88d 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-inode.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-inode.c
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-link.c b/cpukit/libfs/src/rfs/rtems-rfs-link.c
index 5a8c70188b..64d1571cc6 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-link.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-link.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
index 34d0dbabec..a2302581ea 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-mutex.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
index 0f31a54fe2..65ddc0f026 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
index d1d28f5185..1c416e0436 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index 2c406cee5b..210e416097 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
index 9db46fa902..c72a840937 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 0efab2cca6..4db48a8422 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
  *  Modifications to support reference counting in the file system are
  *  Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.h b/cpukit/libfs/src/rfs/rtems-rfs-rtems.h
index 2f1385ede2..2cec2f58f2 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.h
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.h
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
+ * are met:
 #if !defined(RTEMS_RFS_RTEMS_DEFINED)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-shell.c b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
index 81d2d06037..3ffb740645 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-shell.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-shell.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-trace.c b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
index b064898074..85312267a7 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-trace.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-trace.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
2.24.4
