[PATCH 13/26] cpukit/capture: Change license to BSD-2
Fri Mar 18 16:21:20 UTC 2022
Updates #3053.
 .../capture/rtems-trace-buffer-default.c      | 25 ++++++++++++++++---
 .../libmisc/capture/rtems-trace-buffer-vars.c | 25 ++++++++++++++++---
 2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/cpukit/libmisc/capture/rtems-trace-buffer-default.c b/cpukit/libmisc/capture/rtems-trace-buffer-default.c
index 23c66cdc88..fd9a9cc06b 100644
--- a/cpukit/libmisc/capture/rtems-trace-buffer-default.c
+++ b/cpukit/libmisc/capture/rtems-trace-buffer-default.c
@@ -1,9 +1,28 @@
  *  Copyright (c) 2015 Chris Johns <chrisj at rtems.org>
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <rtems/trace/rtems-trace-buffer-vars.h>
diff --git a/cpukit/libmisc/capture/rtems-trace-buffer-vars.c b/cpukit/libmisc/capture/rtems-trace-buffer-vars.c
index ec24181253..5e565387d0 100644
--- a/cpukit/libmisc/capture/rtems-trace-buffer-vars.c
+++ b/cpukit/libmisc/capture/rtems-trace-buffer-vars.c
@@ -1,9 +1,28 @@
+ * are met:
2.24.4
