[PATCH 14/26] cpukit/libmisc/capture: Manually change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:21 UTC 2022
These files did not follow the standard format and needed to be
changed manually.
Updates #3053.
cpukit/libmisc/capture/README | 4 +-
cpukit/libmisc/capture/capture-cli.c | 57 ++++++++++++-------
cpukit/libmisc/capture/capture.c | 55 +++++++++++-------
cpukit/libmisc/capture/capture_buffer.c | 49 ++++++++++------
cpukit/libmisc/capture/capture_buffer.h | 42 +++++++++-----
cpukit/libmisc/capture/capture_support.c | 57 ++++++++++++-------
.../libmisc/capture/capture_user_extension.c | 51 +++++++++++------
7 files changed, 200 insertions(+), 115 deletions(-)
diff --git a/cpukit/libmisc/capture/README b/cpukit/libmisc/capture/README
index 3e59637149..806bb37d1f 100644
--- a/cpukit/libmisc/capture/README
+++ b/cpukit/libmisc/capture/README
@@ -1,7 +1,7 @@
RTEMS Performance Monitoring and Measurement Framework
- Copyright 2002-2007 Chris Johns (chrisj at rtems.org)
- 23 April 2002
+ Copyright 2002-2007 Chris Johns (chrisj at rtems.org)
+ 23 April 2002
This directory contains the source code for the performance monitoring and
measurement framework. It is more commonly know as the capture engine.
diff --git a/cpukit/libmisc/capture/capture-cli.c b/cpukit/libmisc/capture/capture-cli.c
index d489d9f32a..d8afc982a1 100644
--- a/cpukit/libmisc/capture/capture-cli.c
+++ b/cpukit/libmisc/capture/capture-cli.c
@@ -1,25 +1,40 @@
- Copyright 2002, 2015 Chris Johns <chrisj at rtems.org>
- All rights reserved.
- COPYRIGHT (c) 2014.
- On-Line Applications Research Corporation (OAR).
- The license and distribution terms for this file may be
- found in the file LICENSE in this distribution.
- This software with is provided ``as is'' and with NO WARRANTY.
- RTEMS Performance Monitoring and Measurement Framework.
- This is the Target Interface Command Line Interface. You need
- start the RTEMS monitor.
+ * @file
+ * @brief RTEMS Performance Monitoring and Measurement Framework.
+ * This is the Target Interface Command Line Interface. You need
+ * start the RTEMS monitor.
+ * Copyright 2002, 2015 Chris Johns <chrisj at rtems.org>.
+ * All rights reserved.
+ * COPYRIGHT (c) 2014.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
#include "config.h"
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index bba7d91396..2ed607ecaf 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -1,24 +1,39 @@
- Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>.
- COPYRIGHT (c) 1989-2014.
- This is the Capture Engine component.
+ * @file
+ * This is the Capture Engine component.
+ * Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>.
+ * COPYRIGHT (c) 1989-2014.
+ * are met:
#include "config.h"
diff --git a/cpukit/libmisc/capture/capture_buffer.c b/cpukit/libmisc/capture/capture_buffer.c
index 967842000b..2b7d6947e5 100644
--- a/cpukit/libmisc/capture/capture_buffer.c
+++ b/cpukit/libmisc/capture/capture_buffer.c
@@ -1,22 +1,35 @@
+ * @file
+ * to start the RTEMS monitor.
+ * COPYRIGHT (c) 2014. On-Line Applications Research Corporation (OAR).
+ * are met:
#include "config.h"
diff --git a/cpukit/libmisc/capture/capture_buffer.h b/cpukit/libmisc/capture/capture_buffer.h
index af75c0204c..8f2f59b39f 100644
--- a/cpukit/libmisc/capture/capture_buffer.h
+++ b/cpukit/libmisc/capture/capture_buffer.h
@@ -7,21 +7,33 @@
- Copyright 2016 Chris Johns <chrisj at rtems.org>.
+ * Copyright 2016 Chris Johns <chrisj at rtems.org>.
+ * are met:
#ifndef __CAPTURE_BUFFER_H_
#define __CAPTURE_BUFFER_H_
diff --git a/cpukit/libmisc/capture/capture_support.c b/cpukit/libmisc/capture/capture_support.c
index e2438fb23b..ab301ddeb3 100644
--- a/cpukit/libmisc/capture/capture_support.c
+++ b/cpukit/libmisc/capture/capture_support.c
@@ -1,25 +1,40 @@
- This is a set of print support routines that may be shared between
- the RTEMS monitor and direct callers of the capture engine.
+ * @file
+ * This is a set of print support routines that may be shared between
+ * the RTEMS monitor and direct callers of the capture engine.
+ * are met:
#include "config.h"
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
index ae4107afbc..8f793f1c9b 100644
--- a/cpukit/libmisc/capture/capture_user_extension.c
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -1,22 +1,37 @@
+ * @file
- Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * are met:
#include "config.h"
2.24.4
