[PATCH 09/26] cpukit/libgnat: Change license to BSD-2.
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:16 UTC 2022
Updates #3053.
cpukit/libgnat/ada_intrsupp.c | 25 ++++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cpukit/libgnat/ada_intrsupp.c b/cpukit/libgnat/ada_intrsupp.c
index e30d50cbc6..4c0319fa58 100644
--- a/cpukit/libgnat/ada_intrsupp.c
+++ b/cpukit/libgnat/ada_intrsupp.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2010.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
2.24.4
